Old 04-17-2024, 09:08 PM
slowbird's Avatar
slowbird slowbird is offline
That is definitely a large header. Not sure if you're trying to get the 80tq that your dad is up or what you're looking to gain. But my honest opinion is it'll take a combination of intake and header work. If the plenum is so large you're having issues on the leave that's definitely not right and you will see gains once that is fixed (I'd bet your shift recovery is bad also due to it).
One thing you could do with the headers is move to a 4 or 4.5 inch collect and lengthen it. See how that works. I'm guessing yours are removable so that would be a very easy thing to test.
Fwiw, I ran 2 1/8 to 2 1/4 4" collector on my 1050hp 511ci.
Old 04-17-2024, 09:18 PM
Matt1970gto Matt1970gto is offline
I just want all I can get & not pull the motor out every 4 or so passes. Apples to apples dads dyno #s were with his two 1050s so I was happy to get as close as I did. His motor made peak trq @ 5800 & mine @ 6700. Peak hp for him was around 7600 & for me over 8000 each piull. As far as shift points once it clears up it’s pulls strong through both shifts. 2.24 lenco 4.56 rear it leaves hard.
Old 04-17-2024, 09:37 PM
slowbird's Avatar
Interesting, how different are the cams? By the numbers you posted it would seem your cam is quite a bit bigger?
Old 04-17-2024, 10:25 PM
Launch RPM?
Dads is 280/294 .855 .837 115 lobe sep
Mine 284/306 .954 .936 121 lobe sep
Old 04-17-2024, 10:40 PM
slowbird's Avatar
Just curious who picked/made you cam?
I would try another cam.
Old 04-17-2024, 11:01 PM
Engine builder & LSM.. I had a twin to dads cam in it at first but it was worse.
Old 04-18-2024, 08:24 AM
PAUL K's Avatar
PAUL K PAUL K is offline
There is going to be a huge difference between those two cams. That second one is going to move the power band much higher in the RPM range.
Go fast, see Elvis!
Old 04-18-2024, 09:23 AM
Yea, dad’s motor only dropped 11hp from 7000-7800 but by 7800 it was dropping. My motor just starts making good #s @
around 7800 & I pulled it to 8400. Only 7 passes on this setup & no clean runs yet but I was only crossing @ 7550-7600 @ Gainesville for the gator nationals this year.
Old 04-18-2024, 09:27 AM
Stan Weiss's Avatar
Can you post dyno sheets for both engines?
What does each engine have for stall speed?
Stan
Pontiac Pump Gas List
Old 04-17-2024, 10:34 PM
My heads were also hogged out. Once dad’s new set of 5s & his new intake are ready I’ll decide whether I take his old heads or back up & punt. These 5s made good #s on the dyno but we haven’t seen the gains on the track to match the #s. I gained 100hp & lost 60ft lbs of trq compared to my 535 with 11 degree eldebrocks. Dad gained 140hp & about 80 fr lbs trq over his 535 11degree combo. We throttle stop race & the cars are running the same mph with this combo than the old. Both 535s had cams in .763 .780 range & both cars went 5.20s on a single carb i@ Huntsville Dragway.
Launch RPM?
Old 04-17-2024, 10:26 PM
Launch RPM?
Sorry it didn’t post the 1st time for some reason but 5800.
