Eaton makes a 30 spline 8.5 carrier and anyone can make 30 spline 10 bolt axles. I have Dutchman in the 81 and Moser in the 78. Dutchman could make a longer brake pilot than Moser would to locate a rear disc and hubcentric wheels. Moser we had to tack and extension on.
Moser and most others weld on bolt in bearing retainers-I added them to a factory 12 bolt in the IA Camaro with a 33 spline spool as you can but them separate. Strange has a "Street C Clip Eliminator that use the same taper bearings 3.150 OD they use on weld ons
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
