It would have been swapped along with the proportioning valve when the 4 wheel discs were put in.
Agree , the 79's with 15x8 Flakes still used the round stainless caps.
An old friend had a 79 403 car with 2.41 ,,,, the road had to be wet and power braked to make it spin the wheels. Would be a great gear with a 5spd Nash transmission |
And yeah, I'll be swapping out the 2.41 rear with another 78 rear I have laying around. One is a 3.23 posi, the other I think is the same but I need to double check. I'll be swapping back to drums.
"Those poor souls have made the fatal mistake of surrounding us. Now we can fire in any direction" 1970 Trans Am RAIII 4 speed 1971 Trans Am 5.3 LM7 1977 Trans Am W72 Y82 1987 Grand National |
I thought 78 was first year for rear disc???
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down...
Nope 79 for rear discs.
And my 78 180 HP with 2.56 could light the tires up also. And at Texas World Speedway all it could pull was 4000 rpm though-about 130+mph.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
So I'm jumping on the 78 now that the 79 I was working on is done. Started stripping the body down in preparation for metal work. I'll be replacing both door skins, the passenger quarter, the driver rocker, and lower patches on the driver quarter.
I have a new nose cone for it. The original is smoked. Here's a couple pics, including one of the passenger quarter and why I'm replacing it.
"If the best Mustang is the Camaro, the best Camaro is actually the Firebird" David Zenlea |
Nice bird and well-optioned! Congrats.
Where do you get the ambition to do all this? I used to be like that, seems to have left me........
1970 Trans Am 1971 Trans Am 1974 Trans Am 1978 Y88 Trans Am W72/auto 1979 10th Anniversary Trans Am 1984 Trans Am 1996 Trans Am WS6 1999 30th Anniversary Trans Am 2001 10th anniversary Firehawk #104 |
Perfect gears for an overdrive.
I just like to stay busy, and what better way to stay busy than to play with old Pontiacs? lol
More stripping. I'm using a harbor freight surfacer tool with a 40 grit drum. It actually makes quick work of it compared to a DA with 60 grit.
Door skins should be here this week. I'll get those banged out pretty quickly. I'm waiting on the inner and outter tail panel.
Man I wish one of mine only needed exterior work. All my cars are torn apart for floor work!
Making good progress there! |
Making progress. Got the glass out, nose stripped, trunk stripped, and interior mostly gutted. Still need to remove the dash, and fix the corners on the steel part. No biggie.
Picked up another passenger fender instead of having hours and hours of hammer and dolly work in the original. It looks like it was attacked with a hammer lol.
This snowballed into stripping the front end so I can pull the drivetrain and go thru it and detail everything.
More tear down going on. Time to strip and paint everything, replace bushings, hoses, belts etc etc
Had to do a heater core, so I decided to pull the dash so I can clean up the wiring and give all the hvac related items a deep cleaning.
#38
Mission creep, happens to all of us.....
Looks great! I am waiting on the body shop to get the body done on my Y88 so I can start putting it together.
#39
NOW is definitely the time to do the heater core!!!
Looking forward to your dash corner repairs. My 77 has that going on too....
#40
Doing door skins today:
