Old 02-18-2024, 08:29 PM
Glad you found the culprit(s)
All of my E heads have the rocker stud hole into the intake port. First run set I had instructions did not mention sealing threads and at a long idel it would puff smoke. Using Permatex #14 on threads and a blob under the stud hex never and issue. I also put a blob under the head bolt washer on the set KRE sleeved that hole.
SBC Fast burns go into intake port their factory stud has a built in washer under the hex I guess helps seal it.
