Old 07-18-2024, 09:28 PM
Here’s the problem with oil analysis; it requires multiple tests to establish a trend. They are correct; slightly elevated lead results COULD be nothing more normal break-in IF lead was still used in engine bearings. Modern bearing are faced with babbitt which is predominantly tin and antimony. If I were you I would pull another test when the engine has at least one thousand more miles on it along with an oil filter inspection.
Dr. Thomas Sowell
The Following User Says Thank You to hurryinhoosier62 For This Useful Post:
Old 07-19-2024, 01:22 AM
jhein's Avatar
jhein jhein is offline
So if the bearings are not faced with lead then that that would mean it's coming from deeper layers of the bearing (assuming that's still got lead) or somewhere else?
They mentioned fuel as a source. I buy my gas in bulk and it's 92 octane non-ethanol gas. I add Sta-bil and Lucas fuel treatment. I guess those could contain some lead.
They also mentioned blow by. My cold cranking compression was 175 psi +/- 2 psi. So I doubt I have excessive blow by.
Old 07-19-2024, 06:58 AM
On a bearing lead would have been the outer protective layer, after that layer you'll see high concentrations of copper which you dont have in your analysis.
Thing is I don't think they use lead anymore as the outer layer of a bearing that I'm aware of and tin is low too which I think is used as a replacement for the lead so I tend to think that's coming from somewhere else.
Being a new engine id do just as Hoosier recommended and go another 1000 miles and check again and compare.
https://youtu.be/XqEydRRRwqE
Old 07-19-2024, 10:50 AM
jhein's Avatar
That's what I was thinking. That if the lead was coming from a bad bearing there would be other abnormalities as well.
I don't really know anything about shear but can that depend on how the car it driven? For example if someone just puts around and the motor never sees any WOT vs someone who gives the motor WOT at least a couple times every time they drive? And if that's the case should I consider going to a 20w50?
Old 07-19-2024, 04:02 PM
Jay S's Avatar
Jay S Jay S is offline
Unless the engine has trouble maintaining oil pressure toward the end of the oil change, or the UOA was indicating that a thicker oil would help on wear, there would be no reason to change to the thicker oil. Heat is the top cause for extra shear, harder driving equals more heat. More heat cycles from longer oil change intervals would be another area that cause extra shear. Some oils shear more than others. It isn’t a problem until the UAO comes back and says it was showing extra wear from your UOA trends.
Old 07-19-2024, 05:16 PM
jhein's Avatar
Makes sense. Thanks!
Old 07-21-2024, 09:05 PM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
I had Blackstone do a UOA on a fresh engine with about 2K miles on it and it had a higher level of lead also, around 50 IIRC. Copper and tin were low and everything else looked good so they pretty much told me the same thing as thy told OP.
Was running Valvoline VR-1 conventional with no additives and always ran unleaded gas.
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
The Following User Says Thank You to TCSGTO For This Useful Post:
Old 08-04-2024, 07:45 PM
tjs72lemans tjs72lemans is offline
My oil was last changed in 2021, or three years ago. But, I was only driving about 700 miles/yr.
Old 08-05-2024, 09:55 AM
78w72 78w72 is offline
Same here... sometimes 1 or 2 of my cars dont get driven much for whatever reason, working on them or on something else, its hard to put lots of miles on multiple cars sometimes living in the midwest with a shorter driving season than those in year round warm climates.
If i have less than ~1000 miles on the car for the season I dont change the oil, its a complete waste, oil doesnt go bad sitting in the pan (or bottle) in that short of time, same for the filter. If the engine is healthy & not dumping raw fuel into the oil or other major issues like that, the additives neutralize any combustion by products and the anti wear additives dont go bad while sitting. My engines are clean lower mile rebuilds so no high mileage sludge or anything.
I also spoke to valvoline about long term use & was told the same thing, 1-2 years at low miles is not an issue at all, neither is new oil in the bottle for 5 years or more if stored properly. I have & use oils rated SN & SM & even some 15+ year old rotella-T SL grade.... stored in climate controlled area off the ground, shake them every year or so & again before using.
Valvoline FAQ- "DOES MOTOR OIL EXPIRE? IF NOT, HOW LONG DOES MOTOR OIL GENERALLY LAST?
Valvoline motor oils do not have documented expiration dates. When stored under optimal conditions, the product remains stable for an extended period of time. It can be used as long as the American Petroleum Institute (API) rating on the label continues to meet or exceed the requirements listed in your car’s owner's manual. If the rating is still current, we advise you shake the container before use to blend any additives that may have settled."
Old 08-05-2024, 09:42 PM
Combustion byproducts in oil have a nasty tendency to turn acidic in the presence of moisture. I’ve seen it in aircraft recip engines and classic automotive engines as well. Changing the oil is cheap insurance to prevent acid damage of internal engine components.
Dr. Thomas Sowell
Old 07-22-2024, 11:10 PM
Lead was taken out of babbitt years ago. We used to have to re-babbitt Model T and Model A connecting rods; the original composition was lead faced. The replacement babbitt was tin and antimony.
Dr. Thomas Sowell
Old 08-01-2024, 05:38 PM
I put Driven GP1 10W30 in just like my last oil before oil change. I'll have it tested after about 2000 miles and see how it comes back (that could be two years though!).
Old 08-01-2024, 07:32 PM
Don't think I'd leave it in 2 years. I'd be interested in seeing that oil sample, lol. How old was the oil from the last analysis? Were they made aware or just mileage?
Very few oils have an additive package that promotes long time storage like that, which is what that would be considered given you only drive 1000 miles a year.
I'm not sure if Driven is that way or not or if they make one specific, but Amsoil does make an oil specifically for that purpose with an additive package that fights against moisture and corrosion that typically happens with cars that sit for periods of time. Especially if you live in a moist climate.
Old 08-01-2024, 10:51 PM
Jay S's Avatar
Driven GP1 uses an additive for long term storage. Supposedly similar to what the military uses.
I wonder if long term storage could raise the lead level if a source of lead is exposed?
The levels from the sample of moly and boron are typical of GP1, those are in a normal range for that oil.
Old 08-01-2024, 11:19 PM
jhein's Avatar
That's great info to know, thanks very much.
Old 08-02-2024, 07:44 AM
Good to know there are others that offer that kind of additive package.
I don't know what sitting a long time does to the oil, I've never sent a sample in that's just been sitting for months but I'd be interested in seeing one. With oils formulated just for that purpose I can see where it might be concerning.
Old 08-02-2024, 10:28 AM
jhein's Avatar
The sample I sent in sat over the winter, 5-6 months. I'll be sending in another sample in about 2-3 months that will be "fresh" after about 2000 miles.
The Following User Says Thank You to jhein For This Useful Post:
