#61
Old 09-23-2023, 01:24 AM
turbo69bird's Avatar
This is my buddy data plate . I don’t know all the options but I do know it’s a RAIIi 4 SPD, carousel red, can’t rmmeber color of the interior (been at least 16 years since I’ve seen it.)
Black vinyl top. I really don’t remember anything else about it but could find out.
I don’t want to go jack this awesome thread but wanted to know if it could still be a pattern judge for my buddy. He’s had the car since 73 .
I just couldn’t figure out a sure plan as to what constituted a pattern judge and what didn’t .
960 HP @ 11 psi, 9.70 at 146.
  #62
Old 09-23-2023, 07:48 AM
johnta1 johnta1 is online now
The only absolute way is to get the PHS for the car.
If a buildsheet is found in the car, it may have the number.
Having all the options for a 'Pattern' Judge doesn't make it a 'Pattern' Judge.
  #63
Old 09-23-2023, 11:33 AM
Every Judge Invoice we have witnessed from 01C through 02B has been a Carousel Red , Pattern Car.
His would be the First Known with a Vinyl Top .
His options would HAVE to mirror the Invoice of The Hangin Judge exactly.
But even with those factors - it doesn't make his documented.
To people in the know - it would be considered a 99% probability.
Doubtful he will do PHS since he hasn't already.
Framingham 69's usually have a Buildsheet - if it were found in good condition , that would document it by the order number and Zone Lot : Ship To : information.
  #64
Old 09-23-2023, 01:10 PM
jwood82d jwood82d is offline
TKX will fit into an A body no issues; uses the same bellhousing and shifts better than ANY Muncie - much stronger also and you get a good overdrive. You can shorten your existing driveshaft easily and use the C6 yoke.
You will need an offset shifter, plenty available.
Ok, you sold me. I’m going to go with the Tremec 5 speed. I’m guessing what I have is an M20 anyway.
The only transmission parts I have right now is the Muncie that will probably need to be opened up and looked in at the very least, and a bell housing. If all they would need to do is shorten the driveshaft to make it fit, a few extra grand is probably going to be well worth the driving experience and gas mileage by the sounds of it.
  #65
Old 10-20-2023, 06:00 PM
New update. Undercoating finished. I went with bedliner. Looks cool and should last a couple lifetimes. Also more block sanding. Looking forward to actual primer coming up soon.
ID:	621978   Click image for larger version
The Following 2 Users Say Thank You to jwood82d For This Useful Post:
  #66
Old 11-08-2023, 09:15 PM
Last week: Underliner, brake lines and rear brake fitting, more block sanding body work. Finally found a picture of the quarter panel decal from a vintage racing decal seller on Ebay! Might have to repro it though, last time he had one was 10 years ago.
Hoping the next update will be in primer and include the engine. Waiting on a new decklid which is currently on backorder til Dec.
ID:	623041   Click image for larger version
ID:	623042   Click image for larger version
ID:	623043   Click image for larger version
ID:	623044   Click image for larger version
The Following User Says Thank You to jwood82d For This Useful Post:
  #67
Old 12-16-2023, 07:46 PM
Engine block back from machinist, cleaned up and painted. Currently being assembled. TKX 5-speed and flywheel ordered.
ID:	625093   Click image for larger version
ID:	625094   Click image for larger version
ID:	625095   Click image for larger version
ID:	625096   Click image for larger version
  #68
Old 12-29-2023, 12:03 AM
Thanks for posting another update .
It must be a 69 YH block
  #69
Old 01-12-2024, 08:58 PM
It feels like it’s been a while since last update, so here’s more engine pics from today. Hydraulic camshaft is a Comp Cams custom grind from Butler. Need to measure for pushrods next and intake manifold going in is a dual plane Edelbrock Performer.
ID:	626500   Click image for larger version
ID:	626501   Click image for larger version
ID:	626502   Click image for larger version
ID:	626503   Click image for larger version
  #70
Old 01-12-2024, 09:27 PM
Also some chassis stuff. Fitting a beefier crossmember, and also the ladder bars are back. They will be removed again, painted yellow and given new bushings. Motor mounts on.
ID:	626506   Click image for larger version
ID:	626507   Click image for larger version
  #71
Old 01-12-2024, 10:25 PM
Yup. 028147 YH. Not sure where my father got it but it had a torque converter on it. Also have a 400, a 421, and another 428 that I guess aren’t in as good of shape.
  #72
Old 01-28-2024, 09:07 PM
Engine almost done. Going on the frame this week. VERY happy with how it looks and can’t wait to see it with the valve covers on it. Going with some Hamburger’s Performance tall finned fab’ed aluminums.
ID:	627372   Click image for larger version
ID:	627373   Click image for larger version
ID:	627374   Click image for larger version
  #73
Old 01-30-2024, 10:04 AM
gtome's Avatar
gtome gtome is offline
I have used bedliner on the bottom of many cars. One thing I've noticed, and it would be interesting to hear how it works for you is, tape doesn't like to stick to it for me. I usually try to do the bedliner after it's painted, wetsanded, and buffed because of that. Also its hard to get the wetsanding goo off of bedliner because of the texture. Could be specific to the brand I use though.
The Following User Says Thank You to gtome For This Useful Post:
  #74
Old 02-02-2024, 04:29 PM
Visited the shop today to check things out. The engine and trans is mounted to the frame! Trans has to come off again for a min because they need to install a spacer somewhere.
The valve covers are Hambergers, but they have to go back because the valve springs touch the interiors, so that’s a shame. May be going with Edelbrock classics for the finned look.
I am pumped for the body to go back on the frame soon. Still needs a driveshaft and exhaust. My wife says, “Let me know when it’s orange.”
ID:	627741   Click image for larger version
ID:	627742   Click image for larger version
ID:	627743   Click image for larger version
ID:	627744   Click image for larger version
  #75
Old 02-02-2024, 04:57 PM
gtome's Avatar
I'm Interested to see how well the trans fits the tunnel.
  #76
Old 02-02-2024, 07:23 PM
Should fit without any modifications from what I heard/read. Just needs a shorter driveshaft.
  #77
Old 02-02-2024, 10:01 PM
gtome's Avatar
I saw a YouTube video of a guy putting one in a 69. I'm just not 100% sure which one. I think he had to clearance a bit. It was "fast montey" if you want to have a look at it. He has a ton of videos on his 69 that are interesting.
  #78
Old 12-04-2025, 08:56 AM
scott70's Avatar
scott70 scott70 is offline
Any updates on the hanging judge?
  #79
Old 12-05-2025, 08:58 AM
scott70's Avatar
I’m kind of interested in this car because I first met dam miller in the 80’s as he did all our masonry work on new houses. Always did a beautiful job. His son Nate used to work with him too… you can see the name on the license plate. I had my 70 gto at that time and he used to tell me the stories of racing it,, he bought it new and raced it from day one. He invited me over to his house once and gave me some things that were originally off the judge. Exhaust manifolds, bell housing, nose valves and lifters, etc.
The Following 2 Users Say Thank You to scott70 For This Useful Post:
