Old 04-17-2024, 10:25 PM
Matt1970gto Matt1970gto is offline
Launch RPM?
Originally Posted by slowbird View Post
Interesting, how different are the cams? By the numbers you posted it would seem your cam is quite a bit bigger?
Dads is 280/294 .855 .837 115 lobe sep
Mine 284/306 .954 .936 121 lobe sep
Old 04-17-2024, 10:40 PM
slowbird's Avatar
slowbird slowbird is offline
Just curious who picked/made you cam?
I would try another cam.
Old 04-17-2024, 11:01 PM
Engine builder & LSM.. I had a twin to dads cam in it at first but it was worse.
Old 04-18-2024, 08:24 AM
PAUL K's Avatar
PAUL K PAUL K is offline
There is going to be a huge difference between those two cams. That second one is going to move the power band much higher in the RPM range.
Go fast, see Elvis!
Old 04-18-2024, 09:23 AM
Yea, dad’s motor only dropped 11hp from 7000-7800 but by 7800 it was dropping. My motor just starts making good #s @
around 7800 & I pulled it to 8400. Only 7 passes on this setup & no clean runs yet but I was only crossing @ 7550-7600 @ Gainesville for the gator nationals this year.
Old 04-18-2024, 09:27 AM
Stan Weiss's Avatar
Can you post dyno sheets for both engines?
What does each engine have for stall speed?
Stan
Pontiac Pump Gas List
Old 04-18-2024, 10:47 AM
Stan
Both have 6400.
ID:	632274   Click image for larger version
Old 04-18-2024, 10:54 AM
Is your throttle stop/delay one that has you at an idle/set rpm then opens when ready to go, or on the mat and the 2 step keeps it at a set rpm until ready to go?
Nice dyno sheets!
Old 04-18-2024, 12:06 PM
Stan
Nice dyno sheets!
My stop rpm is 3750 & remain in low gear while on the stop.
