#61
Where are you located Mgarblik? I have never seen a satin black Napa Gold filter. Ours the last several years have always been gloss black. Before that they were always white. That one is clearly coming from a different supplier.
I'm curious now if the difference is the area of the country we are living, or because our Napa is privately owned....or??? |
#62
I am in Dayton, OH. Most of the parts come from Columbus , OH or Indianapolis. Sometimes, KY. Like you said, the Gold filters have been gloss black for probably 5 years . These new, satin black ones have a little, dry grit/grip to them. Might make them a little easier to get hand tight. Similar to the end of some Fram filters. My local NAPA store was an independent for over 30 years. About 2 years ago, all the local stores became "corporate" stores. Not much changed as a consumer. They sell more garage art and air fresheners now. Got a couple decent late model corporate looking delivery cars. Everything else about the same. The 3 main counter people have about 70 years of parts experience and are fantastic. They make ALL the difference and that's why I go there. Parts probably cost 5% more than Autozone, Oreily's, and Advanced Parts which are all staffed by complete idiots with a maximum of 6 month's experience.
| The Following User Says Thank You to mgarblik For This Useful Post: | ||
#63
Having cut open every filter I’ve done on this engine and using the Baldwin, Wix, and Purolator BOSS line the Purolator and Baldwin seem to be the best. More pleats, finer media, heavier.
#64
https://www.youtube.com/watch?v=wP8f...ipCityWrencher Heres 2 Wix filters, #51348, one made in the US, one made in china. https://www.youtube.com/shorts/HnVdf_rYzP0 Before you insinuate I'm a liar, do your homework......
#65
A rhetorical question and one that might set aside any political opinion.
In general, if an oil filter has a strong burst-resistant steel canister, a strong filter element with supported pleats, end caps/seam that are sealed tight and the capture efficiency (particle size retention) that meets your criteria.... would it really matter if it was made overseas. .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
| The Following User Says Thank You to Steve C. For This Useful Post: | ||
#68
Sadly, I have only one hobby car. But, I have 28 oil filters. A combination of Wix and Baldwin. So at my age that's basically a lifetime supply. Probably more. LOL.
#69
There are very few businesses in this country anymore that do everything in house from start to finish, especially in the car industry. |
#70
![]() 1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild |
#71
I don’t like Rock Auto. That’s how I figure.
Who cares, I got enough for years. |
#72
Just got Baldwin filters from rock auto for Pontiac and my work van. Both say made in the USA.
#73
With all the good reviews I'll be cutting a baldwin open to compare. Sounds like an excellent filter.
#74
Interesting, I've worked in a napa shop here in Washington for 30+ years now. I've never seen a totally shrink wrapped filter. I have seen a clear plastic cap just on the open end. Usually that means it's a Mann and not a Wix. I've never seen a filter yet with the red/purple gasket. I'm not the lube guy, but probably open 2+ filters a day too.
#75
Just took a look in the parts room and I have one Baldwin B39 filter left. It's up for bidding to the highest bidder!......
I'm not much of a Rockauto fan but they have the best prices for Hasting/Baldwin filters that I've been able to find. Their shipping can be pretty high so it pays to buy a half dozen or so to keep the price each down some. I'd add here that the last time I ordered Hastings filters (the same one just happens to fit all of our vehicles here) they were listed on Rockauto as part number LF-113. Balwin B1400 or 1401's showed up instead, but all were USA made and excellent quality. Also interesting that when you cross reference the OEM filters for my Yamaha side-by-side, John Deere X740 (Yanmar diesel) and Yanmar diesel powered compact tractor the SAME filter also fits all of those. So now I only need to stock either a B-1400 or B-1401 for everything I own except the Honda 500 Rubicon. The only difference in the B-1400 and B-1401 is the height of the filter......
#76
I stock cases of Wix Filters for all my different stuff.
All my 51258s are Made in USA. These pics however, are from my last order for the Filter that fits my YJ Jeep Wrangler & Dodge Ram 2500:
1966 GTO (Red) WARPATH 469CI TriPower 4-Speed 1965 GTO (Black) TRIPOWR 455CI Weiand Dragstar with 6 Strombergs 4-Speed 1965 GTO (Blue) 3X24SPD 464CI TriPower 4-Speed 1963 Tempest (Red) VIOLENT 440CI 2X4 Mag Nash / T400 (for now..) |
| The Following User Says Thank You to 3X24SPD For This Useful Post: | ||
#77
My thinking is that since it's a Wix filter with the sticker changed for Napa (even the sticker appears very similar) I'm guessing that the filter is just taken out of the Wix box, box thrown away, Napa sticker installed and then the entire thing is shrink wrapped to keep it clean and it's put on the shelf. Keeps Napa from spending more money to make a Napa box lol. |
#78
I have a Subaru and. A 16 Buick Lacrosse. The Buick Wix were made in the US and the Subaru’s were made in Mexico.
1979 Trans Am WS-6 .030 455 zero decked flat pistons 96 heads with SS valves 041 cam with Rhoads lifters 1.65 rockers RPM rods 800 Cliffs Q Jet on Holley Street Dominator ST-10 4 speed (3.42 first) w 2.73 rear gear __________________________________________________ _______________________________ 469th TFS Korat Thailand 1968-69 F-4E Muzzle 2 |
#79
Huh, they're all boxed here. I wouldn't have expected such variation coming from one supplier. |
#80
That's what I seem to be finding out in this thread. Different suppliers with different packaging, some say China, some say USA.
Ive never seen a china one out here while others report differently. |
