#41
Old 04-13-2024, 08:14 AM
Cammer-6 Cammer-6 is offline
Gary, great to see another 67 AIR air cleaner survived! You don't still happen to have the FH stamp you had made do you? I was thinking of having one made with 1" tall 1/2" wide letters but if you still have yours I could borrow or buy it off of you.
Im sure I do
will PM you when its found
Another thing that comes to mind was a bright pink "spot"
IIRC I duplicated with spray paint as it looked rather line assembly applied.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
  #42
Old 04-13-2024, 10:09 AM
how good is your label on air cleaner?
might be time to repop it.
  #43
Old 04-14-2024, 01:01 PM
Thanks Gary, I will dig out my aircleaner and check the label's condition
  #44
Old 04-14-2024, 07:47 PM
mine has 2 labels one on top of the other.
either the wrong one was put on first or it was upside down
  #45
Old 04-17-2024, 06:06 PM
Here is my Placard Gary not perfect by any means. Plus I added picutes of my battery tray that just came back from the powder coaters in the other tread
  #46
Old 04-18-2024, 07:25 AM
that should be good enough to replicate.
Mines in about same shape but is double layered
Many,many years ago I got into a discussion with Jim Osborn on the color of the metallic print.
I say its gold,Jim said"golds too messy,its silver"
I have an NOS 68-9 and its gold. Im pretty sure the color fades with age.
  #47
Old 04-22-2024, 01:30 PM
(Note the 69 Bird was missing the entire A.I.R. system when I bought it in CA back in the early 1990's.
Did 69 OHC's still have California emmisions? NO 69 V8 Pontiac's had any California specific smog stuff installed.
Old 04-23-2024, 08:30 PM
North you may be correct that the 69's didn't use a smog pump. I remember the exhaust manifold on my 69 had the A.I.R holes drilled in it, but that they where capped off. I just assumed it originally had a pump.
