Old 09-25-2023, 02:25 PM
i4abuygto's Avatar
i4abuygto i4abuygto is offline
Default 79 Trans Am AC system restore stock? or aftermarket?
I need help with recommendations to get the AC working in my 79 403 TA.
I am putting my 79 TA interior back together and I want to get the AC system back working. I have the heater box installed with a new heater core, fan, resistor, and relay. I have an existing evaporator coil that has been flushed and holds pressure that I would like to use if possible. Can I use anything of what I have existing?
Attached is the photo of what I have- nothing forward of the dryer as shown in the photo.
I know I need the compressor and condenser and all the plumbing from the condenser back to the firewall.
I have a good wiring harness from the dash controller to the resistor but nothing forward of that to the compressor. The high-power fan feed from the alternator is working and the blower Fan blows well on all speeds. The vacuum gates in the under-dash ducting system have been fixed and work with the dash controller.
I dont have any of the compressor mounting brackets for the 403.
What is the best way to approach this to get the AC working for the least amount of cost?
Would I likely be able to find some used rebuildable components or is an aftermarket system my best option?
Name:	AC existing under hood.jpg
Old 09-25-2023, 02:56 PM
I was not impressed by the Vintage Air setup.
The Following 3 Users Say Thank You to Scarebird For This Useful Post:
Old 09-25-2023, 03:22 PM
bhill86's Avatar
bhill86 bhill86 is offline
I installed a Classic Auto Air system in my 77 400 being in a similar situation as you. I was missing all components beyond the evaporator core but flushed mine, it had no holes and everything under the dash was present and worked well.
I did not want to use a vintage air system (though people seem to like it) because I had all of the above mentioned items in working order already. I also don’t like the idea of tube ducting vs the factory stuff not to mention the hassle of replacing everything. I don’t believe at the time VA offered a retrofit kit for an AC car but you might be able to buy the components individually.
That said, I opted for the CAA Kit. It included the compressor (modern sanden), all of the lines, the accumulator/drier and a parallel flow condenser. It’s also 134a and it ran me around $1200 I think. Installation was fairly easy but I have some gripes in the fit and finish department. The compressor bracket is ugly and unpainted. I still need to remove and paint mine. The design of the bracket isn’t ideal either. I had really bad belt flutter initially. That seems to have corrected itself after some time. I also made a small pedestal bracket to add some rigidity to the compressor. I’m not sure how much that helped or didn’t.
The hard lines they provided didn’t fit the best either. I’d have to go back to my TAC post if it’s still there to recall exactly what the issues were but I remember one hard line was too long, one hose was almost too short.
Lastly, the charge was a little tricky to get right. It’s possible a competent AC shop could perfect it but I opted to charge myself since I was getting quotes of $200 to fill the system. It does blow cold but I think there is room for improvement. One thing I would’ve don’t differently was install a variable orifice tube instead of a fixed.
I should note that Vintage air sells a different compressor bracket that looks like it would work better that could be used with the CAA setup I believe. I planned to try that but opted not to since my belt flutter seemed to disappear.
CAA’s customer service was also severely lacking but this was around COVID times or just after the peak so I’ll make an assumption that is part of the cause and hopefully things have gotten better.
Hope this provides some insight.
1977 Trans Am 400/4speed (swap)
Brian
The Following User Says Thank You to bhill86 For This Useful Post:
Old 09-25-2023, 04:28 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
Since the under-dash parts and evap are the most complex sub-assembly of all, I'd use that and piece together the rest of the parts underhood.
To avoid the aftermarket, kludgy compressor/mount, I'd use a junkyard Olds compressor mount for an A6 and get a new A6 from Alma Products who now has the GM tooling for that compressor. Make sure the compressor has PAG oil in it if going R-134a. I'd also get a parallel-flow condenser.
Yeah, the A6 is heavier than a Sanden, etc, but it'll last forever and look "correct", as well as have good belt alignment.
The Following User Says Thank You to hgerhardt For This Useful Post:
Old 09-25-2023, 06:05 PM
i4abuygto's Avatar
On the Classic Auto Air website I could only find the latest GM model for a Camaro complete system for a 1978. The firebird years I found were for the late 60s only. - is there a link to the CAA kit?
Thank you.
Old 09-25-2023, 09:44 PM
bhill86's Avatar
Sorry, here…. https://www.originalair.com/engine-compartment-gm
It’s under original air group which is a part of classic auto air.
Brian
Old 09-26-2023, 04:17 PM
ta6point6's Avatar
I used original air as well and thought fit was good but the ac mounting bracket was not painted( as mentioned) so do that first. With the sanden compressor I did not need to add a idle speed motor to carb. The sanden compressor does not drag down motor like stock compressors. I have a different opinion on OE compressors, they leak and fail at a higher rate then sanden compressors. I used my original evaporator just flushed it and everything is working fine. My biggest complaint is the OE fan motor does not create enough flow compared to modern vehicles. On hot days fan motor is in high the entire time
I started out with an original rebuilt A6 compressor from Napa and went through 2 in 2 years. Here is the kit I used
https://www.originalair.com/77-81-fi...ile-v8-stage-1
going bandit-Reynolds style
The Following User Says Thank You to ta6point6 For This Useful Post:
Old 09-26-2023, 04:44 PM
bhill86's Avatar
I agree, my fan stays on high, likely max (recirculate), almost indefinitely on hot days. I’ve read about n this forum of people using a different fan that blows more air but I don’t think I ever saw a definitive solution to that.
Brian
Old 09-26-2023, 05:50 PM
hgerhardt's Avatar
Originally Posted by ta6point6 View Post
.........I started out with an original rebuilt A6 compressor from Napa and went through 2 in 2 years. ...............
And there's the problem. I said get a NEW one from Alma Products, who own the original GM tooling. They are not cheap, however: https://coldhose.com/products/new-al...44110452031743
Also note that these A6's ship with mineral oil. To use with R-134a, you need to drain that and replace with PAG...did you happen to check that with your Napa units, or were you running R-12?
And as far as "more" HP required to rotate the A6 vs a Sanden--they're both axial piston compressors with a swash plate to drive the pistons--so if the A6 needs more HP, then it has a larger displacement and pumps more refrigerant. It's the 455 of the A/C compressor world!
The only reason I push the A6 is because the Sanden compressor with all its universal mounting ears and bracket is so ugly. It screams aftermarket.
Best would be if someone were to design a NICE bracket to hold a modern Denso compressor. That would be ideal.
The Following 3 Users Say Thank You to hgerhardt For This Useful Post:
Old 09-27-2023, 12:43 AM
i4abuygto's Avatar
Thanks guys - great info here.
With the systems in the above links - will all components to make the system work be included in the kit from the evaporator coil forward to the condenser?
I will need to get the harness that goes forward to the compressor from the existing harness that connects to the harness coming through the firewall. Will all the components with the new system work with the stock wiring harness?
Old 09-27-2023, 03:14 PM
ta6point6's Avatar
~I drained oil and used pag instead as I was using R-134. A new unit looks interesting but I imagine they still leak out the front of seal. That is how these A6 lubricated the seal. So that is why you see many A6 equipped cars with that oil stain on top of hood.~
~I agree with you there the Sanden does look out of place under the hood but changing spark plugs is a lot easier with a sanden.~
There also has to be a weight savings with sanden over A6 as well
Old 09-27-2023, 06:45 PM
bhill86's Avatar
Without rereading the stage 3 kit description, my stage 2 kit includes everything except the thermal switch if I remember correctly. (Different than the low pressure switch which is included). The wiring was simple. One wire (hot) from the factory harness to the compressor which is grounded through the bracket/engine. Now, since my AC stuff was all gone when I bought the car I could be wrong on this but if I remember right the factory setup included a two terminal plug for the compressor to ground the compressor which split off to a ring terminal I think went to the compressor bracket. I think that also provides ground for the blower fan. Someone before me reattached that ground elsewhere on my car to maintain the blower fan. So you’ll have to decide how you want to deal with that ground and powering the compressor.
Your two options. Would be cut the factory plug off, ground the black wire somewhere and run the hot to the new compressor. Or, I don’t like altering things permanently if I can help it so I’d probably make a jumper to plug into the factory plug then run the “new” wire(s) wherever you want.
