Old 06-16-2024, 01:40 PM
cnc's Avatar
cnc cnc is offline
Default Chrome decor
Looking to see if someone has very nice set of the rocker panel thin mouldings…I have set but looking for a nicer pair…. my 73 has the chrome decor package
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
Old 07-11-2024, 12:00 PM
unruhjonny's Avatar
I am a bit confused by this;
The thin rocker panel molding was a base model and Formula part;
It had nothing to do with either model's options - or lack there of.
Maybe you mistyped what you're looking for - in which case my query might help you find what you're looking for
1970 Formula 400
Old 07-12-2024, 10:19 PM
Formula403 Formula403 is offline
https://www.firebirdcentral.com/1970...1_p/bcm-27.htm
Old 07-13-2024, 06:14 AM
cnc's Avatar
cnc cnc is offline
After the fact I should have said a different title option instead of decor …it is the lower rocker trim thin chrome strip
Old 07-13-2024, 06:15 AM
cnc's Avatar
cnc cnc is offline
Originally Posted by Formula403 View Post
Hi yes I ve seen this just unsure of quality?…
Old 07-13-2024, 10:52 AM
unruhjonny's Avatar
Ok, I figured that since I saw no replies in about a month, something should be said to clarify what you wanted.
I didn’t know they were now reproduced!
When I got my set maybe fifteen (probably more) years ago, I had to pull them off a donor car.
1970 Formula 400
