Old 11-05-2023, 11:14 PM
Verdoro 68's Avatar
Is that the Danville cars and coffee??
This was Brentwood. I think they only the Danville c&c tied to special events now since it got crazy a few years ago. We went to one down there last month that was pretty good.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #162
Old 11-06-2023, 09:15 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Hit up cars and coffee a couple of towns over this morning for a 40 mile round trip of mostly freeway driving. Parked next to a '69 Goat and there were a couple nice early '70s Formulas parked down the line.
I noticed a trans leak when I got home which weirdly got me excited because it wasn't a rear main leak! BOP seal seems to be working great so far.
I snugged the pan bolts up, but it looks like it's coming from the vent tube and dripping down the side. Wondering if I just have it overfilled or if I should be thinking about a trans cooler with this TSP converter.
Great pic! If your stall is higher than stock you need a transcooler. Fluid level is critical for longevity
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
  #163
Old 11-06-2023, 01:12 PM
Chipping away on the new to me '72. Back window had goop around the trim. Windshield leaks really bad.
[ATTACH]Click image for larger version
  #164
Old 11-06-2023, 09:12 PM
Shiny Shiny is offline
I acquired a 68 Chevelle in 1973. In it's 5-yr life, the sheet metal under the rear window had rusted through. Yours at least lasted a little longer!
  #165
Old 11-06-2023, 09:43 PM
It's supposed to be winter but it's not so I took a step toward road-worthy.
I had gone through all the suspension many years ago and left a lot un-done. I made a crude pass to get caster and camber somewhere north of nowhere. I found I'd left the nuts on the upper control arm shafts loose... a mind is a terrible thing to waste.
The greased pizza-pans idea off YouTube worked fine. No trouble turning the wheels by hand.
I painted these 14" rallys about 15 yrs ago and kept them in a box since. I decided to see if they would clear the disc brake brackets I swapped in later. If I get the car drive-able, I'll need tires so was happy to find the wheel cleared!
Then I drove the car around the block just because it will actually propel itself.... plus it's obnoxiously loud with only glass-packs.
A good Mike day.
ID:	622948   Click image for larger version
The Following 3 Users Say Thank You to Shiny For This Useful Post:
  #166
Old 11-07-2023, 12:31 PM
The window channels are in really good shape considering. Good solid metal all around with no rust holes. I just cleaned them up and treated the surface rust.
  #167
Old 11-07-2023, 01:08 PM
KS circutguy's Avatar
My 1969 SS Chevelle were super clean no rust.
Bought in at the dealer I worked at in Kingman Arizona,
was a trade in 1987 Cali car.
Frt and rear windows needed just gaskets.
Super easy to do.
  #168
Old 11-07-2023, 01:15 PM
Gaskets?
Old 11-07-2023, 02:02 PM
My 68 was a wet climate car. Was in Pensacola. I think the rear window channel held water and rusted through FAST.
No water, no rust! Living in this dry SW climate is a different world than places with 50% RH all the time. Add road or airborne salt and it's yet another level of aggression.
I do remember it was easy to pull the window and replace it. Butyl rope is what I recall...??
  #170
Old 11-07-2023, 03:09 PM
Thumbs up
Correct.
The Following User Says Thank You to KS circutguy For This Useful Post:
  #171
Old 11-08-2023, 07:35 PM
jhein's Avatar
jhein jhein is offline
Well, it looks like the driving season is over here so I gave her bath, topped off the tank with stabilized fuel and put her away for winter.
The Following 2 Users Say Thank You to jhein For This Useful Post:
  #172
Old 11-08-2023, 08:45 PM
FirebirdHank's Avatar
Drove the Solstice to the body shop to get the deer hit damage repaired. I should have it back just in time to put it up for the winter.
The Following User Says Thank You to FirebirdHank For This Useful Post:
  #173
Old 11-08-2023, 08:55 PM
tom s tom s is offline
Had to trouble shoot a 3310 Holley that was running over.Found the vent tube laying on top of the flote.Pounded back in where it belonged and life is good again.Tom
  #174
Old 11-09-2023, 08:37 AM
Dadspackard's Avatar
Dadspackard Dadspackard is offline
Dove it into work
The moon and planet are aligned
You all have a great day
Tom
The Following 8 Users Say Thank You to Dadspackard For This Useful Post:
  #175
Old 11-11-2023, 09:22 PM
Verdoro 68's Avatar
The window is closing on car shows for the season so my son and I headed down to the Goodguys show. Ended up parking next to a '73 SD with a super cool owner whose had it since '79
Got a lot of nice complements on my car, though I kind of had a captive audience because it was by the corn dog stand.
Smooth drive home on the freeway with the windows down. Trans leak is still there, but it seems to have lightened up a bit so maybe it was just overfilled.
ID:	623177   Click image for larger version
ID:	623178   Click image for larger version
Ken
'74 Ventura 350
'69 AMC Javelin SST
The Following 5 Users Say Thank You to Verdoro 68 For This Useful Post:
  #176
Old 11-11-2023, 09:55 PM
Wheels and tires on this yesterday
The Following 3 Users Say Thank You to 71GP76TA For This Useful Post:
  #177
Old 11-11-2023, 10:01 PM
Love those TTs
Old 11-14-2023, 07:55 PM
Verdoro 68's Avatar
Kinda cool - we made the photo recap from the Goodguys show. They had ample opportunity to take a pic because I drove around forever looking for a good spot.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #179
Old 11-14-2023, 08:14 PM
jhein's Avatar
^^ Very sharp looking car. Have you gotten enough of the bugs worked out to get into the throttle yet?
  #180
Old 11-14-2023, 08:34 PM
Torquewar's Avatar
Torquewar Torquewar is offline
Well season is done so time to start on an engine removal session, find out my issues. . I did get my Fiero out for maybe one of its last spins.
