Old 11-30-2023, 08:46 AM
Cliff R's Avatar
Cliff R Cliff R is offline
I made the OP aware of the MAIN ISSUES with this engine about 400-500 posts ago. It went on deaf ears. Instead we are searching the Internet and various other sources to the brink of extinction to find another potential cause when the OBVIOUS problems were right in your face a couple of times and easy repairs made. You can Google all you want, and go all over these Forums and get BUTT LOADS of input on your issues, you can even wear out a few resident "experts" here to a point where they will tell you piston offset the wrong direction and rods backwards on the cranks throws is OK, but as with everything else on this planet it is NOT possible to get past the basic laws of physics with these things.
Somewhere in the history of this engine it got FUBAR'd. The problems from that deal are finally manifesting themselves to where the correct repairs are REQUIRED. Any other course of action is just wasted time/funds and additional "drama" on the thread at this point.
Getting mad and breaking up cinder blocks with your bare hands woln't help, neither will doing hand stands on your fingertips. If I were Mike I'd smoke a hog, get a keg of beer and invite over ALL your friends and even folks you don't know. If I lived closer I'd be the first one in line to help out and get some free smoked pork belly.
Have the car up on cinder blocks, hood off, and before you let everyone get drunker than monkeys have them help you remove the engine again and pull it down to parade rest. Once all the pistons are out locate the chamfered side of the rods and "notch" on the pistons. Put them all back in the right bores with both the rods and pistons facing the right direction. No honing needed, no new rings, etc. You "knurled" the valve guides for crying out loud so throwing more money at rings and such isn't going to be worth the additional expense.
If the rings don't seal up well just get some Comet cleaner and drizzle some into the carb/intake with it running on fast idle at 1500rpm's or so. That'll either get them to "bite" into the bores or give it a miserable death. Either way you'll be a LOT further ahead than you are at this point......IMHO.......Cliff Out
Old 11-30-2023, 12:01 PM
Nobuddy Nobuddy is offline
BonAmi cleanser, not Comet..
Old 11-30-2023, 12:30 PM
Stan Weiss's Avatar
Cliff,
Since I like many here want to learn. Just what laws of physics does installing the piston with the offset reversed break?
Stan
Pontiac Pump Gas List
Old 11-30-2023, 12:55 PM
JSchmitz's Avatar
JSchmitz JSchmitz is online now
Cliff,
Stan
I would say that the piston installation didn't break any laws of physics. They are merely complying with the laws. The laws dictate that the pressures and angles act on the pistons in a certain manner. The engineers, that designed the pistons, understood this better than anyone in this discussion. They designed an offset to minimize unwanted movements of the pistons and maximize efficiency. Choosing to go against this is most likely causing the noises in this engine. But he wants to blame it on the moon, stars, and everything else. I say, GOOD LUCK!
Old 11-30-2023, 01:04 PM
Stan Weiss's Avatar
How many times does it need to be said the engineers only put that offset there so that people on a cold stop wouldn't hear piston slap. You do understand that with that offset the piston and crank journal are not at TDC at the same time?
Stan
Old 11-30-2023, 01:23 PM
JSchmitz's Avatar
Stan
Yes I think I understand it pretty well. Piston slap is bad. It causing ring wear, sounds bad, etc. The offset is there help eliminate this. Are you saying that his knock isn't from improper assembly?
I know that my dad owned a 1969 Chevy pickup. He had the engine rebuilt. The guy put the pistons in backward. Guess what, it had a strange knock.
Old 11-30-2023, 01:34 PM
Stan Weiss's Avatar
So does this mean you will never run an after market piston that doesn't have any offset?
Stan
Old 11-30-2023, 01:43 PM
Shiny Shiny is offline
As a spectator (or maybe in this case an observer of a spectacle), gtofreek's explanation of offset was the most helpful for me:
https://forums.maxperformanceinc.com...6&postcount=24
Old 11-30-2023, 01:44 PM
JSchmitz's Avatar
Stan
No, I'll order custom pistons with the offset. Then I'll install the backwards to break the laws of physics.
Old 11-30-2023, 02:59 PM
Stan Weiss's Avatar
If that is the case then why does ever Pontiac engine from a 326 ci to a 455 ci having different bore size and strokes all had the same 0.063" offset? (Based on the information I have)
Stan
Old 11-30-2023, 03:10 PM
JSchmitz's Avatar
Stan
That's a good question. Maybe they chose a standard offset that minimized piston rocking and thrust loads on the piston. Maybe it's the maximum that they could justify. Maybe it just works well for all. Maybe the guy was mental. LOL
Old 11-30-2023, 04:39 PM
242177P's Avatar
242177P 242177P is offline
96,946 GTOs built in '66. Eight pistons each... 775,568.
Pistons were mass produced, fixed offset makes sense.
455SD was already receiving extra attention because of
the rods, 326 just needed a slug to fill a hole.
Old 11-30-2023, 07:42 PM
Something related to piston noise is being overlooked here I think.
Prior to the the first 400 motor in 67 Pontiac pistons where fully round and in my mind other the the issue of having the rods facing the wrong way on the crank if you had a piston in a motor the wrong way I don’t think you would hear much added noise when cold.
Now let’s look at the 350s, 400s, 428s and the 455s with there inventive usage of a Cam ground piston.
Now if you reversed these pistons, yes to me you would be in for a good amount of cold slap noise, and along with the noise comes ware.
Just some food for thought here.
Old 12-01-2023, 04:48 AM
Kenth's Avatar
Kenth Kenth is offline
This is from the 1966 Tempest Shop Manual:
Name:	1966 389 Piston offset.JPG
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 11-30-2023, 06:23 PM
MatthewKlein MatthewKlein is offline
Stan
Things have progressed to the point I prefer this thread to be more comedy oriented and less well thought information
In the beginning I had genuine concern but it has evaporated
Old 12-02-2023, 08:37 PM
Yes, I think I understand it pretty well. Piston slap is bad. It causes ring wear, sounds bad, etc. The offset is their help eliminate this. Are you saying that his knock isn't from improper assembly?
[QUOTE=JSchmitz;6469943] I would say that the piston installation didn't break any laws of physics. They are merely complying with the laws. The laws dictate that the pressures and angles act on the pistons in a certain manner. The engineers that designed the pistons understood this better than anyone in this discussion. They designed an offset to minimize unwanted movements of the pistons and maximize efficiency. Choosing to go against this is most likely causing the noises in this engine.
Mikes Reply:
We are putting the Trans. back to the Engine now, I will let you know when we run the Motor. I am not holding my breath though, that this noise has disappeared. Perhaps the noise was always there, I just did not hear it until the Heads were remanufactured, causing new Harmonics resonance within this Engine.
The Pistons are backwards except for #2, Why. The racers reversed the Pistons for a reason, we know why.
The #6 Rod is backward, and maybe more. Not good.
The Pictures in the 1967 Pontiac service Manual are confusing at best.
People made mistakes rebuilding these engines over the years and it seems that I have one of them.
Let's see what happens when we get the Vehicle running again.
I bought the Stethoscope, with the long rod on the end, we can now listen better, to isolate said noise, if it is still there.
Mike out, thank you all for your help.
Also, to find out that my Pistons are closer to TDC because they are installed backwards, is ironic since I spent all that time with the degree wheel just to find true TDC.
Closed Thread
