Old 12-19-2023, 03:49 AM
dataway's Avatar
dataway dataway is offline
Is it just me ... or are the results getting better?
At least they don't have three or five headlights now.
Wonder if it's learning from all the car searches we are doing.
  #82
Old 12-19-2023, 09:20 AM
chuckies76ta's Avatar
Wow, That's some cool pic..
950 Quickfuel.
The Following User Says Thank You to chuckies76ta For This Useful Post:
  #83
Old 12-19-2023, 11:33 AM
Those Mopar are pretty sharp!
The Following 2 Users Say Thank You to Greg Reid For This Useful Post:
  #84
Old 12-19-2023, 12:03 PM
Shiny Shiny is offline
Agree! They are dramatic. It's interesting to see how it randomizes parts, colors, lighting, backgrounds, etc.
Who wouldn't want a wood-bodied Mopar with an angry turkey on the door?
The Following 2 Users Say Thank You to Shiny For This Useful Post:
  #85
Old 12-23-2023, 01:23 AM
4zpeed's Avatar
4zpeed 4zpeed is offline
To be honest I don't see allot of improvement yet with accuracy in detail, at times it gets pretty close though.
Frank
ID:	625472   Click image for larger version
ID:	625473   Click image for larger version
ID:	625474   Click image for larger version
ID:	625475   Click image for larger version
Poncho Huggen, Gear Snatchen, Posi Piro.
The Following User Says Thank You to 4zpeed For This Useful Post:
  #86
Old 12-23-2023, 04:35 AM
dataway's Avatar
Not being a Ford or Mopar guy ... they look perfect to me
  #87
Old 12-23-2023, 12:11 PM
4zpeed's Avatar
Not a huge fan either but some are appealing from afar, rear view mirror afar...
Actually the description on that one was 1972 Road Runner Rat Rod Theme, if not for copyrights I may have gotten the real Road Runner on the door. This thing is awesome for inspiration, I'd love to have that car. You're right here's a few random things I got while creating images of 442 Rat Rods, some can be odd and extraordinary.
1972 Oldsmobeast?
Head hunter? Bone Collector?
Check the hood handle.
Satellite adjustment slip and slide... TV addiction perhaps?
This one came out of nowhere...
Frank
ID:	625486   Click image for larger version
ID:	625487   Click image for larger version
ID:	625488   Click image for larger version
ID:	625489   Click image for larger version
  #88
Old 12-24-2023, 02:42 AM
dataway's Avatar
That's freakin hilarious ... where the heck is it coming up with that stuff.
If Bender was an artist .....
  #89
Old 12-24-2023, 04:38 AM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
As mentioned the time it's doing these in is unreal, that's a compounding effect that will speed up movies, TV shows etc. Marvels "Secret Invasion" TV show has an AI intro, it probably pumped out a ton of versions and they then used the best clips as the main 1, in like 2 hours because the editor couldn't decided which ones to use because they were all creative and good.
I like the Where's Waldo of details wrong, that's a fun test to see what is jacked etc. One of the cars had like 6 exhaust pipes underneath facing forward in that wheelie shot, hilarious. The Bender one was half convertible half hard top. Actually one of the fire cars had killer 5 spoke wheels.
AI has already created deadly toxins mankind never came up with, a couple of scientists let it run overnight and the **** it spit out freaked them, they stopped and realized, not a great test to run. Hopefully it'll cure and save more than it'll kill.
The images are fun, actually the input going into the AI has been creative which helps you the user gain more insight into what you want to see and your feelings towards the results. It'll train you to be very descriptive and process the results to meet your criteria or vision etc. I think a big plus to AI is time efficiency, one of the most valuable things in your life to gain back when possible.
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct @ 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline
The Following 2 Users Say Thank You to GOAT8U2 For This Useful Post:
  #90
Old 12-24-2023, 11:18 AM
Originally Posted by GOAT8U2 View Post
....AI has already created deadly toxins mankind never came up with, a couple of scientists let it run overnight and the **** it spit out freaked them, they stopped and realized, not a great test to run. Hopefully it'll cure and save more than it'll kill....
Definitely a blessing and a curse. I appreciate the tech but remain cynical about the ethics of business and worse, the profitability of crime.
I always pegged Gandolph as a Ford guy..
"A classic muscle car show in the Shire judged by Gandolph"
  #91
Old 12-24-2023, 12:43 PM
"First astronauts on the moon exiting their lunar module designed as a Pontiac GTO"
ID:	625546   Click image for larger version
  #92
Old 12-24-2023, 10:44 PM
ID:	625558   Click image for larger version
  #93
Old 12-24-2023, 11:55 PM
Looks very Moparish
  #94
Old 12-25-2023, 05:30 AM
dataway's Avatar
100 years from now you'll be able to AI design a wife ... better be real careful what words you use to generate that.
  #95
Old 12-25-2023, 07:18 AM
4zpeed's Avatar
Mike those are awesome, I like the one with a reindeer driving 'how ironic', a few days ago I tried to get a picture of a Pontiac sleigh getting pulled by reindeer, it's very hard to get the exact image you want or even something close. If, and that's a big if, you get the car you want, you don't get the reindeer, or they're in the wrong place or somethings off and it's just not a good rendering. It's always something... and the more words or specific you try to get, often the worse the results are.
