#181
Old 10-13-2023, 11:48 AM
The date codes decipher like this :
A201 = Jan 20 1971
B120 = Feb 12 1970
C302 = March 30 1972
D071 = April 07 1971
and so on , etc ...
  #182
Old 10-13-2023, 11:57 AM
79 Phoenix's Avatar
79 Phoenix 79 Phoenix is offline
Okay...Here are codes... There is a big "350" on the side of the block.
The last picture must be the serial# ? The Date appears to be Jan 15 (or16) 71.
Not sure what XR suffix means...
ID:	621577   Click image for larger version
ID:	621578   Click image for larger version
The Following User Says Thank You to 79 Phoenix For This Useful Post:
  #183
Old 10-13-2023, 12:13 PM
Verdoro 68's Avatar
In 1971, XR meant 250hp 350ci with an automatic behind it.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #184
Old 10-13-2023, 12:41 PM
Definitely 1971 block
#94 is a 1971 only - head ID number
The last picture is the partial VIN of the original car.
2= PMD
1= 1971 model year
Z= Fremont Cali plant
xxxxxx= last 6 digits of VIN
  #185
Old 10-13-2023, 12:50 PM
79 Phoenix's Avatar
Any reason this engine couldn't be used with a manual transmission?
  #186
Old 10-13-2023, 01:50 PM
79 Phoenix's Avatar
Now, in looking at the engine currently in my GT-37 (which I have assumed is the original), here is the block casting #...
Is this supposed to match the VIN or part of the VIN?
VIN on my car is 233371P160219
Any idea what WN indicates?
Name:	GT-37 Block.jpg
  #187
Old 10-13-2023, 03:10 PM
79 Phoenix's Avatar
On further investigation of the engine that is currently in my car, I found the block serial # which includes the last 6 digits of my car's VIN. So, that indicates it is an original number matching engine, right? Also found the large 350 casting on drivers side.
Is there a way I can find out what WN means on the ID#?
  #188
Old 10-13-2023, 03:23 PM
Verdoro 68's Avatar
There's no specific block for manual or automatic, so you could totally use that XR with a manual. I believe all cranks are machined to receive a pilot bearing, but I could be wrong.
Engine codes: https://pontiacpower.net/numbers/engine-codes/
WN looks like a 250hp 350 with a manual trans in '71. The numbers above the two letter engine code are just a production number. I don't believe they match anything else. The partial vin is stamped down on the lower front size of the block. That's supposed to match the vin plate on your dash.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #189
Old 10-13-2023, 04:01 PM
79 Phoenix's Avatar
Okay--Thanks so much for the charts and the info! yes, the partial VIN matches the 160219 on my dash VIN plate.
WN I guess is one of multiple suffix used on various A body 71 250 HP w/4spd designated blocks. ... I see it in the chart listed for a 71 250 HP 350 w/4 speed and mine's a 3 speed but maybe in 71 they didn't differentiate between 3sp and 4 spd with regard to the suffix.
Thank you guys for your time and patience helping me figure out what I've got in these 2 engines. I really appreciate it!
  #190
Old 10-13-2023, 05:38 PM
Verdoro 68's Avatar
I don't believe the engine codes typically specified what type of manual transmission, just whether it was a manual or an auto.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #191
Old 10-20-2023, 04:28 PM
79 Phoenix's Avatar
Engine is now out and going to machine shop on Monday. First picture is block ID# that matches VIN. Transmission is not a Muncie but a Saginaw 3 speed. It has one groove... I am assuming it's original and what Pontiac put behind the 250 HP 350's.. .Does anyone know of a chart that shows how to ID this 3 speed?
Name:	Original engine BLOCK VIN.jpg
ID:	621963   Click image for larger version
Name:	Original engine.jpg
ID:	621964   Click image for larger version
Name:	input shaft.jpg
  #192
Old 10-21-2023, 11:38 PM
Mister Pontiac's Avatar
Mister Pontiac Mister Pontiac is offline
Be happy, because you have the Muncie M-13 there. Since it's original to the car (GT-37), it should have come equipped with the "Heavy Duty" Muncie M-13 behind the 350. The 3 speed only has one grove on the input shaft like your picture.
Another way to confirm is to count the bolts on the side cover. Across the top, it will have 2 bolts on the Muncie, but only one on the Saginaw.
To be 100% sure, post a picture of your transmission, including the side cover.
