Old 07-14-2024, 11:00 AM
mrennie's Avatar
mrennie mrennie is offline
Default 70 GTO parts available for Norwalk
I'll be at Norwalk next weekend and have some left over stuff from my GTO project that I can bring. Much of it is new reproduction and I believe my pricing reflects a desire to move it.
As I am travelling with friends (wives need the truck for shopping), parts can only be delivered to the track Saturday afternoon (at time to be determined) or we can meet anywhere between the track and the Sandusky strip Saturday evening once we head back for supper. We can also meet up at the track Sunday morning or again in the afternoon (time to be determined).
Prices are USD, cash only. Please do not say you will take something if you have no intention of following through, as it will be a PITA to explain a pile of parts that I am bringing back to Canada and convince the border agent that they were already mine and not subject to import tax .
Send me a PM for the items you want and I will update the ad to show what is gone. I am loading my truck this coming Thursday night, so only items that have been committed to by then will be brought down.
At this time, I am only selling these parts for pickup at Norwalk and will not ship. If anything is not sold, I will look at shipping elsewhere at a later date.
New parts:
-reproduction quarter window sash channels, does not include weatherstripping (came from PY), slightly different than what Ames sells $10
-reproduction taillight set $150
-reproduction rad cap $15
-front fender to rad support brackets (these are improved and thicker than OEM) $15
-adjustable HEI vacuum advance (came off a Pertronix flamethrower, never used) $10
-reproduction gas cap $10
-reproduction vent line bracket & screw $5
-reproduction parking break pedal pad (I don't think it is correct for 70) $5
-gas tank insulation $15
-reproduction seat piping set $50
-rad support to front bumper filler panel $50
-reproduction formula wheel Sold
-trunk drop off plug $5
-outer door & quarter window felt sets (note: I bought this set just for the driver side quarter window felt as the first one I installed did not fit well on the aftermarket quarter panel that is on my car. The one from this set fit slightly worse so I did not use it.) $50
-1970 Catalina/Bonneville B-body assembly manual $20
-Griffin rad cap (17 PSI) $5
-ram air vent tube & grommet (notes: tube is zinc plated where originals were bare steel. It has a defect in it where the flange that fits against the grommet was created, it is split there and would leak air. It will require welding up the split to make it usable). $10
-Dash knob Ames #A274LJ $3
Used parts:
-black seat back and side covers. They have some scratches and are just starting to fade in a few spots, would be great for a driver, they just were not good enough to go with a complete new interior in my car. $100
-front fender parking light lenses. LH side has no cracks, good condition $30 RH side has a crack in the lens but still usable $15
-tack strips for headliner. These were cleaned and then primed in black epoxy. This is all of the pieces except for 2 small ones at the rear of the car. $50
-piece of hood brace from a 1970 hood. If you are putting the 68-70 repro hood on your car, be aware that the bracing is not correct for 1970 and will rub against the 70 fan shroud. The fix is to cut out the section of incorrect brace and weld in the proper piece from a 70 hood, then some minor filler & priming. The back side that will not be visible has some pitting but the front will be fine once blasted and welded in place. I will attach some pics of the work required when I have time. $10
-stainless trim for door and quarter panels. I had several sets and buffed them all then used the best ones for my project. What is for sale is a pair for the rear quarter panels, and 3 top pieces + 3 bottom pieces for the door panels (so enough to do a complete car with an extra set for the door panels). They are not perfect, but very good. $50
Let me know if you have any questions. I am out of town for work the next few days and my response could be delayed.
Thanks for your interest
ID:	636832   Click image for larger version
ID:	636833   Click image for larger version
ID:	636834   Click image for larger version
ID:	636835   Click image for larger version
Michael
1970 Oshawa built 1 option Judge. 24 year restoration/upgrade project finally finished!
1979 Trans Am - low-buck drag car project for when I retire
Old 07-14-2024, 11:09 AM
mrennie's Avatar
More pics
ID:	636837   Click image for larger version
ID:	636838   Click image for larger version
ID:	636839   Click image for larger version
ID:	636840   Click image for larger version
Michael
Old 07-14-2024, 11:12 AM
mrennie's Avatar
Some more pics
ID:	636842   Click image for larger version
ID:	636843   Click image for larger version
ID:	636844   Click image for larger version
ID:	636845   Click image for larger version
Michael
Old 07-14-2024, 11:14 AM
mrennie's Avatar
Even more pics
ID:	636847   Click image for larger version
ID:	636848   Click image for larger version
ID:	636849   Click image for larger version
ID:	636850   Click image for larger version
Michael
Old 07-14-2024, 11:16 AM
mrennie's Avatar
Still more pics
ID:	636852   Click image for larger version
ID:	636853   Click image for larger version
ID:	636854   Click image for larger version
ID:	636855   Click image for larger version
Michael
Old 07-14-2024, 11:25 AM
mrennie's Avatar
Door panel trim
Michael
Old 07-14-2024, 01:15 PM
steve v's Avatar
steve v steve v is offline
Michael, I'll take the left marker light and the ram air vent tube.
pm sent.
Old 07-15-2024, 07:21 PM
Goats & Birds Goats & Birds is offline
Hi Micheal
I am interested in the filler panel and possibly a couple other items.
My # is (320) 583-3073.
Thanks, Jon
Old 07-17-2024, 01:59 PM
mrennie's Avatar
3 day bump + updated list of what is available. Let me know by 10 PM tomorrow night if you want something brought down
New parts:
-reproduction rad cap SOLD
-front fender to rad support brackets (these are improved and thicker than OEM) SOLD
-reproduction parking brake pedal pad (I don't think it is correct for 70) $5
-gas tank insulation SOLD
-reproduction seat piping set SOLD
-rad support to front bumper filler panel SOLD
-reproduction formula wheel SOLD
-1970 Catalina/Bonneville B-body assembly manual - Reduced to $15.
-ram air vent tube & grommet (notes: tube is zinc plated where originals were bare steel. It has a defect in it where the flange that fits against the grommet was created, it is split there and would leak air. It will require welding up the split to make it usable). SOLD
Used parts:
-front fender parking light lenses. LH side has no cracks, good condition SOLD; RH side has a crack in the lens but still usable SOLD
Michael
