Old 10-13-2023, 06:01 PM
grd777 grd777 is offline
Default having issues with my sail panels purchased from AMES
never had a problem from the parts i buy from Ames , but the sail panel do not fit right .Any one else had this issue
Old 10-13-2023, 06:22 PM
Trevor78 Trevor78 is offline
Looking at that they likely go under the rear trim
Old 10-13-2023, 06:24 PM
no i can not get it far back enough to make it fit Just checked the ones OER sells and the look more correct
Old 10-13-2023, 06:48 PM
Ok, and yes pics look like it goes over as shown. Can you roll it into place from side rather than push backwards?
Old 10-13-2023, 07:29 PM
when i install against the roof pillar it will not go any further back . cant stand when these repo parts don't work . i wonder why no one else had this problem i guess i will buy the ones from OER AND REPORT BACK TO INFORM THE OTHER GUYS IF THE FIT BETTER
The Following User Says Thank You to grd777 For This Useful Post:
Old 10-13-2023, 09:23 PM
burd's Avatar
burd burd is offline
I’d use nOS myself.
Southern Hamtramck Institute of Technology , Alumni
Put some 8” flakes and BFG’s on dude!, like everyone does🙄
Burds Literature, nOS factory Brochures, Glovebox literature, & black & blue freedom toppers.
1978 YEE
1995 Q45
#whoremembers
Old 10-13-2023, 09:34 PM
Originally Posted by burd View Post
I’d use nOS myself.
ok if i can find them i will buy them ?
Old 10-14-2023, 07:55 AM
All well and good suggesting that if they were available.
Old 10-14-2023, 08:44 AM
Mr Twister's Avatar
Possibly some extra material/mold flash in the u shaped leading edge that hooks over the pinch weld in the front?
Old 10-14-2023, 09:49 AM
will check that thanks for the tip
Old 10-14-2023, 10:02 AM
burd's Avatar
Gastro, I Didn’t sell any nOS on Dayton, just rusty junk. I had a whole table of nOS, it all went back home. Other than the serious collector, people won’t pay for it.
1978 YEE
1995 Q45
#whoremembers
Old 10-14-2023, 11:53 AM
i do and will for NOS .DO YOU HAVE ANY SAIL PANELS NOS
Old 10-14-2023, 03:16 PM
Norwood's Avatar
Norwood Norwood is offline
In all likelihood whoever you buy them from they come from the same source.
The Following 3 Users Say Thank You to Norwood For This Useful Post:
Old 11-01-2023, 02:18 PM
skunkwerks's Avatar
skunkwerks skunkwerks is offline
You may have to drill a new hole in the lower area on the cars side to mount them correctly.
It really depends on where the factory drilled the original hole.
White/Blue 71 455 HO T/A Auto
Blue/Blue 71 455 HO T/A 4 Sp
White/Sandalwood 71 455 HO T/A 4 Sp
White/Black 70 RAIII T/A M21/373 (stripper)
Carousel Red/Black 69 GTO Judge 4 Sp
2002 Firehawk Red/Black 6Sp
Old 11-01-2023, 07:08 PM
not worried about the hole .its were it meets the upper glass. thesE ones are for a 73-74 OER MAKES THE CORRECT ONES FOR 70-72 CHECK THEM OUT ON THE WEB AND YOU WILL SEE THEY ARE NOT THE SAME
