Old 02-09-2024, 01:39 AM
Same as above about your engine verification.
Have to have the P-o-P
That is the only pure defacto way to authenticate.
If you do not have it , the only thing you can do is compare the date code of the block against build date of the car.
Distributor Cap is not assembly line correct for your car.
Since I don't see a date code on your front drum I suspect it is an aftermarket replacement.
And we still need to see the stampings around the valve stem of your spare wheel.
Old 02-09-2024, 08:44 AM
Tedd930 Tedd930 is offline
Ok I will get a close up of the wheel date code
Does the engine numbers provided appear to
Be year correct ? As mentioned prior I speak to
The original owner and he is 100% certain the engine
Was never replaced .. but it would be nice to confirm .
I will ask about the pop . Thank u
Old 02-09-2024, 09:50 AM
johnta1 johnta1 is online now
Get the date code off the engine. It will also tell what model years it could be.
Old 02-09-2024, 01:25 PM
There’s pictures bellow of the engine numbers
698534. WS
Old 02-09-2024, 02:10 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
WOW, this has become exhausting.
The Following User Says Thank You to 60sstuff For This Useful Post:
Old 02-09-2024, 02:28 PM
The date code is back by the distributor on the block.
Looks something like J105. A letter and 2-3 digits.
Old 02-20-2024, 08:26 PM
Default More pics of trunk and engine
See attached please review and confirm thank you.. also attached thermostat housing
ID:	629065   Click image for larger version
ID:	629066   Click image for larger version
ID:	629067   Click image for larger version
ID:	629068   Click image for larger version
The Following User Says Thank You to Tedd930 For This Useful Post:
Old 02-20-2024, 10:50 PM
242177P's Avatar
242177P 242177P is offline
No spacer on starter solenoid. Low torque replacement.
The Following User Says Thank You to 242177P For This Useful Post:
Old 02-20-2024, 08:24 PM
Default Manifold numbers and spare tire pics
Baron ,
Exhaust manifold and spare tire attached
ID:	629060   Click image for larger version
ID:	629061   Click image for larger version
ID:	629062   Click image for larger version
ID:	629063   Click image for larger version