My factory 1972 GT came with the 350/3 speed, which is the same Muncie M-13 as yours.
Incidentally, the M-13 is my favorite transmission for street driving out of all of my cars! The gear spread is identical to a Turbo 400 automatic, but you get to do the shifting. And on the street, a Pontiac doesn't need 4 gears. 3 is perfectly suited to the job.
Enjoy!!
Eric Mitten
'74 Bonneville 4dr Sedan (455/TH400/2.93 open)
'72 LeMans GT (455/M-13/3.23 [8.5"] posi)
'71 GTO Hardtop (400/TH400/3.07 12 bolt posi)
‘71 GTO Convertible (455HO/TH400/3.23 posi)
'67 GTO Coupe (455/ST-10/2.93 posi)
Deuteronomy 8:3
The Following User Says Thank You to Mister Pontiac For This Useful Post:
  #193
Old 10-22-2023, 03:52 PM
79 Phoenix's Avatar
Thanks for the info! I cleaned it up a little more and here are some pictures. It does have 2 bolts at top of side cover...So I guess it is the M13? Also a yellow "RM" is stenciled on it in a couple spots. Not sure what that means.
ID:	622083   Click image for larger version
ID:	622084   Click image for larger version
  #194
Old 10-22-2023, 04:11 PM
RM is the pick code for the 1971 M13 Muncie.
2.42 1st gear, 1.58 2nd gear
  #195
Old 10-22-2023, 04:53 PM
I'm trying to remember what the RM stands for as well. John may well be right that it's a pick code, but it would have been the same in 72 then. My 72 GT has its original M-13, and it has the same "RM" yellow stamp (pics below).
And I'm not 100% sure either, but I always heard the ratio's were 2:48, 1:48, 1:00, same as a Turbo 400.
But to answer your question, yes indeed! You have the strongest 3 speed you could ask for there. And as a bonus, you still have the bracket for the back drive assembly attached.
That M-13 is plenty strong for a 350. Mine has 100,000+ behind the original 350, and another 20,000 behind a 455, all with zero issues. I expect none going forward either. I love the 'whine' you get from the gears in the M-13. Akin to the M-22 Rockcrusher gear whine, though not as pronounced. Heck, I luv the trans so much in my 72, I found another spare M-13 that I plan to put into my 71 GTO behind a (soon to be built) 455HO.
Congrats, and enjoy!
ID:	622091   Click image for larger version
ID:	622092   Click image for larger version
Eric Mitten
Deuteronomy 8:3
  #196
Old 10-22-2023, 05:00 PM
79 Phoenix's Avatar
Here's picture of the Saginaw I once had in my 79 Phoenix... It was a 4 speed originally in a 77 Monza... But it also has 2 bolts in the top of side cover... By 77 I would imagine there were changes to the Saginaw design that might account for the 2 bolts rather than 1 bolt at the top of side cover like earlier versions?
  #197
Old 10-22-2023, 05:05 PM
I would say so, yes.
The fact that you have the VIN match on your trans, and the date code falls in line with the car build date gives you extreme confidence that you have the original trans to your car, which would be the Muncie M-13.
Saginaws from that era had the single bolt on the top of the side cover, and they were weaker transmissions, all things being equal.
I don't know what happened to the designs as the later 70's rolled in.
Eric Mitten
Deuteronomy 8:3
  #198
Old 10-22-2023, 05:10 PM
I fat fingered my response above and changed it to the correct RM code.
1972 also used RM as the code for the M13 Muncie.
  #199
Old 10-22-2023, 05:37 PM
79 Phoenix's Avatar
Where would the VIN numbers and date code be located on the transmission?
I love the M22 whine!! I can't wait to drive this... Hopefully sometime next spring or summer.
  #200
Old 10-22-2023, 07:27 PM
Look at the right side of the main case. You will see a cast in date code on the case body, a standard 4 letter/digit combo that indicates the date code.
Just above that on a machined pad, there will be the last part of the VIN stamped into the smooth surface. It should look just like the VIN stamped onto the engine block.
The picture below is my 72 GT M-13. Notice the VIN stamped into the smooth surface, and just below, cast into the case is the date code. In my case, D122. That translates to April (D), 12, 1972. My car was built the first week of May 72, and the VIN matches, so it's the original to the car.
Hope that helps.
Eric Mitten
Deuteronomy 8:3
