Old 12-21-2023, 04:40 PM
bill ryder's Avatar
bill ryder bill ryder is offline
I believe you need to switch carbs with the rod and plunger. On the rear carb, the plunger can, and did, separate from the rod at WOT and catch on the intake riser. NOT GOOD!! With the plunger on the rear carb, it is to long to catch and will just slide across the riser. Hope this makes sense!!!
When you are checking it out, you can separate the two and let them drop down at simulated WOT. You will see which way their might be a problem.
"Bill"!
Old 12-22-2023, 05:18 PM
Dick Boneske's Avatar
"Bill"!
Sorry, Bill, but the way he has the linkage set up is the correct way. The female plunger will not hang up if uncoupled if it is on the rear carb.
Yes, this is the mechanical linkage kit released in 1964 to satisfy the many Tri-Power owners upset at how badly the vacuum linkage performed, especially during a drag race (or acceleration trial)!
Name:	'64 GTO Linkage 017.jpg
BONESTOCK GOATS
'99 Bonneville SE Sedan
The Following User Says Thank You to Dick Boneske For This Useful Post:
Old 12-22-2023, 07:59 PM
bill ryder's Avatar
Hello Dick. Thanks for the correction. Do not want to mislead anyone!!!!!
"Bill"!
