Old 04-13-2024, 06:02 PM
hisgto's Avatar
hisgto hisgto is offline
Default 1966 GTO Parts For Sale
I did a restomod to my 1966 GTO and have some parts available for sale.
Located in El Cajon, CA 92020
PM your cell or email for more info or pictures on specific parts.
Air Cleaner - Edlebrock - $20
Back Up Light Assys (2) - $40 Pair
Battery Hold Down Bracket & Bolts - $20
Blower Motor - $40
Blower Motor Cover - $60
Carburetor Holly Street Avenger (Needs Rebuild) - $100
Core Support Lower for 15.5" Radiator - $150
Crank Pulley Steel - 2 Groove - 1972 - $40
Dash Bezel Non Air - $250
Defrost Duct - $50
Distributor - TSP Pro Billet - JM7604R - New - $125
Door Handles - $65 Pair
Door Sill Plates - $35 Pair
Fan & Shroud Assy 15" Tall - Cold-Case - $125
Fan & Shroud Assy 17" Tall - Cold-Case - $125
Fan 7 Blade - $50
Fan Clutch - $20
Fan Guard Chromed - Driver's Side Hole - $75
Gas Tank Straps - $20 Pair
Grills LH & RH - $150 Pair
Heater Core Box - $250
Heater Hose Bracket - $20
Hurst Competition/Plus Shifter Stick - 5386836 - $100
Intake Manifold Four Barrel - Steel - 1972 - $100
Kick Panel Vent Passenger Side - $75
Kick Panels - $95 Pair
License Plate Light Assy - $20
Oil Pan - 1972 - $75
Parking Lamp Assy (2) - $75 Pair
Radiator Cold-Case GPG34 (2) - $300 Ea
Radiator Mount Lower (2 Sets) - $20 Ea Set
Rally Gauge Cluster - $300
Rally Gauge Cluster Tach - $100
Rear Control Arm Stiffeners - $40 Pair
Rear Upper Control Arm Bushings Axle Side - $10 Pair
Rear Upper Control Arms W/Bushings - $75 Ea
Seat Belt Retractor Covers - $20 Pair
Seat Tracks Driver Side - $75
Seat Tracks Passenger Side - $75
Tail Light Bezels - $300
Valve Covers w Filler Cap 67-77 - $100
Visors - $100
Washer Bottle Bracket - $20
Water Pump Pulley 8" Billet 2 Groove - 1972 - $140
Water Pump Pulley 8" Steel 2 Groove - 1972 - $40
Window Cranks (2) - $30 Ea
Window Regulators Front Driver - $75
Window Regulators Front Passenger - $75
Window Regulators Rear Driver - $45
Window Regulators Rear Passenger - $45
Some people say I have A.D.D., but they don't know what they're talk ... hey look, a chicken!
Old 04-14-2024, 11:08 AM
GOAT WHORE's Avatar
GOAT WHORE GOAT WHORE is offline
Pm sent.
1969 GTO 4spd. Antique Gold/black, gold int.
1969 GTO RAIII 4spd. Verdoro Green/black, black int.
1969 GTO 4spd. Crystal Turquoise, black int.
1970 GTO 4spd VOE Pepper Green, green int.
1967 LeMans 428 Auto. Blue, black int.
Old 04-14-2024, 04:19 PM
GTO_6970 GTO_6970 is offline
PM sent
Old 04-14-2024, 06:43 PM
RLEngland RLEngland is offline
PM Sent.
Old 04-14-2024, 08:47 PM
hisgto's Avatar
GTO_6970
Here is a pic of each. No problem to take more.
ID:	632079   Click image for larger version
ID:	632080   Click image for larger version
ID:	632081   Click image for larger version
Old 04-14-2024, 08:54 PM
hisgto's Avatar
BTCS
Here is a pic of the core support lower.
It's in great shape. I had it removed by my body shop to install the 17.5"
Let me know if you want more pics.
Old 04-14-2024, 08:59 PM
hisgto's Avatar
GOAT WHORE
Sent you a text and pictures through Whatsapp.
Let me know if you got them.
Old 04-15-2024, 06:46 PM
hisgto's Avatar
Dash Bezel Non Air - SOLD
Rally Gauge Cluster - SOLD
Rally Gauge Cluster Tach - SOLD
Core Support Lower for 15.5" Radiator - SOLD
Old 04-16-2024, 12:50 AM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
Do you have the black plastic water shields which go behind the backup lights?
Old 04-16-2024, 01:02 AM
65 Lamnas's Avatar
Sent you a private.
Old 04-16-2024, 01:11 AM
65 Lamnas's Avatar
Originally Posted by 65 Lamnas View Post
Sent you a private.
Make that 2
Old 04-17-2024, 11:06 PM
hisgto's Avatar
I do not.
Old 04-17-2024, 11:15 PM
hisgto's Avatar
One of the 15.5" radiators is SOLD
I still have another and a matching shroud with fans.
