Distributor
I have New spark plug wires Coming For my 67GTO. I. Set the crank mark at top dead center, #1 cyl on compression stroke. The car ran when i pulled the engine. I never pulled out the distributor. The vacuum advance is pointed at driver fender, but the router is pointed at the center of firewall. I read it should be pointed more toward the brake pedal.
Attached a pic, does this look ok? |
Fort Worth/Dallas TX area 1966 GTO Fontaine Blue 389 CID Carter AFB Muncie 4 speed (orginally an automatic car) |
If you did not move the distributor relative to the engine, just start wiring with # 1 at the dist. rotor position and go counter clockwise. If you want it to look correct, you need to reposition the distributor. Looks like the previous person inserted the dist slightly off. It will still work correctly if you start with the #1 wire at the rotor position.
To get it to look correct, leave the engine at #1, top of compression stroke. Pull the dist, and reinsert such that the rotor rotates into the desired position. You may need to adjust the position of the oil pump drive shaft slightly to get the dist to drop in, since the dist rotates as you drop it in due to the helical drive gear. George
Like George said.
I have found that holding the distributor with vacuum advance pointing 90° of engine centerline and turn rotor to point the same way, when distibutor is mounted the rotor will be properly located due to the helical gears. |
Thread Tools | |
Display Modes | |
