Stan
Just curious what others have done or heard about using trans fluid in an engine to help mike understand why its not a good idea, amsoil explains its pretty good about lowering oils viscosity when used at 1-2qts... but completely filling an engine seems very counter productive and just asking for trouble. |
Yes, the Motors Crank rides on a film of oil between the Journals as well as the "041" Cam in my 428 ci HO Pontiac. Without this film of oil, the Motor will seize up. Now Motor oil that I use is 10-30 Viscosity, I think for argument's sake that ATF is some ware in that Viscosity range? Thus, there is not a problem there. Oil vs. Trans. fluid, Trans. Fluid has cleaners to keep debris out of the small areas that they have on the interior and exterior, like in the Valve Body. After building mine, that contains a smaller screen, before the Governer Valve to keep it clean so the Trans always shifts as it was designed to. Motor oil does not contain the same detergents as the Trans., because they don't need them. Sure, the small gap in the Bearings is completely different than the Bearings in an Automatic Transmission. Have you ever seen or built one to know the difference between an Engine Rod/Cam Bearings VS. an AT Trans. Bearing? The Motor Vehicle Bearing rides on a film of Motor oil and they will never touch as long as the oil pressure is present all the time. Now, the Trans. Bearings are spaced throughout the entire Unit and are designed like wheel Bearings; in that they ride on grease and the Needle Bearings spin as the Wheel rotates while in the AT. Trans. the Shaft Ends ride on ATF and the Needle Bearings spin. The Thrust Throughout the Trans. Shaft ends carry the load throughout the entire Trans. and end at the rear of the Case. From there the Thrust goes out the output Shaft to the rear of the Engine to the Thrust Bearing out front, to the Crank Shaft to Harmonic Balancer. This is why I think that my Vehicle Trans. accident that lifted the Trans. , drive train, moved forward and caused the shock wave forward and cracked the Harmonic Balancer, because there was no problem with the HB before the Trans. was lifted up, while moving forward, on a driveway made of asphalt, without pouring the proper cement first. The Transmission fluid is developed for Trans. only and should be used for that purpose. The Factory told us to use Oil in the Motor, so that is what I do. The Trans. Mechanic that drove his Vehicle for 300,000 miles doing a test, made out well. I don't think that I would ever use his idea, I follow the factory experts all the time. As far as flushing out my Engines that I own, I can and will experiment. For the past 10 years I have been experimenting with keeping the Engine Temps. down. I had a 1981 Camaro Z-28 that I had to stop at the Bridge as a Boat went by to open the Hood to let the under-Hood Heat out. I had add-on AC on that Vehicle, I never did figure out why that was necessary, now I think that is why the factory never installed AC on it to begin with. Of course, the Car came with AC, but the factory knew what add-ons they needed to add for it to work, I didn't. So, Trans. fluid is slippery, uses detergents and is approx. 10 Viscosity, how could ATF hurt any Motor when flushing for 1/2-hour existing debris? Compared to Amsoil, Seafoam or any bodies flush solution and their perspective ingredients that do the same for more money? |
I ran ATF in my Gear Vendors unit as per Factory spec., I tried Synthetic 90 wt lube, but it was too thick and clogged the screen in the unit that they don't show in their little book, that they make you pay for. I found the book on the internet for free.
| Closed Thread |
