#101
Old 02-13-2024, 02:41 PM
Was the window channel a pre-made panel or did you make that? Just wondering about the nice looking trim studs.
As usual, wonderful work you are doing.
Which TIG hand control are you using these days?
I bought preformed window channel patches for my '66 from this place. Don't know if they were around when I did my '68.
https://www.beldenspeed.com/
The Following 2 Users Say Thank You to Greg Reid For This Useful Post:
  #102
Old 02-13-2024, 09:34 PM
Entropy11's Avatar
Entropy11 Entropy11 is offline
Thanks guys. It’s exciting seeing these obstacles gradually disappear 1 by 1.
I was going to get the Beldenspeed pieces (those guys are awesome and their customer service is the best) but decided against it. I’d have to buy the upper and lower half of the channel and weld them together anyways so figured I’d just make the piece so I’d have the bottom of the channel, the side of the channel, and a little left over to roll into the top pillar/quarter face. I needed practice forming such a tight but smooth contour with the shrinker anyways. Definitely either learned or invented (lol) some techniques to wrap that contour and not have any of those typical or obvious “gather” lines on the flat area. Kinda fun when it’s not agonizing.
I guess it was a lot of trouble to go through but it saved me $120 in parts and 4-5 down days for shipping. Maybe too much effort but I wanted to preserve the curve right where the factory put it. Pics of fitting it in tight just before welding.
ID:	628567   Click image for larger version
ID:	628568   Click image for larger version
The Following 2 Users Say Thank You to Entropy11 For This Useful Post:
  #103
Old 02-13-2024, 09:57 PM
Entropy11's Avatar
Hey John I made a little jig to hold the trim stud at the right height to weld it in place and then separate to remove it from the stud. Once it’s held in the jig you can’t screw it up. I just use the trim studs Belden sells that are made for the stud weld guns. Too much effort for these 2 studs but I also had the 6 or so across the channel in the deck filler.
I’m still just using a simple finger on/off switch I made from Amazon parts on my TIG torch. I do everything in what has become my go-to high amp pulse deal. No need for amperage control once I get it dialed in… just how many pulses I want before heat is an issue.
ID:	628571   Click image for larger version
ID:	628572   Click image for larger version
ID:	628573   Click image for larger version
The Following 3 Users Say Thank You to Entropy11 For This Useful Post:
  #104
Old 02-14-2024, 02:32 AM
dataway's Avatar
dataway dataway is offline
Sweet, and probably more secure than the OEM studs. Excellent job on the metal, with those kind of skills pretty much any restoration is within your capability.
Not that I don't value our old Pontiacs ... but when I see your kind of work I kind of wish it was on something more rare and exotic.
  #105
Old 02-14-2024, 02:29 PM
Entropy11's Avatar
Haha yeah… I almost feel guilty sometimes going to these lengths on a car that must have spent a good number of years rotting away in some farm field. This car was off the road for 36-37 years and I had to jump through some hoops just to get it a new lease on life with NY state and the registration.
I figure it’s all good practice for that time down the road when I’m working on something where preserving every square inch of metal is essential. In the meantime this should become a pretty solid driver and already feels like an old member of the family.
  #106
Old 04-15-2024, 11:28 PM
Entropy11's Avatar
Haven’t updated in a while. Been spending more time with my family than working on the car seeing that my Dad was having health issues. Funny thing was every day at the hospital he’d ask me for updates on how the car was going.
Anyways, what I thought would be a minor patch on the right side of the trunk became nearly a full right third stamping (and the trunk support below). It went in pretty quick and clean. Decided to MIG this side in for a change. I was worried about warpage so located the butt welded seam on top of the fuel tank support below it (felt like cheating) and ran the seam up onto the “shelf” area about 1/4” off the stamped rib. The structure from the rib helped keep everything distortion free.
ID:	632118   Click image for larger version
ID:	632119   Click image for larger version
ID:	632120   Click image for larger version
  #107
Old 04-15-2024, 11:38 PM
Entropy11's Avatar
I did this little spot tonight. I didn’t notice I never ran my left trunk floor patch up high enough onto the back edge. Made a quick repair piece, welded it in, then blended the seam out. Maybe the speed of this whole MIG thing is growing on me lol. No before pic but it was just a small hole.
ID:	632122   Click image for larger version
ID:	632123   Click image for larger version
The Following User Says Thank You to Entropy11 For This Useful Post:
  #108
Old 04-16-2024, 01:38 AM
dataway's Avatar
Yep, MIG is like a metal hot melt glue gun
  #109
Old 04-16-2024, 05:24 PM
Entropy11's Avatar
Haha exactly. I think I tweaked things enough to enjoy it. 0.23 ER70S-7, inductance settings, a non-standard gas mix… Basically I complicated it enough to make it interesting. For some odd reason I’m betting you can probably relate to that mindset!
  #110
Old 04-17-2024, 01:55 AM
dataway's Avatar
You can do some amazing things with 0.23 if you have enough controls to adjust. I can't wait to get a MIG welder that isn't 35 years old so I'll have more dials and buttons
