Old 03-05-2024, 03:48 PM
Drag Star Le Mans's Avatar
What intake is that? The support from the heat cross over doesn't look familiar to me.
Well with it being posted by toms I would say it's a 544128 early SD intake.
DragStarLeMans
  #322
Old 03-05-2024, 06:30 PM
BILL BOWMAN1's Avatar
Catalina is back up in the air. Now doing the driver side of the front end rebuild. Should be a little easier, learned a couple tricks from the other side.
The Following User Says Thank You to BILL BOWMAN1 For This Useful Post:
  #323
Old 03-05-2024, 07:11 PM
68 Firebird's Avatar
68 Firebird 68 Firebird is offline
Default Installed intake with seperated water and exhaust crossover
Modified 9799068 intake and seperated water crossover.
Used repop exhaust crossover.
Drove it Sunday and she ran excellent weather 55-60.
There will be a lot more testing in summertime!!!!
Fit very well. Enjoyed the project!
Note poprivet for throttle cotterpin has already been replaced!!!!!
Gerry
ID:	629931   Click image for larger version
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, GM HEI and Ram Air pans and RARE Long Branch Manifolds
The Following User Says Thank You to 68 Firebird For This Useful Post:
  #324
Old 03-05-2024, 07:23 PM
Lemans got her first bath of the year - damn Albuquerque water is rock-hard and spots are tough to avoid.
The Following 2 Users Say Thank You to Scarebird For This Useful Post:
  #325
Old 03-06-2024, 10:37 AM
One of the bolts is rust welded to steering arm -that connects tie rod to backing plate. I think I’m gonna kill it trying to remove it. Question… can chassis bolts as this be replaced with a grade 8 ?
  #326
Old 03-06-2024, 03:09 PM
gtospieg gtospieg is offline
Bill, Have you tried heat yet?
The Following User Says Thank You to gtospieg For This Useful Post:
  #327
Old 03-06-2024, 03:54 PM
Smile
Got all the junk that was piled on top of it put away where it belongs.
Lifted the dusty tattered cover off of it and looked at it, pondering the next steps towards getting this long stalled-out project going.
All in good time I suppose.
ID:	629979   Click image for larger version
ID:	629980   Click image for larger version
ID:	629981   Click image for larger version
ID:	629982   Click image for larger version
  #328
Old 03-06-2024, 05:26 PM
Yes took a while but finally got it.
First couple threads are buggered but I can dress them up.
  #329
Old 03-06-2024, 05:52 PM
Some days I wonder if knowing how to do this stuff is a blessing or curse 🤔
  #330
Old 03-06-2024, 08:04 PM
You'll have the satisfaction of having done it yourself...and saved a ton of money.
  #331
Old 03-07-2024, 05:42 PM
Whiz wheeled the frame bolts that were rust welded to the bushing inners.
GOOD TIMES!
  #332
Old 03-07-2024, 06:04 PM
tom s tom s is offline
Changed plugs in the 69 bird,fixed a small gas leak in the 62 GP.Tom
  #333
Old 03-08-2024, 10:27 PM
VCho455's Avatar
VCho455 VCho455 is offline
It was the nicest day in months and I needed a clean timing cover for the 389. Picked some from the pile and started in.
  #334
Old 03-08-2024, 10:38 PM
Reconfigured the upper radiator hose for better flow/burping of air.
  #335
Old 03-08-2024, 11:18 PM
Engine builder came to my house and we did the breakin,all went well.I had the new Comp hydraulic roller lifters in it and they are quiet. Builder found you HAVE to follow the directions to a T.They are the Evolution lifters.Daved Butler gave them high marks.FWIW,Tom
The Following 4 Users Say Thank You to tom s For This Useful Post:
  #336
Old 03-09-2024, 06:20 PM
The supervisor.....
  #337
Old 03-09-2024, 10:56 PM
form74's Avatar
form74 form74 is offline
Pulled the trans out today to be checked as the motor locked up going down the track.
74 Formula
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Edelbrock 87 cc dport heads
Performer RPM
The Following User Says Thank You to form74 For This Useful Post:
  #338
Old 03-10-2024, 03:34 PM
Verdoro 68's Avatar
Took the backroads to cars and coffee this morning. Car ran smooth, no issues. Brakes finally feel good.
That's Mt. Diablo in the background.
Found a cool barn on the side of the road and though the red might make for a nice contrast against the green.
ID:	630159   Click image for larger version
Ken
'74 Ventura 350
'69 AMC Javelin SST
The Following 4 Users Say Thank You to Verdoro 68 For This Useful Post:
  #339
Old 03-10-2024, 04:10 PM
SD455DJ SD455DJ is offline
Ken, Love the stance, love the color, love the wheels & tires...one of the nicest '68 GTO's I've ever seen...drool!
Dennis
  #340
Old 03-10-2024, 04:25 PM
Tack welded a couple nuts inside the A arms for the shocks. Nothing worse than those friggin cage nuts breaking loose and spinning. That’s all for today..
