If it’s that sensitive my guess is you got something else going on. Really I ran mine with no issue on 93 octane, for years. Here’s a possibility and I’ve seen this a more then a few times. Some times your running what you think is total timing 32-36 degrees, but if there’s issues with the distributor, for example you put a time light on it and say at 1500 rpms. Time in while it says 32-36 degrees But ! You bring it up to say 3000-3500 and it keeps advancing, I’ve seen the advance up to 50 degrees. But you don’t know if that’s happening say your first instinct is kicking it back 10 degrees then it feels sluggish. Just something did you want to check out and make sure that it’s not advancing. Honestly I never had any issues with my 69 Grand Prix 428. Running on 93 octane. Just a thought something you might want to check out.
| The Following User Says Thank You to Gach For This Useful Post: | ||
What do you mean by the original oh 067 ? Do you know what number the heads are on the motor. Another question what octane pump gas fuel was you running
In the past, I put a timing light on it (I have a dial back light, so I can check the timing throughout the range) and it was in spec. During an inspection it was obvious that there weren't any missing bushings or pins in the distributor. Springs were stock, weights were stock. Vacuum can was fine and functioning. Could not find any problems with the advance mechanism at the time. Checked the balancer with a piston stop, and the balancer had not slipped (at that time). I don't now have faith that the elastomer is serviceable, and I expect to change the balancer as part of getting the engine back to running and reliable service. Again, it ran well with a blend of race gas and 93 octane, but sounded like ball bearings in a tin can with just the 93 at 9-10 degrees of timing. To drive it on 93, I had to retard the timing by 12 degrees from stock. Not fun. |
Wow you’ve done your home work. Here’s a possibility the automatic cams usually are in at 108-109. Being its a 4 speed car ( sorry can’t remember what 4 speed cams are 112 ? ) that could be part of the issue. I mean you could try one of the new generation pump gas cans more suited for a four-speed. The compression part, I mean hoping those 16’s are 72 cc. So ok my 68 GTO 4 speed 400 had number 16 heads. Those motors rated at 10.75 compression.
It sounds like you’re going to have the heads off anyway so lets see what those 16’s check put ass cc wise. I may be wrong but 16’s on a 400 rated at 10.75 compression vs being on a 428 may be more true 10.75 then on a 400. Anyway I would definitely go with a cam change and definitely see what cc those heads are then decided from there what head gaskets to go with. |
Or you could spring for a set of aluminum D-ports and a cam more suited for a 4 speed, definitely aluminum head would end compression issues and definitely motor with right cam will definitely make a ton more power. I would definitely not consider 080 head gasket. Otherwise you’ll be chasing your tail.
| The Following User Says Thank You to 1969GPSJ For This Useful Post: | ||
Ok, elaborate on the comment ' I put a timing light on it (I have a dial back light, so I can check the timing throughout the range) and it was in spec. '
What's 'in spec'? What's your initial, total, and timing at 3000 rpm? And how much is the can adding? When/where does it ping? Rolling of a dead stop, under load at 1800-2800, or above 3000? If it's not been apart, the pistons are def in the hole, how much is the question. If you haven't had the heads off, you don't know what the heads CC are. Rated static CRs are exaggerated. 'sounded like ball bearings in a tin can with just the 93 at 9-10 degrees of timing' . You're obviously talking about initial, which doesn't mean jack. Definitely need more (accurate) info to make any type of recommendation. If you're willing to change gaskets, you can pull the heads and determine exactly what you deck height is and head volume. Without that basic info, I don't think anyone can give any valid recommendation. Now, just to say, most shops finish deck and head surfaces to 50 RA or better as SOP, which supports an aluminum head/iron block combo with MLS type gaskets. If it's iron/iron, it's a lot more forgiving, and you could possibly get away with an MLS gasket. Or, you could try 'smoothing' the surface some if you feel brave and lucky. Another option is you could stack composite gaskets, that too would be if you feel brave or lucky. Neither would be advisable with a performance build, but if you're just trying to 'get away with it' for a short period of time, you could take a shot at it. This could all be moot if whatever cam in there now is compromised or there are other factors that could be contributing, like heavy carbon build up. You could go through the trouble and try to get 'lucky', but you may end up having it fail and be forced to rebuild. Can't cheat physics, might be better to just ride it out until you can go through and properly rebuild. .
