Old 01-29-2024, 06:13 PM
Scott Stoneburg's Avatar
Well, my Sickweek ended early. I broke a rocker arm halfway to Orlando. I'll post pics later.
Old 01-29-2024, 06:26 PM
PAUL K's Avatar
PAUL K PAUL K is offline
That is a bummer! We were rooting for you.
Go fast, see Elvis!
Old 01-29-2024, 06:56 PM
mysticmissle's Avatar
did you hurt anything else? hope not, but arent they just bbc rockers? should be easy to find right. dont give up unless you have to
relatedly, i saw a very nice 1968 green firebird on the sick week you tube post
Old 01-29-2024, 07:06 PM
Very nice Green 67, but it's LS powered. I didn't stay at home home to take it apart to check the lifters or cam. I'll pull the intake to check that stuff next week. The heads will accept Big block Chevy rockers but mine are a shaft set up. So Harland Sharp would have to make the replacement. If I go back to HS rockers. I am looking at Jessel's.
The Following User Says Thank You to Scott Stoneburg For This Useful Post:
Old 01-30-2024, 12:59 AM
Just looking at it quickly (road side diagnosis) the adjuster nut looks to have backed off, pushrod popped out of the cup and stopped oiling the rocker. It overheated and froze up on the shaft. I'll have to tear into it to check further.
ID:	627511   Click image for larger version
Old 01-30-2024, 09:07 AM
slowbird's Avatar
slowbird slowbird is offline
That sucks, sorry to hear/see this. At least it's an easy fix if nothing else is damaged.
Old 01-30-2024, 09:24 AM
Cleetus track runoff video shows the Verdoro Green Bird ready to stage at the starting line.
Old 02-06-2024, 06:15 PM
Congrats, Nick Wiegand on his Fastest Pontiac win!
The Following 2 Users Say Thank You to johnta1 For This Useful Post:
Old 02-06-2024, 06:41 PM
PAUL K's Avatar
Excellent! Congrats Nick.... That is a very well done car those guys built.
Go fast, see Elvis!
Old 02-06-2024, 08:10 PM
Nick Trans Am is bad ass!
Old 02-06-2024, 09:35 PM
I took the intake and valley cover off today, the lifters and cam look good, but there were 2 other exhaust rockers that are damaged. Looking at replacing the current shaft rockers with either Jessel Pro Steel or T&D Steel shaft rockers. I spoke with T&D today, 22 weeks out for their Steel Shaft rockers to be made.
Old 02-07-2024, 01:27 AM
Dragncar Dragncar is offline
What brand was the shaft rockers that failed ?
Old 02-07-2024, 04:34 AM
Harland Sharp. They came with the top end when I bought it from the original owner, but I had to send some back for a rebuild when I got them, only had Dyno time on the rockers at that point. They are just not up to the task.
Old 02-07-2024, 04:40 PM
How much did T& D quote you for the steel shafts ? For Pontiac shafts they told me 20 weeks and 3000$ 1900$ for aluminum. I was kinda taken aback on the 3000$ price.
So I went with Crower SS shafts, 1540 $ through Jegs. I see you can get Jessel or Crower stell shaft rockers for BBCs for 1700-1900 $
Old 02-07-2024, 05:32 PM
firechickenman's Avatar
firechickenman firechickenman is offline
I'm curious, are your lifter bores or pushrods restricted? I've never ran any kind of restriction and have had very good luck with the top end with the exception of breaking 2 valve springs on Drag Week 2021.
Greg Weigart
IAIIA 520/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radial Pro/3300lbs/1.35 60'/[email protected]/[email protected]
Hot Rod Drag Week finishing averages:
2014 - 11.12 @ 118.56
2015 - 10.84 @ 124.97
2016 - 10.56 @ 127.88
2017 - 10.29 @ 130.74
2018 - 10.29 @ 130.53
2019 - 10.16 @ 132.34
2021 - 10.09 @ 132.69 - Quickest Pontiac
2022 - 10.13 @ 133.07
2025 - [email protected] - 2nd place SRBBNA
Old 02-07-2024, 06:40 PM
T&D Steel shaft rockers were quotes at $3100 with the valve spring oil hole feed. (only an extra $20 for the set to add this option) about $1950 for aluminum. The Jessel's were quotes @$4200. The Jessel set will use my existing Roland Racing shaft stands, which would be no issue. The T&D uses their own stands. The wait time is long, but whatever. I'll probably put my Edelbrocks on the motor during the down time. If I do, then I will have a very good comparison between the E-heads and the CV1 s.
Old 02-07-2024, 06:44 PM
I have never used and restrictors in the oil passage or restricted pushrods. This is the 2nd time the needle bearings @ the trunion needed to be addressed. When I got them there were 6 rockers that needed to be rebuilt, they only had Dyno time on them then.
  #38
Old 02-07-2024, 10:21 PM
slowbird's Avatar
Just curious what has been done to your e-heads?
  #39
Old 02-07-2024, 10:54 PM
My E-Heads are Butler 330-340 cfm heads, the are only 66cc chamber so they will raise the compression about 3/4 of a point. To 12.5 to 1. Depending on valve clearance, I hope to use 1.65 rockers, but have 1.5 if clearances don't allow the extra lift.
  #40
Old 02-07-2024, 11:14 PM
Your CV heads use BBC rockers right ?
For which exact BBC head. When I look there are many styles of them.
Will a shaft rocker for a factory rectangular port work or a specific type of aftermarket head ?
