Guys I found a complete rear end out of a 66 GP with posti and 278 gears for a fair price. I assume this will swap out in my 67 Catalina Wagon. Rear end is drum to drum .
Am I ok in buying it without any major issues? Thanks Pete |
While you can switch out the center chunks, I believe you will find the axel housings do not share the same control arm mounting points. Perhaps someone else can confirm. Want to say only 67 and 68 are direct housing swaps.
I installed a 3:42 posi in my 68 Bonneville, and truthfully, I wish I had left the open 2:73. The off the line performance change was not that great with the low-po low compression 400, and I lost some of the easy highway cruising ability. Are you building something with enough grunt and planning to use it in a fashion that really needs the posi? |
Thank you for your reply.
Yes building a 421 HO stoker motor is the reason why I want posi rear. Motor will be around 500 hp. |
you might want to consider poly bushings and boxing the control arms.
someone was selling aftermarket arms, but I dont recall who. Maybe RARE? |
https://pmtfabrication.com/product/1...-trailing-arms Here is one example
I am pretty sure '66 spring perches are different from '67. Not a deal breaker, but something to be aware of.
Jim K in PA 1967 GP HT 428 1967 GP convert 428 1957 Chieftain 4D HT |
perhaps it was the spring perches and not the control arm mounting points. I wasnt certain.
![]() Quote:
Sent from my SM-N950U using Tapatalk |
Larry thanks for your reply. I have another question if you don’t mind, I can buy a posi & 3:08 nos gears from a 71 big car Pontiac. Guy tells me that only needs to be done is to change the yoke and maybe cut the drive shaft and that should work. After reading what you wrote I have some doubts about it since you mentioned about the pinion spline is 28 in the 71’s and 30 spline in my 67. Can you give me your opinion on this? The gears are Nos and the posi is rebuilt.
I put in a 421 factory motor from a 66 2+2 with 3x2’s and stroked the motor bored .060. Thank you |
65-70 Oldsmobubble share the same guts as Pontiac. This should expand your options.
"At no time did we exceed 175 mph.” Dan Gurney's truthful response to his and Brock Yate's winning of the first ever Cannonball Baker Sea-to-Shining Sea... Still have my 1st Firebird 7th Firebird 57 Starchief |
![]() Quote:
63 Catalina coupe 467 cid budget drag car 11's 1/4 , 7.20 1/8th pump gas n/a 66 Star Chief Executive 57k mile 69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4 69 Firebird 400 Burgandy/Black 70 Olds Rallye 350 F85 4 speed 3.91's 70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455 74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8 2020 RAM 1500 SLT 4x4 5.7 A8 Hemi 2007 Hummer H3 3.7 liter turd 2019 Chevy Spark petrol car 38 mpg |
![]() Quote:
not all the B body Olds have the 65-70 PONT 8.878 , SOME models years do but not all
The OLDS B Body interchange is only 1965 and some early 1966 before they switched to their own Type O B body big axle (9.3) similar to the A body OLDS 64-66 used a BOP 8.2 and 67-70 went to the Type O 12/10
Extremely rare to find a "good" ratio (3.23 or 3.42) P series posi rear in the '65/66 Big OLDS.
Agree with Larry, that usage was only for a little while in big Olds. It's been near 15 years since I've run across a manual trans non AC '65 big Olds, & that was in a monster yard in MN that used to hold onto the old stuff much longer. That '66 had a 3.42 Safe-T-Track under it. Last Fall, two of us PY'ers were in another monster yard up north that had several '65 Olds Station wagons, the wagons are a good place to look. That long row of big Olds had other big Olds of that era setting on top of the wagons, along with trees & saplings growing between each car. No chance of getting any of the wagons jacked up. On the 8.4" ring gear Type "O" Olds, have had quite a few 3.23-3.91 ratio Anti Spin 442 rears, & have gone though a few more for customers. The Type O's are a restoration piece, for any kind of strong performance, they lack the pinion support of the later 8.5 A-body. Always get a chuckle out of eBay listers noting the Type "O" A-body rears as "12 bolts", or as an OEM usage rear in Pontiac "GTO"s. Only Olds were originally built with Type "O" rears.
Buzzards gotta eat... same as worms. Last edited by 'ol Pinion head; 03-18-2024 at 10:45 AM. |
Thread Tools | |
Display Modes | |
