Old 03-30-2018, 09:23 PM
PAUL K's Avatar
PAUL K PAUL K is offline
That's good news, but the bad news is they're not made anymore!
Any other tailpipes that work?
Not sure. We tried a system from someone else and it was a major job installing the it, nothing fit. Torque Technologies was great! Pypes used to be good but have taken a turn for the worse.
Go fast, see Elvis!
Old 03-30-2018, 09:42 PM
form74's Avatar
form74 form74 is offline
Ramair has several exhaust system, But I don't see the splitters
https://www.ramairrestoration.com/ca...t=11&q=exhaust
I have their 3 inch pipes from the Ram Air Manifolds into an X pipe and then currently dumping behind the rear wheels. Ran out of time to have the tail pipes out the back car but should that done in the next few months.
Video of exhaust under the car
https://www.youtube.com/watch?v=m95cYNyy-y0
74 Formula
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Edelbrock 87 cc dport heads
Performer RPM
Old 03-30-2018, 11:41 PM
ErikW's Avatar
ErikW ErikW is offline
I have a Pypes 3" system on my wife's 71 T/A. Fit very well with Doug's headers. I added flex segments to reduce vibration.. Also used V-band clamps instead of collector reducers. If you could find 3 inch splitters I'm sure they could be made to work with that system. I used the 3" hockey stick tips like original to the 71.
ID:	479482   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 03-31-2018, 09:11 AM
PAUL K's Avatar
Your exhaust looks nice. I don't know if anything has changed recently but the splitters won't work with their standard tail pipes. Pypes offers an adapter kit for their 2.5" inch exhaust systems to use with their splitters. They never offered a kit for the 3" splitters... instead, they discontinued the big splitters because few people were able to make them fit.
Go fast, see Elvis!
Old 03-31-2018, 09:12 AM
PAUL K's Avatar
I'll be trying the Ram Air restoration's exhaust next time around. Your system is very nice.
Go fast, see Elvis!
Old 03-31-2018, 01:29 PM
ta man ta man is offline
That is a quality job! I like the flex segments , the heat shield at the back near the tailpipe and the new OEM style hangers.
Old 03-31-2018, 05:09 PM
ErikW's Avatar
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 03-31-2018, 07:28 PM
Does look good.
What rear disc setup?
Old 03-31-2018, 09:26 PM
Will Will is offline
Wish someone would make a good flowing 3" transverse style muffler.
ErikW - that system looks great!
Old 04-01-2018, 09:05 AM
ErikW's Avatar
Skip, rear brakes are a combination of late second gen rear rotors, front S-10, or mid-size GM calipers, and brackets I bought off of eBay. Work great, just no parking brake. Very low budget, calipers are $17 from AutoZone, brackets we're like $30 and rotors were $28 ea.
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 04-01-2018, 10:54 AM
Got you. My Camaro project 79-81 rear disc and brackets w/ just "plain" Malibu calipers. So similar.
Old 07-02-2024, 10:02 PM
grandville455's Avatar
That looks great!! Is that a 3.5” collector? What kind of v clamp setup is that? Is one side 3.5 n other is 3” roughly how long is it from the collector to where the X pipe attaches?
Darby
M/T 275/60 ET SS Drag Radial
Old 07-03-2024, 01:33 AM
wakesupremo wakesupremo is offline
This is interesting reading. My 469 powered '69 convertible has run a best of 11.4 @122 mph. This was on open headers and with a 1050 dominator. A few weekends ago whilst competing in the UK street weekend i had to fit an exhaust. I have a 2.25" Borla system that is regularly on and off the car depending on what im doing with the car. I lost a second and 8 mph on the quarter. This is also with a 950 HP carb. I have been pondering the loss and was told it was the exhaust to which several people have said that it wasn't the reason. This weekend I'm doing dragstalgia on open headers so will see.
If this proves to be the problem does anybody make a 3" kit for a '69 'vert?
Old 07-03-2024, 08:53 AM
That's hillarious people telling you a tiny 2.25" exhaust isn't slowing down a car that normally runs mid 11's @ 122 without it.
Something making that kind of power for sure needs a pretty good size pipe on it if you want to run through the mufflers and not lose too much.
I typically run 3" on stuff like that, and then use electric cutouts if I want the headers open for any reason. Then you won't be taking the exhaust on and off all the time, that gets old.
https://youtu.be/XqEydRRRwqE
Old 07-03-2024, 09:49 AM
I’ve been 9.40’s through 3” exhaust,depends on the whole combo!
Darby
Old 07-03-2024, 03:13 PM
You can certainly run quick with small exhaust, it's just a matter of making more power with the engine. Look how quick the fast guys are going with 2 1/2" exhaust.
What isn't realistic is running an et and mph such as the op with open headers and then expecting to do the same when slapping on a 2 1/4" exhaust system. That's just not goona happen. You're going to have to find missing hp somewhere else to make up for it, or just put an exhaust system on the car that's more deserving to start with and have an easier time with it.
Old 07-04-2024, 03:20 AM
Thanks for the replys again, but, My question was , does anyone make a good fitting 3" system for a '69 firebird 'vert?
  #38
Old 07-05-2024, 11:05 AM
Lee's Avatar
Lee Lee is offline
Jesus!! Your car is probably tuned very well for open headers. Choking it with a 2.25" system probably made the car run horribly rich.
Just installing better mufflers can make a big change to the AFR, requiring a change to the tune.
For pretty much any 3" system to fit GOOD, it will require an installer with the skills and equipment to make adjustments.
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
  #39
Old 07-07-2024, 10:50 PM
R 70 Judge's Avatar
R 70 Judge R 70 Judge is online now
Looks good! I have a Pypes 3” X system with tailpipes and 3” hockey stick tips on my 70 TA. It fit great. I went with 3” Hooker Aerochamber mufflers and vbands. The tailpipes got a little tight around the tanks Inc 20.5 gallon tank so they added some wrap. It sounds pretty amazing
Idle clip while tuning
https://youtu.be/-XGWLuEwyso?si=2x5QzMZohkvFneft
ID:	636450   Click image for larger version
ID:	636451   Click image for larger version
ID:	636452   Click image for larger version
James
1970 Trans Am