Brian
Old 11-17-2023, 09:51 AM
bsblguy bsblguy is offline
I used the original air kit on a '78 and '79 and it works very well. Evap, condenser, compressor, all hoses. Everything needed. I do not like their compressor mounting bracket so I bought a vintage air bracket that looks much better. I did use a vintage air conversion kit on a '77 and works much better than factory air but my foot hits the vent duct by the gas pedal. My only complaint.
The Following User Says Thank You to bsblguy For This Useful Post:
Old 11-17-2023, 04:05 PM
The little rotary compressor in my 81 actually works pretty decent and easier to change plugs than the A6 that was on the 78!
Old 11-17-2023, 04:48 PM
Trevor78 Trevor78 is offline
Is that a feature of the conversion, to have a floor ducting there? Or stock? Mine doesn't use any of that those.
I like my stock setup, the whole reason I went that was way for original appearance and at the time there was limited aftermarket anyway and still largely universal. I also started with nothing whereas sometimes that's enough of a reason to get new everything. Mine can still be adjusted down enough to freeze and still cycle so it certainly has the cooling capability, it also has the weight and perhaps limited economy. I doubled the engine HP so I'm not too worried about that! If the compressor ever plays up, they are hugely common and standard to just put another one on, not always the case with some aftermarket setups that come and go, Sanden is fairly safe and common. Comes down to the guy and what he wants and access to either setup.
The Following User Says Thank You to Trevor78 For This Useful Post:
Old 11-18-2023, 09:08 AM
the vintage air unit has flexible hoses run to all the vents. the drivers side vent comes out of the plenum right by the gas pedal, I have it ty wrapped as far away as possible but still hit it with my foot at times. the '79 I am doing right now I found all the pieces I was missing and putting it back to original the than the compressor.
The Following 2 Users Say Thank You to bsblguy For This Useful Post:
Old 01-26-2025, 05:49 PM
i4abuygto's Avatar
Thanks all for your previous help
Needing updated info as I had to take a year off the TA and I am getting ready to put engine bay together and having difficulty sourcing the AC parts.
Same as before looking for all needed components forward of the evaporator that I flushed and is good to go with rebuilt heater box and new heater core.
Classic Auto Air is currently not producing kits and I can’t find individual components on their site
Unfortunately our host site is hard to find parts also
Seems no one has complete only under hood kit forward of the evaporator
In sourcing parts it seems compressor, condenser and dryer should be easy to find but the hoses valves and required tubing is unknown by me as I have nothing to compare to.
Seems most hose kits are universal and I may need to source correct fittings to be crimped on to proper unknown lengths.
I believe the Sanden 508 compressor is a good choice but I will need to add and source mounting hardware to mount for the Olds 403
I have been looking for a list or schematic for all parts needed and the orings and seals necessary
Considering if all is worth the effort
Any additional thoughts or advice will be helpful.
Thank you
Old 01-27-2025, 09:31 AM
bhill86's Avatar
All I can offer is, if classic auto air were to sell kits again or even just parts, I’d avoid them. I have the kit they used to offer and I’m unimpressed.
That said, I thought vintage air offered a system that was for factory AC cars and covered the parts forward of the evaporator. I could be wrong.
Brian
Old 01-27-2025, 01:16 PM
HoovDaddy's Avatar
HoovDaddy HoovDaddy is offline
When I install the Vintage Air units, I keep a few feet of the AMES flexible hose on hand. You can flatten it for clearance. The VA hose doesn't flatten.
https://forums.maxperformanceinc.com/forums/attachment.php?attachmentid=585876&stc=1&d=1646964  761[SIGPIC]
The Following User Says Thank You to HoovDaddy For This Useful Post:
Old 01-28-2025, 09:43 AM
i4abuygto's Avatar
Thanks for comments
I have been looking for under hood AC kits with no luck.
I acquired all underdash ducting and refurbished the underdash air box so I will be using stock ducting and controls
I plan on updating to 134a so I need the proper valving for updates to the stock system
Any ideas to source parts would be helpful
