Old 05-07-2024, 03:30 PM
Bandit400 Bandit400 is offline
Default Gauge Cluster Year/ID help?
Hey all, I'm going to look at a gauge cluster tonight. I think k it is early 70s, but I can't find any definitive identification for the differences on these. The cluster I'm looking at has the following:
8k tach
160 Speedo
Brake Light only on speedo, no seat belt light that I can see.
260 degree max water temp gauge. ( all the others in my research are 250 degree max)
Yellow on tach starts at 5250 rpm, redline starts at 5750rpm.
Connector on printed circuit looks to have 12 contacts.
What is this? 1970 possibly? A frankenstein? What are some other identifiers I can check? What's a fair price? I'll try to get a pic, but no guarantee before I go to see it.
Old 05-08-2024, 03:22 PM
Transamric's Avatar
Pictures??
Old 05-08-2024, 08:08 PM
Formulabruce's Avatar
Color of clock knob. Black was 70- part of 71. That should nail it down enough
" Long may we DRIVE !"
Old 05-08-2024, 09:11 PM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
One or two terminal tach?
So long, farewell.
Old 05-09-2024, 12:06 AM
I saw a black clock knob on my brothers original paint survivor 72 ta yesterday !
The Following 2 Users Say Thank You to Tellyshavilli For This Useful Post:
Old 05-09-2024, 08:44 PM
Wow!, never have seen it on a 72, but we did a tach on a 72 at end of its warranty and we were sent one with a black knob.. on the clock.
Old 05-09-2024, 08:53 PM
necdb3's Avatar
necdb3 necdb3 is offline
My late production 72 has the black knob also my old early production 72 Formula 455 had the black knob. Chrome started in 73
Old 05-09-2024, 10:04 PM
Same here, 03E very late '72 production T/A, black cloverleaf style clock knob.
The Following 2 Users Say Thank You to 'ol Pinion head For This Useful Post:
Old 05-10-2024, 06:22 PM
unruhjonny's Avatar
based on the speedo alone, it sounds like a 70-72.5 cluster.
there were two style black clock knobs, but that's getting into the minutia...
iirc the 70-72.5 used the smaller plug in the back.
now, if it's a hodge-podge, all bets are off.
look on the back of the housing to see if an early speedo was swapped in place of a later one.
Tachs (contrary to reproduction literature) were 8krpm through to 1976;
As of 1977, the limit reduced.
The 1970 tachs only have a single male connector - starting in 1971 there are two - because starting in 1971 you could get the 'unitized' distributor (precursor to the HEI that Pontiacs received in 1975).
There should normally be a printed (ink stamped) date on the circuit board.
The combination water temp & oil pressure gauge changed after 1972 iirc, but they are a direct replacement;
early ones had a temp reading @ 12=o'clock of 210 degree, the later ones were 220 degrees.
I hope that something here helped!!
1970 Formula 400
