#421
Old 07-11-2023, 09:27 PM
63Banshee's Avatar
63Banshee 63Banshee is offline
Originally Posted by PLongen View Post
I am looking for a park cable for a 63 LeMans.
Thank you
Dash or floor shifter?
  #422
Old 07-12-2023, 07:50 AM
PLongen PLongen is offline
Floor but I am told I could use a dash one if I coil it.
Thank you,
Pat
  #423
Old 07-26-2023, 07:57 AM
Default Rear Differential Axel Seals
I am looking for rear differential axel seals.
Thank you,
Pat
  #424
Old 07-27-2023, 07:25 AM
Radman's Avatar
Radman Radman is offline
Rear axle seals part number CR11590 Fatsco.com
From the Little Indians web site tech section. If you are not a member join. Only $15.00 per year. Newsletters and a great web site. They have a parts interchange list and other great information in the tech section.
If you built it, drive it.
red 62 Tempest total stock restoration.
white 62 Tempest modified, 61 389 Tri-Power, and a conventional drive train.
  #425
Old 09-20-2023, 07:05 PM
Halfthrottle Halfthrottle is offline
Default Bell housing and flex plate
In need of a 63 lemans flex plate and bell housing. Automatic application. My flywheel is stamped steel not a cast iron flywheel. "Flex plate" I have been having starter issues since purchase. I have had 2 OEM starters and two aftermarket torque drive starters and all have chewed up the gear on the starter and flex plate. I talked to a local re-builder that told me to check the clearance between the flex plate and flywheel gear and the measurement is no where close. He said since there is no way to shim the starter on a bell mounted starter I need to try a different bell housing. And since, now, my flywheel teeth are chewed up he told me to source another flywheel/flex plate as well.
  #426
Old 09-20-2023, 08:56 PM
Radman's Avatar
What engine do you have?
  #427
Old 09-21-2023, 10:08 AM
Its a 326
  #428
Old 10-06-2023, 07:37 PM
Still in need for bell and flexplate 326 auto in 63 lemans. Car is now DOA and can not be driven. Willing to pay appropriately for these parts.
  #429
Old 10-31-2023, 04:38 AM
63Banshee's Avatar
I have those parts for you.
  #430
Old 10-31-2023, 07:40 PM
That's great. Can you email me at [email protected]. I'll give you my address so you can work up a price shipped for me.
  #431
Old 11-08-2023, 03:23 AM
Darren 639's Avatar
Darren 639 Darren 639 is offline
Default 63 quarter panel emblem
Hello all
I am finally trying to reassemble my 63 LeMans.....only 12 years now HaHa
I need one quarter panel emblem. was looking for N.O.S. one to match the other side that I luckily found in Norwalk. Please if there is one out there let me know
THANK YOU. Darren
  #432
Old 11-10-2023, 04:42 PM
deanremix's Avatar
deanremix deanremix is offline
I'm in need of front fenders for either a 61 or 62 tempest.
  #433
Old 11-17-2023, 05:06 PM
63Banshee's Avatar
Your location?
  #434
Old 11-17-2023, 08:37 PM
deanremix's Avatar
Originally Posted by 63Banshee View Post
Your location?
southern maryland
  #435
Old 02-24-2024, 08:01 AM
Default 63 Tempest/Lemans Power Steering Brackets Wanted
Looking to put power steering on my 63 Lemans. I need the 4 cylinder power steering pump brackets and other related parts.
Thank you,
Pat
  #436
Old 02-24-2024, 11:53 AM
tom s tom s is offline
FYI,the tempest PS is power assisted like early Mustangs and early Corvettes.Works pretty good.Tom
  #437
Old 02-24-2024, 03:11 PM
JohnFromVentura's Avatar
JohnFromVentura JohnFromVentura is offline
63-67 Corvettes used similar slave cylinders, lines etc. The pump brackets you might to make?
  #438
Old 02-25-2024, 08:15 AM
I would like to get a picture of the brackets, there's a picture of the brackets in the manual but doesn't show the pulley side.
  #439
Old 02-25-2024, 08:38 PM
cleveweld's Avatar
cleveweld cleveweld is offline
I don't have a picture of the front bracket without the pulley in the way but you can see its general shape. Bracket is about 1/4" thick and has a jog to it. There is also a bracket to support back of pump. You need the correct ps pulley so it will line up with water pump pulley.
You would also need a PS center link, control valve, slave cylinder and hoses. A hole has to be made in fender well for the pump hoses to pass thru. Also need a bracket to mount slave cylinder to frame. A different pitman arm for ps also.
Your best bet is to find a junk 61-63 4-cyl. Tempest with power steering. There are rebuild kits readily available for the pump, control valve and slave cylinder as Corvettes used the same rebuild kits.
Name:	PS pump 007.jpg
ID:	629344   Click image for larger version
Name:	PS pump 004.jpg
ID:	629345   Click image for larger version
ID:	629346   Click image for larger version
ID:	629347   Click image for larger version
Name:	bike pics 017.jpg
  #440
Old 02-26-2024, 07:54 AM
thanks for the pictures that helps. All need now is a templet to make the front bracket. It shouldn't be to hard.
Pat