I will upload some pictures of the parts still for sale.
Also, the messaging through the forum seems to be somewhat slow.
If you are interested in any of the parts, please WhatsApp(preferred) or text me instead.
619-890-5413
Name:	Air Cleaner - Edlebrock.jpg
ID:	632249   Click image for larger version
Name:	Back Up Light Assys (2).jpg
ID:	632250   Click image for larger version
Name:	Battery Hold Down Bracket & Bolts.jpg
ID:	632251   Click image for larger version
Name:	Blower Motor Cover - Blower Motor.jpg
ID:	632252   Click image for larger version
Name:	Carburetor Holly Street Avenger (Needs Rebuild).jpg
Old 04-17-2024, 11:18 PM
hisgto's Avatar
More Pics
Please WhatsApp(preferred) or text me if you want more pics or need more info on a part. 619-890-5413
Name:	Crank Pulley Steel - 2 Groove - 1972.jpg
ID:	632254   Click image for larger version
ID:	632255   Click image for larger version
Name:	Distributor - TSP Pro Billet - JM7604R -  New.jpg
ID:	632256   Click image for larger version
Name:	Door Handles.jpg
ID:	632257   Click image for larger version
Name:	Door Sill Plates.jpg
Old 04-19-2024, 05:43 PM
hisgto's Avatar
Rear Control Arm Stiffeners - SOLD
Seat Tracks Driver Side - SOLD
Seat Tracks Passenger Side - SOLD
Below is what is still for sale and some more pictures.
If you are interested in any of the parts, please WhatsApp(preferred) or text me.
619-890-5413
Blower Motor - $40
Defrost Duct - $50
Fan & Shroud Assy 15.5" Tall - Cold-Case - $125
Fan & Shroud Assy 17.5" Tall - Cold-Case - $125
Fan 7 Blade - $50
Fan Clutch - $20
Visors - $100
Name:	Radiator Cold-Case GPG34 (1).jpg
ID:	632329   Click image for larger version
Name:	Fan & Shroud Assy 15 Tall - Cold-Case .jpg
ID:	632330   Click image for larger version
Name:	Fan & Shroud Assy 17 Tall - Cold-Case .jpg
ID:	632333   Click image for larger version
Name:	Fan 7 Blade - Fan Clutch.jpg
ID:	632334   Click image for larger version
Name:	Fan Guard Chromed - Driver's Side Hole.jpg
Old 04-19-2024, 05:46 PM
hisgto's Avatar
More Pics
Name:	Gas Tank Straps.jpg
ID:	632336   Click image for larger version
Name:	Grills LH & RH.jpg
ID:	632337   Click image for larger version
Name:	Heater Core Box.jpg
ID:	632338   Click image for larger version
Name:	Heater Hose Bracket.jpg
ID:	632339   Click image for larger version
Name:	Hurst CompetitionPlus Shifter Stick - 5386836 .jpg
Old 04-19-2024, 05:49 PM
hisgto's Avatar
Pics
Name:	Intake Manifold Four Barrel - Steel - 1972-1.jpg
ID:	632341   Click image for larger version
Name:	Kick Panel Vent Passenger Side.jpg
ID:	632342   Click image for larger version
Name:	Kick Panels.jpg
ID:	632343   Click image for larger version
Name:	License Plate Light Assy.jpg
ID:	632344   Click image for larger version
Name:	Oil Pan  - 1972.jpg
Old 04-19-2024, 05:52 PM
hisgto's Avatar
Even More Pics
Name:	Parking Lamp Assy (2).jpg
ID:	632346   Click image for larger version
Name:	Radiator Mount Lower (2 Sets)-1.jpg
ID:	632347   Click image for larger version
Name:	Rear Upper Control Arms WBushings.jpg
ID:	632348   Click image for larger version
Name:	Seat Belt Retractor Covers.jpg
ID:	632349   Click image for larger version
Name:	Tail Light Bezels.jpg
Old 04-19-2024, 05:54 PM
hisgto's Avatar
Almost done . . .
Name:	Valve Covers w Filler Cap 67-77 .jpg
ID:	632351   Click image for larger version
ID:	632352   Click image for larger version
Name:	Washer Bottle Bracket.jpg
ID:	632353   Click image for larger version
Name:	Water Pump Pulley 8 Billet 2 Groove - 1972.jpg
ID:	632354   Click image for larger version
Name:	Water Pump Pulley 8 Steel 2 Groove - 1972.jpg
Old 04-19-2024, 05:58 PM
hisgto's Avatar
That's all the pics.
If you want more pictures or information or want to haggle the price, please WhatsApp(preferred) or text me.
619-890-5413
Name:	Window Cranks (2).jpg
ID:	632356   Click image for larger version
Name:	Window Regulators Front.jpg
ID:	632357   Click image for larger version
Name:	Window Regulators Rear.jpg
