Pypes race pros are basically the same as ultra flows, they are a perforated straight through pipe with some packing in the case, cheaper than ultraflows but still a quality muffler, I run them in a 3" X pipe set up on a 500+hp stroker 467.
Can also check on ebay, there is or used to be some brands offering the same straight through type nuffler for very cheap, like $70/pr depending on size. Think it was "full boar" or something like that. |
Went with the full boar mufflers at $42 each. Thanks for the recommendation!
************************************* 1968 Lemans. 37,000 original miles. GTO clone. 462ci/KRE 290 heads. UltraDyne 280/288 Solid/850 Qjet by Cliff/Performer RPM/TSP 9.5" in TH400/8.5" 3.42 gears/3950# Race weight/12.58@106 at Bandimere speedway high altitude |
| The Following User Says Thank You to 68lemans462 For This Useful Post: | ||
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 |
Im sure the ultra flows are made a little better, but they also cost more... the race pros are stainless too & will or should last a very long time as well, mine are 10+ years old & look like new with no signs of any problems, still sound like they did when new too. |
