#61
Usually the biggest carb wins. Flowing through an empty baseplate sometimes helps see what's going on with the transition from the carb exit into the manifold runners. The flow bench is helpful for improving carburetor CFM and testing booster signal. |
#62
So…. TA Man you pulling the tiger and making the move to Northwind, you have room under hood to try it with a spacer.
Interesting thread. I'm just been playing around with a Victor 4150 I'm gonna try this summer. The Northwind is a 4150 Dave did for me. Victor difference of about 1" plenum height.
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 3:90 gear. 28" slick. Best so far 9.95@135 mph. 1.39 60 ft. 76 Trans am, TKX .81 o/d, 3.73 Moser rearend, 468 with KRE D-ports, Doug headers, 3" Exhaust 950 Quickfuel. Last edited by chuckies76ta; 02-10-2024 at 12:22 AM. |
#64
Are you going with 1050 on Victor? Or am I reading picture wrong
Yes 1050
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 3:90 gear. 28" slick. Best so far 9.95@135 mph. 1.39 60 ft. 76 Trans am, TKX .81 o/d, 3.73 Moser rearend, 468 with KRE D-ports, Doug headers, 3" Exhaust 950 Quickfuel. |
#66
Brian,
Sometimes because of rules that is not possible. ![]() Stan
#67
Just as a comparison first picture is un-port Victor second one fully ported Victor. I was blown away in the difference in hp the ported Victor made over the un-ported one, that was just port matched to my heads.
| The Following User Says Thank You to Gach For This Useful Post: | ||
#68
Definitely looking good, going be interesting see how much you pick up
Ya hard to say. I'm just playing around with this intake to see what the car will do. I have the Northwind 4150, the Northwind 4500 and now this Victor 4150 which I'm doing. I'm gonna try all 3 this summer see what happens. I didn't do back to back testing with both Northwind intakes, but at end of season we ran the N.W. 4500 and ran a best number at our track. (10.12)
#70
Stan
#71
Maybe this will help, when we dyno with the un-ported Victor and the 10.50, after a few pulls, he said you need more carb, so he’s on the phone with Patrick at Pro Systems, Who he deals exclusively with. Two days later carb shows up, first pull it picks up 30 more hp, turns out its a 1150 cfm. I’m not running a big roller 739 lift. 265/276. 505 ci. But they are wide port heads.
I may run out of room..torker 2 with a 2inch was pushing it
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 |
#73
Time to get out the measuring tape. Wow 2” on the torker 2 nice
That because both intakes are ported, Gach is confused again.
| The Following User Says Thank You to slowbird For This Useful Post: | ||
#75
#76
closest to my Dom-Victor 2-inch spacer on the NW and 1 1/2 on the victor The victor has not been ported either the differance was I think 6 HP I put the NW on my 57-wagon. GT |
| The Following User Says Thank You to blueghoast For This Useful Post: | ||
#77
.Imo to make it worth while a spacer is needed. They squashed that area to help with hood clearance but it's definitely costing power. |
#78
Gotcha
I was looking at that ...it has really high ports so at least a 3/4 inch spacer to get the throttle blades up higher.
#80
