Old 07-30-2024, 12:59 PM
jonra3 jonra3 is offline
Default Wrinkle Finish for Steering wheel hub.
Hi guys, is any one restoring the hub behind the formula wheel with the correct wrinkle finish. I remember awhile back someone was doing this for members.
Any help is appreciated.
Old 07-30-2024, 01:01 PM
65madgoat's Avatar
Formulabruce was and I am actually waiting to send him a couple. Maybe you can ping him and see if is now able to do some again.
Old 07-30-2024, 01:24 PM
Yes I just received a pm from him.
Jon
The Following User Says Thank You to jonra3 For This Useful Post:
Old 07-30-2024, 03:27 PM
Ramairnacho Ramairnacho is offline
Im.waiting too
Old 07-30-2024, 03:32 PM
comanchefirebird comanchefirebird is offline
Bruce restored my steering wheel collar about a year ago. Awesome job!
Steve
Old 07-30-2024, 07:50 PM
RamAirBirds RamAirBirds is offline
Yes, I had Bruce do 5 for me....They are all perfect...Sent him really good cores though....Early ones are slightly different than later...If I remember it is not a noticeable different once installed...
Old 07-31-2024, 10:13 AM
78w72 78w72 is offline
FYI for those wanting to do this themselves- The wrinkle paint is pretty common from most brands and is not difficult to apply. Ive done at least 7 or 8 of these using Krylon & VHT wrinkle paints. Directions are on the can, with uniform heat like sitting in the sun for an hour or 2 or a heat gun or oven if you have one to use for paint/powder coat curing you can get very good results.
However if another person is offering the service with good results then thats an easier option but it can be done DIY for about $10 in paint the paint to match your interior if not black.
Old 07-31-2024, 11:57 AM
bhill86's Avatar
bhill86 bhill86 is offline
Anyone have a pic of what’s considered “correct” wrinkle finish? I had the hub from my car and a spare that each had a particular finish. I refinished both with good results but it’s not exactly the same so what’s considered correct? Pics below.
Also for the record I used the same method 78w72 described with a heat gun for the best results.
ID:	637672   Click image for larger version
ID:	637673   Click image for larger version
ID:	637674   Click image for larger version
1977 Trans Am 400/4speed (swap)
Brian
The Following User Says Thank You to bhill86 For This Useful Post:
Old 07-31-2024, 12:33 PM
Ive seen the amount of wrinkle finish vary on different year firebirds, I have a lower mile 29k, bought at 24k 1981 pace car and the wrinkle finish is very light compared to my originals on a 50k mile 78 TA.
Ive owned just short of 50 of these cars over recent years, all in varying condition and the amount of texture varies. I think a tighter & not too aggressive texture is correct for most these cars, too much wrinkle doesnt match waht Ive seen but if its done evenly almost any amount will look good & far better than most collars that have degraded or flaked off over the years. I will try to find or get pics of the originals on my cars.
The last 2 pics of bhills looks very good, not too heavy and very even.
Edit- just found a pic of one of the lowest mile original 78 TA's out there, this pics is from a local to me 5000 original miles TA, the texture is heavier than most Ive seen and far more than my 81... so I think its safe to say the amounts varied over the years and there is no "correct" amount.
Old 08-01-2024, 10:29 AM
RAIVJUDGE's Avatar
RAIVJUDGE RAIVJUDGE is offline
I take my collars to a local powder coating company. They have a black wrinkle finish that is spot on and they look NOS when done. Cost was $50.00.
Look up a reputable company that does powder coating and show them what you need. It will perfect
Atoll Blue, Blue interior, 1970 RAIV Judge/4 spd/ 3.90/ pwr steering/ pwr brakes/ hoodtach/ gauges/ sport wheel/ console/ remote mirror/tinted glass.
Starlight Black, Camel Tan interior, 1978 Trans Am . Auto/AC/door edge guards/ am/fm, Cassette stereo/ floor mats frt and rear/Hurst Hatches
Cameo White, Blue interior, 1971 Trans Am/4spd/ Am/Fm/ power windows / AC. 28,000 original miles
Old 08-01-2024, 08:56 PM
Formulabruce's Avatar
A durable long lasting coating only works with proper prep, and once it's cleaned, bead blasted, and needs work, the powder coater is done, and the blems show. I have a lot of pics of early collars that needed a lot if body work ( factory defects due to process. These hold no electrical charge and can't be powder coated like normal and take more time, and a different process. If you have a 69 - 72 hub chances are it needs more work than you may see.
" Long may we DRIVE !"
Old 08-01-2024, 10:16 PM
Default hubs
When can we ship you hubs?
The Following User Says Thank You to Ramairnacho For This Useful Post:
Old 08-01-2024, 10:28 PM
Middle of Sept looks do able. I have a set up I move into shop which is in one of my containers. Trying to get a buddies 70 formula finished and it's been a challenge with the glass not being curved enough. .. I have not forgotten about these.
The Following 3 Users Say Thank You to Formulabruce For This Useful Post:
Old 08-01-2024, 11:52 PM
Default glass
I hear repop glass isn't correct please provide us more info in future
thank you
Old 08-02-2024, 12:11 AM
bhill86's Avatar
thank you
There’s a very good write up over at TAC concerning aftermarket glass and which ones fit and which don’t. I believe auto city classic is one people like. Just FYI
Brian
Old 08-02-2024, 08:37 AM
RamAirPwr RamAirPwr is offline
Bruce
Great to hear you'll do another run
I'm in
1970 RAIII white/blue
The Following User Says Thank You to RamAirPwr For This Useful Post:
Old 08-02-2024, 09:40 AM
bhill86's Avatar
How about a photo of a “formulabruce” finished product too please.
Brian
Old 08-02-2024, 08:26 PM
necdb3's Avatar
necdb3 necdb3 is offline
X2, it's very easy to do and cost next to nothing. Mine is now 17 years old and still looks great.
The Following 2 Users Say Thank You to necdb3 For This Useful Post:
Old 08-02-2024, 09:20 PM
Prep is everything. I gave up on vht long ago. If you have nice collars and want to try it, I think all should. What I do, I make no money on, just do it to help the hobby.
What I do has Uv protection.
If you have a 69-72 ish collar it may not be so nice once it's cleaned.. for a paint job.
Old 08-03-2024, 08:01 AM
Norwood's Avatar
Norwood Norwood is offline
I’ve done many over the years. I’ve tried many different brands of paint and have always had the best result using the Eastwood brand.