| The Following 2 Users Say Thank You to HWYSTR455 For This Useful Post: | ||
It has been over 15 years since this engine has been run, and even longer since I drove the vehicle it was in on a regular basis. So in spec would mean no more that 30-36 (ish) degrees total timing. It did ping on 93 with the initial set at 9-12 degrees from a start through the operating range. It didn't stop with more throttle, and it still pinged at part and light throttle. Vacuum can attached made it worse, but it did not go away with it disconnected. Because of the ping/knock, this engine spent most of it's time running on 93 octane fuel and seriously retarded timing to avoid the ping/knock. The only time (no pun intended) it did not ping when set at 9-12 initial was when I would run it with (about) a half tank of turbo blue mixed with a half tank of 93 octane unleaded. So in this case the difference in how the engine behaved on 93 octane with 9-12 degrees of initial vs having the initial retarded by 14 degrees does mean "jack". This isn't my first rodeo, I have had my hands on dozens of '67 through '70 Poncho cylinder heads over the years, and have had about 6 sets of my own on a variety of cars. I used to do some flow bench work and porting 30 years ago. I have cc'd many of the big valve 400 and 428 heads, and most were nominally 72 ccs (give or take a few cc's in the 68-74 cc range). As far as the engine's current state, I did stick a bore scope in every bore recently to assess cylinder wall, head and piston condition. The pistons had the typical non-428 HO piston dish, intended to yield a 10.5:1 compression ratio with the 16 casting head. There was light, wet carbon build up ("wet" because I have fogged the engine several times over while it was in storage the past 15 years) , typical of a 428 running a little rich, but it was not excessive, and the piston tops and chamber all showed significant areas that were base metal without carbon deposits - so relatively clean. There wasn't any obvious valve, piston or chamber damage, even in # 7 and #8. I didn't take pictures because I was not anticipating any discussion about the condition of the engine. It is fairly apparent that none of the previous owners had done anything internal - I changed some gaskets (intake, valve covers, timing cover and oil pan) and probably replaced the timing gear - but didn't do a cam change and I don't think I even removed the valley pan when I first put this engine in my car about 35 years ago. Darn thing still has the short water pump ( but for not much longer). Gach suggested that a more aggressive cam may help overall. The engine will be going back on the road with a Edelbrock Pro Flow IV, so the fuel/air and spark will be managed better than in the past. It looks like a cam change (which was in the works anyway) may be the best solution for addressing the ping/knock issue, but still nobody has really presented a good case about why a thicker head gasket would be a good or bad idea - other than the issues about cylinder head and deck surface quality, which has nothing to do with the thickness of the gasket and what the pros and cons are for a thicker head gasket. Last edited by 1969GPSJ; 12-03-2023 at 12:06 AM. |
The ticker head gasket, issue (quench) what I’m saying may not be super accurate but it will give you the picture of why its not a good idea. The quench area is or shouldn’t be no more the say .040 to much quench will cause detonation un-burn fuel, so a .080 gasket will incase that. May not solve the problem at all. Especially say your piston are down in the hole say .010 from The factory. Thats why guys go for zero deck, and run say .032 gasket. To allow for piston to head clearance
| The Following 2 Users Say Thank You to Gach For This Useful Post: | ||
428 HOs didn't have special pistons.
| The Following User Says Thank You to 242177P For This Useful Post: | ||
Pontiac greatly over rated their compressions on all their engines. If I were you, if your interested in switching heads, get the 85cc KRE d ports. The compression would be in the upper 8s then, and you could run what ever gas you wanted, with the engine as it is now.
Guys have came on here with tuning issues with aluminum heads and a small cam with not much over 10:1 compression. Aluminum heads won’t help much. The guys running 11:1 have the induction, cam, and exhaust to move the highest volumetric efficiencies to higher RPMs, spreading the compression out. The thicker head gaskets make the quench in a range were it will ping worse even though the compression is dropped. That bad range starts around .060” quench, and continues to around .1” quench. After .1” it seems to get better as it increases. But it is no substitute for a good quench. The .060” gaskets generally put the quench in that troublesome range. If your going to drop the compression with head gaskets you have lower it extra, probably about 9:1. If you switch cams it changes everything. A cam like an 068 with 16s, would likely run on compatible octane to 72cc aluminum heads and the 066. Last edited by Jay S; 12-03-2023 at 11:20 AM. |
| The Following 2 Users Say Thank You to Jay S For This Useful Post: | ||
I’ve tried to water ejection two different applications, don’t waste your money. Or should I say flip a coin.
I have considered using the 9785744 (RAIII 4 speed cam) or 9794041 cams for both more power, but lower dynamic compression. I still think that thicker head gaskets would help too. You can hear part of knock, but not necessarily detonation, and I don't want to go down that path with a stock engine and cast pistons. |
