#1981
Old 06-21-2024, 09:15 AM
Glad to see you enjoying it!
  #1982
Old 06-23-2024, 03:14 PM
Glad you were able to build the vision you had in your head and getting to enjoy it.
Roll on
  #1983
Old 06-23-2024, 10:28 PM
64speed's Avatar
64speed 64speed is offline
Thank you! I still have to put the quarter panel boards on the inside and do the headliner but that’s gonna be a while. Got some home projects that are taking up all the money
  #1984
Old 06-24-2024, 10:42 AM
rohrt rohrt is offline
What make you think that adjustable A-arms will fix your vibration?
  #1985
Old 06-24-2024, 10:49 AM
64speed's Avatar
Pinion angle is off a little
  #1986
Old 06-24-2024, 12:57 PM
AKA pinion angle at the rear u-joint of driveshaft for anyone not sure what's up.
Transmission yoke supposed to angle below horizon , axle pinion angle above horizon.
  #1987
Old 07-03-2024, 02:27 PM
64speed's Avatar
Just thought I’d show off a little bit. Car is running great. Gonna put the adjustable control arms on as soon as I’m able but it’ll be awhile because I am facing another surgery soon. No matter what I do I can’t get the pic to orient right. Please someone rotate it
  #1988
Old 07-03-2024, 02:30 PM
Thumbs up
Cropped and rotated.
Looking great!
Perfect stance.
One of my favorite cars.
  #1989
Old 07-03-2024, 04:07 PM
Bill Hanlon's Avatar
Goes faster down that steep hill.
  #1990
Old 07-03-2024, 05:16 PM
64speed's Avatar
Looking great!
Perfect stance.
Thank you!
  #1991
Old 07-05-2024, 11:17 PM
Looks Really Sharp .
Probably runs like a demon
  #1992
Old 08-07-2024, 06:39 PM
64speed's Avatar
So I got stuck in bumper to bumper traffic yesterday for about 30 mins. This is my take away and any help would be appreciated. My car runs at the thermostat (180) or lower as long as I am moving. In the traffic it got up to 203 before I got antsy and turned the AC off and rolled down the windows. As soon as I did that the temp started dropping, I mean immediately. I started moving again so I never got to see just how far it would fully drop but it was obvious it was under control. I know 203 isnt overheating but I didnt want to find out what my upper limit is on a 4 lane highway. I am gonna take it and see if its charged properly in case thats whats taxing the engine so heavily but short of that does anyone have any suggestions?
  #1993
Old 08-07-2024, 07:17 PM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Running A/C introduces heat (a lot) in front of your radiator. If the A/C was blowing constant cold, it's probably charged correctly. The early cars have a serious disadvantage compared with later years. That is, small frontal area of the radiator. Making it thicker is diminishing returns. By the time the air hits the rear rows, it's already saturated with heat.
  #1994
Old 08-07-2024, 10:08 PM
If you have electric radiator fan (idunno)
They are set to come on and run anytime and all time while a/c is working - in most all passenger cars.
Most have 2 speed fans - and will run on high speed while a/c is working.
In case yours is just set to run by thermo control - or just one speed.
fwiw
  #1995
Old 08-08-2024, 05:57 AM
64speed's Avatar
No I have a clutch fan
  #1996
Old 08-10-2024, 11:28 PM
64speed's Avatar
IF I decided to put an electric fan on the condenser alone how do I want it configured? Pushing or pulling
  #1997
Old 08-11-2024, 06:31 AM
Holeshot71's Avatar
Holeshot71 Holeshot71 is offline
What was your idle rpm when this was happening?
'71 GTO, 406 CID, 60916, 1.65 HS, '69 #46 Heads 230CFM, 800CFM Q-jet, TH400, 12 Bolt 3.55
'72 Lemans, Lucerne Blue, WU2, T41, L78, M22, G80
The Following User Says Thank You to Holeshot71 For This Useful Post:
  #1998
Old 08-11-2024, 07:04 AM
Good question. And where is your vacuum advance connected, full time or ported?
I seriously doubt you can fit an e-fan as a puller since the existing fan probably takes up most of the room. So, pusher.
But, an e-fan may bring on other problems, like electrical/charging system, especially if it's stock.
203 isn't overheating by the way. That's about what mine runs w AC on in stop & go, 195/205.
EDIT: And it would be best to run some kind of a controller, PWM type preferable.
  #1999
Old 08-11-2024, 07:25 AM
64speed's Avatar
Right at 850-900. 203 is just where I cut it off I really think it would go higher. I guess if I get trapped I’m just out of AC if the creep doesn’t stop.
  #2000
Old 08-11-2024, 07:26 AM
64speed's Avatar
I am connected to full manifold. My alternator is 105 amp.
