Curious.I've been reading about that large IA block with one main missing due to rod breaking. Thermal welding the new piece in place. For you high end guys is this repair safe with all the $$ spent?
Forget that it is safe. It is too costly and not ever worth doing.
https://www.youtube.com/watch?v=vgdeN7Muvhw Old thread: https://forums.maxperformanceinc.com...=welding+block |
The Following User Says Thank You to 65madgoat For This Useful Post: | ||
It was very fascinating to watch and it makes me wonder if the origional casting molds for that block are still around and can be redeployed. With the cylinder head advancements now available, building a 600+ CI engine is far more practical now than when this block was cast.
Speaking of practicality, unless you're stupid rich and can afford not to be practical, this was nothing more than a "yes, it can be done" process. Now that I know in theory and with enough money, I can have my 557 block "thickened/reinforced" at a cost much much higher than a new aftermarket block...
1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph 1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car. 1980 Formula 350 Pontiac back burner project 1972 LeMans 350 Pontiac |
I never heard of that big CID IA block. I was interested in the tech. However for cost I was thinking just buy new.
They act like that IA1 block is some super rare and desirable piece. Just buy a IA2, done.
The Indian head logo is cool though. |
![]() Quote:
Did I miss understand about that block? Isn't that a tall deck height block they are fixing? Stan
Yes tall deck
LIFT HEAVY, LIFE IS TOO SHORT TO BE SMALL! |
IndianAdventuresTTF!
Yep, tall deck, not available any more to my knowledge.
Do you guys think they were able to save it? Did not see an updated video so was guessing that it maybe didn’t work out…
![]() Quote:
Any cast iron welding is a risk. |
Does anyone know if the tall deck height blocks had a raised cam location?
Stan
Yes it did
Dragncar you are saying make a plate similar to a honing plate then install sleeves to the height of the plate? Would head bolts hold everything in place then?
I believe I remember seeing that McCarty did something like that at one time.
Steve Barcak did something like that to a big inch configuration on a 370 (or was it a 389) block I thought.
79 Trans Am WS6 71 Formula 72 Formula 71 Firebird 69 Firebird Last edited by hojs69; 04-11-2024 at 10:58 AM. Reason: engine size |
Old post from 2014 from Steve.
"My 577" is a '59 389 with a .315" over stock bore and stroked 1.050"! This was done around 20 years back in an effort to have the largest Pontiac ever. The problem with boring out the stock cylinders is that the deck is not strong enough to support it. I learned this from Ken Crocie, he had told me he had tried it years earlier and the decks lost so much strength, it would not work. The way I made mine work was to use deck plates that raised the deck and added the support needed for integrity. I ordered custom extra long sleeves to accomplish this. Again, this was very expensive and time consuming and before the aftermarket blocks were available. If you can access a boring bar to use as I did, you can try all sorts of things but, as others said, you are better off seeking a 400 block." I know he showed pics and all but I cannot find it right now. Hopefully he weighs in. Ahead of his time here.
79 Trans Am WS6 71 Formula 72 Formula 71 Firebird 69 Firebird |
Bill,
Thanks. Do you happen to know how much the cam was raised? Stan
No, I just remember that because I was going to do a tall deck at one time and decided against it.
![]() Quote:
![]() Stan
Thread Tools | |
Display Modes | |
