65-66 RamAir question
I know this will make some wonder, what the H***, but I was asked this question today.
How is a ramair pan correctly installed?? I replied "loosen the base nuts if necessary, set the pan on the 3 carbs, set the air cleaners on the pan over the studs, set the chrome lids on the studs, and wing nut them down". The guy says he bought the pan over the counter in 1968 and it came with a complete std. 3X2 filter set up. He said " if it came with these parts, they must be needed. Should I put the bases under the pan or inside the pan"? I had no answer. Your thoughts please!!! "Bill"! |
The pan replaces the bases,
The Wolf has howled (spoken) and is correct.
As Wolf 🐺 said, no bases needed.
The three dimples on the inside of the RA pan at each carb hole support the bottom of the filter.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A). 2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option. |
The ACDelco A220C replacement paper filters will rest above the dimples.
If you have the original style foam filters with the original screens, the screens will rest on the dimples. |
Thread Tools | |
Display Modes | |
