| THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
No problem on the high impedance injectors, the below the blower, in the valley setup that is pictured uses Holley 100 lb/hr flow balanced injectors with EV6 connectors, which are plug and play for the Terminator X. The Injector Dynamics 1050 also fits. No sure what you mean about the cooling lines, the air/water intercooler mounted in the blower does not share engine coolant, it has its own circuit.
1964 Catalina 2+2 4sp, 421 Tri-power 1965 GTO, Roadster Shop chassis, 461, Old Faithful cam, KRE heads 305 CFM, Holley EFI, DIS ignition. 1969 GTO 467, Edelbrock 325 CFM, Terminator EFI 1969 Firebird Convertible |
Cool. Those are the same injectors (holley 100lb flow matched) I’m currently using N/A on E85.
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind, E85 Holley Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
That mod is deeply flawed. Coolant that has bypassed the cylinder heads results in lower temperature readings at the water crossover. Moving the sensor to the cylinder head would tell a different tale. HTH.
