Old 11-29-2023, 03:37 PM
indetrucks's Avatar
indetrucks indetrucks is offline
Question New to me 68 GTO Convertible - Need some help decoding a Body Tag
It's been a while since I last posted here as I sold my 67 GTO a while back.
That being said, I picked up a 68 4spd Convertible w/ Hood tach.
Having a hard time decoding it as I'm somewhat "on the spectrum"
Any experts out there able ot help? How can I be sure this is a factory 4speed car?
Thanks!
Old 11-29-2023, 03:47 PM
https://www.tpocr.com/pontiacbp8.html
24267 - GTO convertible
12D build code 12 month, 4th week (1967)
223 Black interior
T exterior color Primavera Beige
2 top color Black
PON Pontiac Michigan build
Not sure what the other stuff top right is...
Old 11-29-2023, 04:24 PM
indetrucks's Avatar
223 Black interior
2 top color Black
Thank you! I was able to get a code off the heads. Does this L087 number coinside with the late 67 build date you posted? Working on the getting the engine block #'s
Old 11-29-2023, 04:53 PM
Thanks!
Obtaining a copy of the original invoice from Pontiac Historical Services would note the original options on your '68 GTO convert. Whether equipped w a factory 3spd Dearborn trans or a 4 spd Muncie, or as an original T400 car that has been converted, it will be hard to discern if the transmission has been changed over the years.
BtW, your Dec 8th '67 dated heads "fit" well with 3rd week of Dec body build out of Pontiac home plant. A few hints to original build can be picked up on, esp if the engine is non original. Quickly looking over the car, a manual trans '68 GTO will have the manual trans neutral safety switch mounted above the clutch pedal. Getting under the car, I would look for the presence of the stamped steel braces that mount from the inboard of the front attachment of lower control arm & continue diagonally to the large frame crossmember. Those braces will attach behind the nuts that tighten the bolts that pass through the upper control arm bushings on top of the R/E center housing.
'68 GTO (& Firebird) manual trans Hurst shifters had a boot shaped "kicker" to the reverse lever. This kicker profile on the reverse lever depressed the side cover mounted reverse light switch when the factory installed Hurst shifter was put in reverse. On '69 model Pontiacs with manual transmissions, the backup light function went to a small opaque plastic switch mounted on down low on top of the column.
Old 11-29-2023, 06:09 PM
Tim john Tim john is offline
As mentioned, the 68 HURST four speed shifter was a one year only shifter, the reverse light mounting bracket is part of the shifter body.
Tim john---
Old 11-29-2023, 08:57 PM
OG68 OG68 is offline
Gotta call you on this one OPH.
68 manual shift models did not have a neutral start switch above the clutch. That started in 69.
A jumper was used across the NSS plug terminals.
Old 11-30-2023, 03:34 PM
You are spot on Ed. Remembrances of checking out & parting too many '69 & later stick cars. Though have owned several '68's, have pulled even more '68 Pontiac A-body floor shift columns & no lower legs on those, the lower leg being the lever that would be needed to connect to the back drive linkage, which was a '69+ thing on manual trans cars.
Appreciate you sharing your '68's pics, interesting that GM Packard Electric was including a connector & a jumper in the dash harness for the NSS provision. Btw, how late in production was your '68 GTO built?
Old 11-30-2023, 04:57 PM
Thanks OPH. It's a Fremont 05A.
Mom's car, it was bought new in late May '68
Aside from a timing gear and wheels, it was never touched mechanically until I replaced the engine in the mid eighties. Kept the original though and it's still all numbers matching.
Car was taken apart 20 years ago and I started the restoration around 2017 when it was just a bare shell with lots of boxes.
Thanks to you and others on this forum to refresh my memory of how everything goes back together, I hope to have it moving on its own power by late spring next year.
Old 11-30-2023, 11:17 PM
The cylinder head ID is further below where you found the date code.
The 2 center/Siamese exhaust ports have large raised numerals - should be 1 and 6 (16).
Block code is on passenger side - front flat face of block - near where cylinder head meets the block.
Should be stamped stamped WT or WS
Partial VIN on block is on passenger side - lower front block flat face - alongside the timing cover.
Low down near where oil pan meets the block vicinity.
Should be stamped 28Pxxxxxx
The date code on the block - will look just like the one you found on the head.
Located around where the distributor goes inside the block.
Date on (factory) intake is next to thermostat housing.
Good Luck and Congrats on your new GTO
Is it still Primavera color ?
Old 12-01-2023, 04:27 AM
Drag Star Le Mans's Avatar
Any chance you could show a pic of the car?
DragStarLeMans
Old 12-14-2023, 10:51 PM
indetrucks's Avatar
I will be picking it up on Sat. I will post up!
Yes, still the factory color, although repainted
It had a Hurt shifter in it, I am now curious if it came with that option. Thinking first thing I do is order a PHS.
Old 12-16-2023, 08:16 PM
indetrucks's Avatar
Just got her home today. Tip went down fine, but now won't go up. No noises, nothing. Stuck down
ID:	625098   Click image for larger version
ID:	625099   Click image for larger version
ID:	625100   Click image for larger version
Old 12-16-2023, 09:32 PM
indetrucks's Avatar
Great news, top was just the fuse. What are the odds...
ID:	625118   Click image for larger version
ID:	625119   Click image for larger version
ID:	625120   Click image for larger version
Old 12-17-2023, 06:59 PM
That's a beauty! I have news for you though...that is not Primavera Beige. Color change for a beige car is understandable.
Back when I first moved to Atlanta 1979-80, there was lady in the city who had to be in her late 60s that had a primavera beige 68 convertible in absolutely pristine condition. I used to see her driving down Peachtree Street with the top down and a head scarf. Had a vanity plate that said MY GTO . It's the only Primavera GTO I've ever seen.
Old 12-17-2023, 08:07 PM
Looks more like April Gold - still a nice color.
The beige? uhhh.......
Old 12-18-2023, 09:46 AM
indetrucks's Avatar
I htought hte same, it seems to have a bit more green in it.
Looking at April Gold, I think you're right! Pulling up other April gold GTO's has me convinced, thanks! This should help determin the touch up paint I need.
Old 12-18-2023, 10:19 AM
Stuart's Avatar
Stuart Stuart is offline
Correct me if I'm wrong but it appears the paint code on the trim tag is RR? Looking at the color chip chart for 1968, R is Solar Red? https://www.autocolorlibrary.com/pag...8-Pontiac.html
Old 12-18-2023, 11:30 AM
indetrucks's Avatar
BtW, your Dec 8th '67 dated heads "fit" well with 3rd week of Dec body build out of Pontiac home plant. .
I was able to rub some paint off the block. Doesn't seem to be the OG 68 powerplant based on these pics correct?
ID:	625194   Click image for larger version
Old 12-18-2023, 11:32 AM
indetrucks's Avatar
I'm seeing T-2 as the color, where are you seeing the RR?
Old 12-18-2023, 11:51 AM
indetrucks's Avatar
Ok, clearly Im new here... but I was looking in the wrong place for the block VIN. Found it and it matches!!!!!
I'm over the moon right now!
Bonus, spare tire is the OG redline! I just ordered the PHS docs
ID:	625197   Click image for larger version
