Old 03-24-2024, 01:19 PM
pngoat pngoat is offline
Default LED instrument panel lights
I am thinking about replacing the instrument panel bulbs with LED's. This question is for those of you who have done this. Is the instrument panel any brighter, at night, with the LED bulbs versus the incandescent bulbs? Car is a 65 GTO with standard gauges. Any help appreciated. Thank you.
Old 03-24-2024, 03:59 PM
gto4ben gto4ben is offline
My GTO has incandescent bulbs and my LeMans has LEDs. I'll send you an A-B compare photos tonight. My only complaint is that the dimmer switch will not work correctly with LEDs unless you convert it to a PWM controller to adjust brightness. I ordered some newer LEDS that supposedly will reduce brightness using the stock dimmer. It'll arrive Monday and I'll let you know how they are.
The Following User Says Thank You to gto4ben For This Useful Post:
Old 03-24-2024, 04:18 PM
gto4ben: Thank you. Will be waiting for your reply.
Old 03-24-2024, 06:48 PM
Red80TA Red80TA is offline
If the LEDs are too bright, try converting them to incandescent globes.
The Following User Says Thank You to Red80TA For This Useful Post:
Old 03-24-2024, 08:09 PM
george kujanski's Avatar
I used the leds and the panel is much better without being too bright.much nicer!
George
The Following User Says Thank You to george kujanski For This Useful Post:
Old 03-24-2024, 11:14 PM
Here are the comparisons. The cell phone camera sets the white balance automatically and that makes the incandescent appearance look whiter. Also, The Instrument cluster lens needs some cleaning on the LeMans.
Name:	Incandescent Bulbs in GTO.jpg
ID:	631001   Click image for larger version
Name:	6000K LED Bulbs in LeMans.jpg
ID:	631002   Click image for larger version
Name:	A-B Comparison.jpg
Old 03-25-2024, 12:25 PM
Did you use white or blue LED's on your Lemans?
Old 03-25-2024, 12:59 PM
white
Old 03-25-2024, 02:30 PM
Here's a side by side comparison of GE 1895 incandescent bulb with the BA9S LED lit with 14V. What you see reflected on the instrument face depends on the background color. The LED enhances the blue a lot when it reflects a blue background while the incandescent looks more white on the same background.
ID:	631020   Click image for larger version
Old 03-25-2024, 04:53 PM
Received the rheostat controllable LEDs today. Their brightness are indeed controllable by voltage. The BA9S shown cuts out at ~7.5V while the dimmable version continues to light down to just under 3V. The cell phone compensated for the ambient light so I tried to show the brightness variation using a camera with manual modes.
Name:	BA9S LED cuts out @ 7.5V.jpg
ID:	631025   Click image for larger version
Name:	BA9s vs Dimmable LEDs.jpg
ID:	631026   Click image for larger version
Name:	GE1895 vs Dimmable LED  @ 14V.jpg
ID:	631027   Click image for larger version
Name:	Brightness vs Voltage 2.jpg
Old 03-25-2024, 05:05 PM
gto4ben:
Thank you for your advice. It helps a lot. Looks like I will be ordering the dimmable white LED's like you have. Thanks again.
Old 03-25-2024, 07:02 PM
jerry455 jerry455 is offline
I bought LEDs for my 1976 Firebird dash also. It is brighter and I really like them. They do not dim but it is not a problem. I have replaced all of the bulbs on my car with LED except for the headlights but they are way expensive.
Old 03-25-2024, 07:21 PM
694.1 694.1 is offline
In post 6, there is a strange Park RNDSL that appears to be on the column?
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 03-25-2024, 08:25 PM
Bill Hanlon's Avatar
PRNDSL was from the factory on SuperHydramatic equipped Pontiacs from 1956 through 63 if I remember right. Besides that, the S stood for "Super", which is pretty cool.
Ben's profile says he has '67 GTO, '67 LeMANs, '71 LeMans, but no one said they are stock.