The description for all those previous images I posted was "1972 Olds 442 Rat Rod in the driveway" nothing else. Sometimes things in your recent descriptions will bleed over. I'm pretty sure that's a gnome in the last image, I googled Gandolph and got - "Did you mean: Gandalf", Wikipedia said he's a wizard character from the Hobbit?
A small deviation in description can change the entire result, as an example RatRod instead of Rat Rod. If I don't use something like "in the driveway" to bring it back to earth, it starts adding totally outrages renditions of gargoyles, skeletons or monsters in all sorts of settings, however though better to be a little vague than over descriptive.
I've found simple terms keep it in bounds and less likely outside the realm of what you want. Black and white images can appear more authentic too but the wording matters, if you want a black and white car, enter "white and black" or it's likely just to give you a black and white image. You can also manipulate it to a degree.
Just to show an idea of what I'm trying to explain and what usually happens, this is a scenario I seem to get
allot when trying to get good lifelike images starting with no background or Rat/Hot Rod terms used.
It can be quite peculiar if you allow it to generate the background, here is "1972 Olds 442" in the description.
Well that didn't turn out like I thought lol, obviously a malfunction due to the drive-in background setting.
But this just goes to show how peculiar and random it can be, also notice the water color tone.
Now add "Rat Rod in the driveway" to the description and poof! Not sure why but the realism is evident.
Now I've taken "in the driveway" out, so it gives me a random background but the realism stayed, because of
"Rat Rod" still in the description and the prior 'recent' description which you can turn off.
I changed nothing in the next one and it gave me a random background again but the lifelike quality of the
picture is starting to fade. If not for "Rat Rod" in the description it probably would have turned to water color.
With "in the driveway" back in the description I get the more realistic image back. Now I might let it give me
a random background again just to see what comes up, it's a always a crap shoot anyway.
Frank
ID:	625566   Click image for larger version
ID:	625567   Click image for larger version
ID:	625568   Click image for larger version
ID:	625569   Click image for larger version
The Following 2 Users Say Thank You to 4zpeed For This Useful Post:
  #96
Old 12-25-2023, 10:45 AM
BILL BOWMAN1's Avatar
I like some of these Oldsmobuigoats😎
The Following User Says Thank You to BILL BOWMAN1 For This Useful Post:
  #97
Old 12-25-2023, 12:07 PM
KS circutguy's Avatar
Arrow Worth a repost.
Anyone that's ever been a coder, even on a basic level understands how over hyped the whole "AI" thing is. Maybe 1% of the population has any real insight into what AI actually is. It's old technology, it's been around for decades. The only "Intelligence" involved is the intelligence of the programmers implementing the alogrhymes that produce the results.
AI doesn't "Think" even the tiniest bit, it sorts through massive amounts of data and finds probable solutions to queries based on well crafted algorithms.
If you have ten scientists working on a problem in ten separate rooms and not communicating their findings progress is slow. If those ten scientist still don't communicate with each other, but dump their results into a database ... "AI" is the program that sorts through those results to find high probability solutions based on a consensus of data.
What makes the "AI" seem super intelligent is that it is the only person in the room that has access to all the results, from all the scientist in the same place at the same time.
It doesn't create anything new, doesn't "think" anything ... what it does VERY well is .... find things that humans miss because of the shear volume of data involved.
What is portrayed in Science Fiction movies is NOT what AI is, what is portrayed in the movies is total fiction (currently). Maybe in 200 years real "artificial INTELLIGENCE" will exist, right now it's very solidly "ARTIFICIAL intelligence" and there is a HUGE difference between the two.
Maybe one out of 1000 politicians and media figures have any real understanding of computer programming .... but of course they are ones making the decisions and hyping the technology.
Hello
The Following User Says Thank You to KS circutguy For This Useful Post:
  #98
Old 12-25-2023, 04:30 PM
Douglas Willinger's Avatar
Douglas Willinger Douglas Willinger is offline
Default A.I. Idea of Hood Design
See the hood seem line. Appears to include that extending down towards the front license plate. Ensures a 0 mph bumper, as any damages would be directly transmitted to the hood.
Apparently AI doesn't know that a 70 Lemans didn't have AWD so it can't smoke the front tires. Still pretty cool though.
1970 Lucerne Blue Firebird Trans Am, deluxe blue interior. Original Ram Air III, M-21, 3.73. Being built as a 4" stroke "434" with SR 614 Ram Air IV heads
1972+ Lucerne Blue 4-door hardtop "what if" T-41 Le Mans Sport GT/Grand Am concepts. Equipped with future 3" journal "455 HO"/"what if" prototype "SD 455".
What if GM had continued production of the 1970-72 GM A body somewhere in the southern hemisphere?
  #99
Old 12-25-2023, 07:22 PM
The hood and bumper are actually fused on the last one.
Old 01-09-2024, 12:42 PM
Our little dog gets harassed by a few large local cats. The stock show has been on the news so....
"a black and white terrier chihuahua mix on horseback, herding cats into a corral"...
