#101
Using the multi quote feature will consolidate your replies and make them easier to read. And the quoted message may be redacted.
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
#102
We rebuilt the Power Steering pump this weekend and installed the Motor on to the new Engine stand, slow progress, the saga continues...
#103
How difficult to rebuild the PS pump?
#104
Mikes reply:
My roommate, Lou, did it in about an hour. For the interested, I found this in my research, somehow, I came across this info. and I think it is important and I will apply it in http. format, so we won't take up valuable space. This way people can read it or not. Holman-moody: https://www.jalopyjournal.com/forum/....571847/page-7 I don't want to appear obstreperous, please don't be offended and keep in mind that this is my page and I said that all may say what they want in my posts, just a reminder update. Mike out... P.S. This Engine rebuild won't be completed overnight, so let me entertain you in between and you do the same. The "H-O" Thread, that I salvaged, is an example of what I'd like to see happen here, share your stories. Last edited by TRADERMIKE 2012; 01-15-2024 at 03:14 AM. |
| The Following User Says Thank You to TRADERMIKE 2012 For This Useful Post: | ||
#105
TOM S., IS THIS YOU IN THE h+m THREAD UNDER A DIFFERENT STATE?
Tom S. in Tn. |
#106
First of all I have no interest in the HM deal and im in CA.Tom
| The Following User Says Thank You to tom s For This Useful Post: | ||
#107
Guess you'll have to ask Lou. I think this thread is more about pontificating than sharing.
#108
You asked: How difficult is it to rebuild the PS pump? If it took Lou only one hour to complete the task, how hard would it be? You need a puller to pull the Pully and I will ask him for the directions when he comes home, if you like so, I can post it. Lou is good at what he does and may make it appear to be easy. The kit that I bought had "0"-rings, that's all. |
#109
Forum, beware of ads like this from any major vendor like Harbor Freight, it is a scam.
https://ladingyang.com/b05df285c99fd98c7be80b7e363a8e0a Here is the same thing with Lowes name on it, same scam! https://bannisterdome.xyz/065fcc6fbe...d128a4c9617f8e |
#110
Those URLs are from 'ladingyang.com' and 'bannisterdome.xyz' and not from Harbor Freight or Lowes, so that's your first clue. Always check that before clicking on a link, or better yet go directly to HF or Lowes (or whatever) website to see if they actually have special offers.
| The Following 2 Users Say Thank You to Stuart For This Useful Post: | ||
#111
I was up late at night buying tools and reading all the Harbor Freight cool stuff with coupons, plus the credit card that I applied for through Harbor Freight too. All adds up to someone cloning their site. Then the same thing happened to Lowes, I let both companies know about the problem. |
#112
I looked up Piston slap and have found videos of the phenonium and it sounds like my problem exactly, here is what it looks like, however, this is not my motor yet, hopefully this weekend we will get to it. I still have a home to keep up with.
https://www.youtube.com/watch?v=1SKxr3hUW7I https://youtu.be/cH0kch12nlE https://youtu.be/jIFK71HOwi4 https://youtu.be/JacTDmdBXWA https://youtu.be/q0PohKQZDA8 https://youtu.be/rrFEQUb9BDk Here is something different, but will it become used? https://youtu.be/UF5j1DvC954 https://youtu.be/hXc3iXGucFs https://youtu.be/9L-ttprjRjY |
#113
I just got through sending an email to Butler to see what the Costs will be for them to build my short Block, with their parts. It's a starting place that makes the most sense in order to get a warrantee. Also, it will expediate things.
I had a neighbor come over and lay a lot of money down to buy my double wide mobile home. I realized after that, after some research, this home is worth a lot more, especially if I finish it completely. I did some research and the market is up, a sellers' market. I have one room I can fix and rent for $500/month. I should be focused on repairing the rest of the Home and installing a kitchen etc, finish the floors and put it up for sale, while the market is high. I have a lot of stuff to get rid of on ebay, why am I playing with the car? Pay a pro to build it and capitalize on the economy. |
#114
Sounds like a good move
Mikes reply:
This the answer from Butler: We can do the machine work and supply parts as needed but we are not doing any assembly work. We can supply an unassembled short block kit using either your block or we can supply a core to machine. As far as the heads that’s between you and your shop. We use only full bronze guides, PC type seals and new valves, springs, etc... We are not big on trying to re-use gaskets but as you are the builder that’s your call to make. If you would like an estimate to do either the short block kit or to do a long block kit and work the heads, we can offer either. You just need to know which way you want to go and if you want to send the block or we need to supply one. Greg Butler Performance 2786 Hwy 43 North Lawrenceburg, TN 38464 Phone: 931-762-4596 EXT: 101 www.butlerperformance.com [email protected] Mikes reply: Since Butler is not going to build the short Block, then I have no alternative but to let a local shop do the Machining and assemble the parts, I will have to ask them about the parts they use and their warrantee? There is no way that I am shipping this short Block out to Butler without a complete job done in return and their taking responsibility for their work. I need to compare the parts between the two options. |
#116
I just got my first email from the forum in over two weeks depicting members responses; I don't know whether it was a button that I pushed on my end, that made a difference or you fixed the problem on your end? |
#117
I just noticed myself that at least some notifications are working again. Moderators don't have powers to fix that sort of thing, so I don't know what changed - it's up to the system administrator.
#118
We have been detailing the Engine compartment better than the former owner, the new motor mounts fit well and I will post a photo soon, meanwhile I am reading the new book on Pontiac Engine building 101.
Since Butler won't assemble the parts that they sell, I am calling out to other Pontiac Engine Builders, of course I will be using the parts that they want to use, that is if this engine needs a complete overhaul. I have yet to take it apart, home projects take priority. P.S. You know, the PY small community members are welcome here, all we ask is that you act accordingly. Mike out! |
#119
Not true, Lou said use a puller to remove the pully and follow the instructions in the 1967 Pontiac service manual, in our case and it is just a matter of R+R the various seals, easy he said, be careful not to damage the shaft or scratch it, in any way, that can cause a leak. I hope that helps. P.S. The book has a good drawing to follow. Last edited by Stuart; 01-23-2024 at 07:55 AM. |
#120
Lou is using the Engine Hoist to hang the AC compressor up and out of the way while he details the Engine compartment. It is looking good, since the motor came in the car on purchase, we have had to live with the former owners original detailing. His warehouse was filthy and thus left a lot of debris on this motor. Worse than that was the dog hair in the Heater core that we pulled and replaced.
I decided to keep the yellow color, a light color that shows the Engine well, I felt that black is just too dark and many people use that in their Engine compartment and you can't see the other parts. JMO I continue to read the Book on" how to build a Pontiac Motor" and as I thought, I have all this info. in my archives, however I am enjoying reading it anyway. I also have downloaded all the pictures in the book and wonder who copied who. Tomorow is the day to disassemble the short block, if all goes as planned! P.S. Current Auction prices on the 1973-79 Pontiac TA: Barrett Jackson, Lot 833.1, 1977 Pontiac TA, Black, 400 ci, auto, Hurst T-tops, 2w87z7n179298, $115,500 Barrett Jackson, Lot 1093.1, 1973 Pontiac Firebird TA 455 SD, 2v87x3n145319, auto, $159,500 Barrett Jackson, Lot 821.1, 1977 Pontiac TA SE,400 ci, 2w87z7n220634, $108,900 Barrett Jackson, Lot 1452, 782 miles, T-tops, 1979 TA Silver Edition, $100,00 Last edited by TRADERMIKE 2012; 01-28-2024 at 06:02 AM. |
| Closed Thread |
