Old 10-09-2023, 11:21 AM
chuckies76ta's Avatar
Default Intake gaskets
Wondering what guys are using that holds up really well for over sized intake gaskets?
Gasket I used are 1.20x2.40 on Edelbrock heads. I had a set of these gaskets split and cover the ports some. Thanks
Link:https://tinindianperformance.com/pon...%20gaskets.htm
950 Quickfuel.
Old 10-09-2023, 11:36 AM
My High ports were ported to that size but using those gaskets the bolt holes I had to redo to line up. Not on a motor yet.
SCE I think only has up to 2.350 tall.
Old 10-09-2023, 11:45 AM
Ill check them out. Thanks Skip
950 Quickfuel.
Old 10-09-2023, 12:17 PM
leeklm's Avatar
leeklm leeklm is offline
Tin Indian has a new performance gasket, vs the old school paper gaskets I previously purchased. Installed a set on my 325cfm heads- but only been a few weeks now. Material seems good to the eye.
Sent from my SM-G965U using Tapatalk
The Following User Says Thank You to leeklm For This Useful Post:
Old 10-09-2023, 12:31 PM
Ken MacNicol's Avatar
Ken MacNicol Ken MacNicol is offline
Fel Pro 1233
The Following 2 Users Say Thank You to Ken MacNicol For This Useful Post:
Old 10-09-2023, 05:20 PM
The FelPro 1233 is only about 2.200" tall.
Unless changed the Tin Indian gaskets are a knock off of the SCE gaskets.
Butler lists a 2.240" tall gasket:
https://butlerperformance.com/i-2445...-128104-2.html
Here is Summit:
https://www.summitracing.com/parts/s...ntiac#overview
Old information here:
Old 10-09-2023, 05:35 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Intake gaskets have went to poop. Used to use SCE gaskets and could go two seasons testing manifolds more than a dozen times on the same pair of gaskets. Nowadays they don't seem to be oil, anti-freeze or crack resistant. If you're lucky a new set won't tear pulling the manifold off a never fired before engine. We've been using custom made Cometic manifold gaskets and so far no issues. We've only been using them for a couple of years so not a ton of feedback...... However all the gasket manufacturers got the memo to increase prices.
Go fast, see Elvis!
The Following 2 Users Say Thank You to PAUL K For This Useful Post:
Old 10-09-2023, 05:36 PM
X2
Old 10-09-2023, 05:41 PM
SCE can also make a .120 thick also. I have an intake that someone milled 0.060 too much just on one side! So different gaskets.
Old 10-09-2023, 06:01 PM
PAUL K's Avatar
We try to keep .030/.060/.090 and .120 thick in stock for that reason. It also helps to align the ports.
Go fast, see Elvis!
Old 10-09-2023, 08:07 PM
73 TRANSAM 73 TRANSAM is offline
Default intake gasket
I had Flatout gaskets make me a custom set for my WP Eheads. I think it's .060 but it is a steel coated gasket. They went up in pricing as I bought a spare set. This reminds me of Felpro but fits a WP heads.
The Following User Says Thank You to 73 TRANSAM For This Useful Post:
Old 10-10-2023, 04:43 AM
Any part numbers for the Cometic .060 set. Thanks
950 Quickfuel.
Old 10-10-2023, 04:50 AM
Thank you. I will check with them.
950 Quickfuel.
Old 10-10-2023, 02:49 PM
PAUL K's Avatar
Best bet would be to call them with your port dimensions and hopefully they have a match.
Go fast, see Elvis!
Old 10-10-2023, 05:27 PM
Bill Eveland's Avatar
Are those doubled up or just single to do that? I used to have to run double, but ended up having a local guy make me some aluminum copies of the gasket and glued them to the intake. These are a 380 Highport gasket
Illinois Outlaw Gassers
6.27@107
9.97@131
The Following User Says Thank You to Bill Eveland For This Useful Post:
Old 10-11-2023, 05:30 AM
Mine was just the single gasket .060 on each side. Not sure why it did that. I don't use any sealer on the gaskets. Did not have any vacuum leaks. Almost looks like an install issue on my part. I always trim the gaskets to get a perfect fit. I install a new set, we'll see how they last. But looking for a stronger gasket. Thanks for all who posted info.
950 Quickfuel.
Old 10-13-2023, 07:24 PM
Probird's Avatar
Probird Probird is offline
I have good luck with the Butler gaskets. The ones from Tin Indian I had issues with them coming apart.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0
2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion
and 2015 IHRA Div 5 Mod champion
2024 Chief of the Pontiacs
The Following User Says Thank You to Probird For This Useful Post:
Old 10-13-2023, 11:15 PM
AG's Avatar
AG AG is offline
I had to use one 0.060" and one 0.120" gasket from Butler with my Victor/Dominator to get good port alignment. They only needed a small amount of trimming to fit well.
The Following User Says Thank You to AG For This Useful Post:
Old 10-14-2023, 09:29 AM
So I sent an email out to them and the new number is 1.20 x 2.40 Pontiac intake manifold gasket .060 thick D7900 That's the good part. Shipping came up as $230 U.S. I'll have to call em. Thanks
Description
1.20 x 2.40 Pontiac intake manifold gasket .060 thick in our D7900 material which is more durable material that stands up better to alky and other more corrosive fuels. Gasket is used on the 325 cfm and 340 cfm KRE D port heads as well as a few of the standard pushrod location KRE High Port heads.
Gaskets are sold in pairs.
950 Quickfuel.
Old 10-14-2023, 11:10 AM
PAUL K's Avatar
Maybe that includes installation
Go fast, see Elvis!
