https://www.tpocr.com/pontiacbp8.html
24267 - GTO convertible 12D build code 12 month, 4th week (1967) 223 Black interior T exterior color Primavera Beige 2 top color Black PON Pontiac Michigan build Not sure what the other stuff top right is... |
| The Following User Says Thank You to Scarebird For This Useful Post: | ||
The 2 center/Siamese exhaust ports have large raised numerals - should be 1 and 6 (16). Block code is on passenger side - front flat face of block - near where cylinder head meets the block. Should be stamped stamped WT or WS Partial VIN on block is on passenger side - lower front block flat face - alongside the timing cover. Low down near where oil pan meets the block vicinity. Should be stamped 28Pxxxxxx The date code on the block - will look just like the one you found on the head. Located around where the distributor goes inside the block. Date on (factory) intake is next to thermostat housing. Good Luck and Congrats on your new GTO Is it still Primavera color ? |
