Old 03-27-2024, 05:15 PM
srmmmm's Avatar
srmmmm srmmmm is offline
We're getting closer. The hood now closes with enough clearance for the air cleaner housing. The last three items are installation of the wood grain IP insert, front end alignment and state inspection. Then I can get plates and hit the road!
Name:	#50 3 Qtr Stance.jpg
ID:	631189   Click image for larger version
Name:	#53 IP Woodgrain Due.jpg
ID:	631190   Click image for larger version
Name:	#51 Scoop Fits.jpg
ID:	631191   Click image for larger version
Name:	#54 Hood Closes.jpg
The Following User Says Thank You to srmmmm For This Useful Post:
  #42
Old 03-28-2024, 09:30 AM
Tempest's Avatar
Tempest Tempest is offline
beautiful car, well done
  #43
Old 03-28-2024, 07:34 PM
Gator67's Avatar
Gator67 Gator67 is offline
Very nice, great work!
  #44
Old 04-05-2024, 11:19 AM
srmmmm's Avatar
Got some bad news from the restoration shop after getting the front end aligned the tech took the car out for a brief test drive and discovered that the rear axle was able to travel 7 miles without any lube in it before seizing up.
I knew the first shop that started on the car 20 years ago had gone through the axle, what was supposed to be a 3.23 posi with the 30 spline axle shafts, installing a new clutch pack and seals. Everything was supposed to be ready to go. Fast forward to 2018 when the serious work starts at shop #2 and I advise them of the axle rebuild thinking "It's ready to go". None of us ever checked the rear end for oil.
In the long run, it will work out better because on tear down, we discovered it was a 2.41 posi with the 28 spline shafts! So a new Dana or Auburn carrier with the proper 3.23 Richmond gears and Moser 30 spline axles are going in to it now. What's another $1300 and a few more weeks to get it correct, right.
  #45
Old 04-05-2024, 11:24 AM
chuckies76ta's Avatar
Dam, Thank Goodness that's all it was. Easy fix like you say though.
950 Quickfuel.
  #46
Old 07-29-2024, 10:45 AM
srmmmm's Avatar
Finally home! After almost 7 years of shop time (which included covid and personnel change storage time), "The Bird" is in my driveway.
Just needs a state inspection and tags, and a little bit of quadrajet tweaking and it's ready for weekend outings. It's not happy trying to run below 1500 rpm right now.
Name:	#55 At Home.jpg
The Following 8 Users Say Thank You to srmmmm For This Useful Post:
  #47
Old 07-29-2024, 12:01 PM
KS circutguy's Avatar
Beautiful ride.
  #48
Old 07-29-2024, 12:50 PM
Thumbs up
Real Stunner for sure.
Congrats on getting there with it.
  #49
Old 07-29-2024, 12:57 PM
SD455DJ SD455DJ is offline
Beautiful! Love that Coronado Gold...especially on a Formula! Nice work!
Dennis
  #50
Old 07-29-2024, 02:14 PM
Agree!
Awesome.
Congrats on getting it back.
Headin out on the Hi-way, lookin for Adventure?
  #51
Old 08-01-2024, 09:50 PM
Looks great - congrats!
