Old 03-25-2024, 01:11 PM
arbys's Avatar
arbys arbys is offline
Default Center link bushing---Where do I find them?
When pulling the pitman arm from the center link I messed up (destroyed) the rubber bushing with the metal insert. Where can I find one? It seems that I checked all the catalogs and can't find one or 2, I don't really want the whole centerlink.
Old 03-25-2024, 06:03 PM
Scott Thelander's Avatar
I may have one ,,,
I am just getting ready to post a few original Idler arms for sale
I will check ,,, I have a dozen centerlinks and tie rod assemblies in a barrel I can check
can you post a picture of yours ??
Scott
Old 03-25-2024, 06:38 PM
arbys's Avatar
Originally Posted by Scott Thelander View Post
I may have one ,,,
I will check ,,, I have a dozen center links and tie rod assemblies in a barrel I can check
Scott
I can't take a picture of the bushing because it's in 20 pieces.
Old 03-25-2024, 09:23 PM
I thought you needed the rubber debris washer flat dust boot donut sleeve thingy ,,, that is between the pitman arm
and the center link
I dont know about replacing the guts ... sounds like its time to replace the center link
Old 03-25-2024, 10:40 PM
gto4ben gto4ben is offline
What did you break?
There are four pieces inside the ends.
Old 03-26-2024, 02:21 AM
Geoff Geoff is offline
You need a new centerlink. I bought one from Summit last year, it was about $90.
Old 03-26-2024, 04:21 AM
arbys's Avatar
Originally Posted by gto4ben View Post
What did you break?
It would be the rubber bushing located between the pitman arm and the centerlink. It would retain the grease and protect pitman arm from wearing into the tapered shaft.
Old 03-26-2024, 04:52 PM
arbys's Avatar
Talking
This is the center link grease seal that I'm looking for Two of the pictures are my center link missing the seal and the other picture is the center link with all of the attachments. I need the two on the lower left of the picture.
ID:	631117   Click image for larger version
ID:	631118   Click image for larger version
The Following User Says Thank You to arbys For This Useful Post:
Old 03-26-2024, 04:59 PM
arbys's Avatar
I found it at Inline Tube. It's called center link "grease" seal.
The Following 2 Users Say Thank You to arbys For This Useful Post:
Old 03-29-2024, 10:39 PM
arbys's Avatar
This is the grease seal:https://www.ebay.com/itm/196264336505
Old 03-30-2024, 10:34 AM
6d7gto 6d7gto is offline
Good to know...thanks for posting.
