What tool?
Makes these flares. Seems I’m bending my own fuel lines often, and some cars ( this is an old Mercury ) run inline fuel filters. I like to have a little flare in it for safety.
71' GTO -original 400/4-speed/3.23 posi 13.95 @ 102.1 on street tires @ 4055lbs. ‘63 LeMans- ‘69 400 w/ original transaxle. 2.69 gears. |
Sorry, pic didn’t post-
Beading is the process
A man who falls for everything stands for nothing. |
The Following User Says Thank You to Formulas For This Useful Post: | ||
I’ve used a double flaring tool and stopped part way through the first flare to end up with something close to that.
There used to be a tool for raising the surface of the tube because I used them when I was in school many years ago. I don't know if they are still made or not. It slipped inside the tube and expanded it from the inside.
https://www.grahamtool.com/tube-bead...e-beading-tool Looks like a nice tool but not inexpensive. Maybe there are more budget-friendly knock-offs? Or maybe you could find a local shop, like a hose fabricator, with a commercial version that could do it for you? I'd be trying b-man's approach on my budget. |
The Following User Says Thank You to Shiny For This Useful Post: | ||
Something like the flare on the bottom sample?
I'm to cheap to go looking for an expensive tool. I often just solder on a ferrule from compression fitting. It's a little too big, so you then have to grind off some of it. I know it doesn't look OE but it is always hidden under the rubber tubing and probably behind a spring type hose camp.
How about an AN to Barbed fitting? Then just flare the steel line?
Go Fast... Return... Go Fast Again... Who cares about left turns??? |
Yes that’s pretty close to what you want.
Yes. I’ve put regular single flares in lines in the past, and it can be a pain to get the lines on. It doesn’t have to be perfectly like the bubble I pictured, but something to hold the rubber line in place.
This is what was coming out of my fuel pump, and then 2 1/2’ of rubber line to the filter, a liability! Rather have a tool, than rely on having fittings and such around that I always seem to be out of. Thanks everyone.
I have made hundreds of feet of fuel and brake line with the Mastercool hydraulic flaring tool. It's a little pricy but does it all. Double flare, ISO flare, quick disconnects, barbs, it does it all. 3/16-3/8".
The Following 2 Users Say Thank You to mgarblik For This Useful Post: | ||
I use the mastercool tool and just use a partial squeeze with the first flare step of a double flare process, as mentioned above
George
Throw your old flaring tools in the trash!!!
Thread Tools | |
Display Modes | |
