Old 08-03-2024, 03:33 PM
Beers Beers is offline
Default Need help identifying rear differential
The original 8.2” rear end in my ‘68 GTO looks to have been replaced by an 8.5” one, just judging from the square casting protrusions on the bottom corners.
Trying to figure out what it came out of, but having a hard time finding a casting number through the standard layers of hard crud. I did find the stamping on the front of the passenger tube, looks like: CJ K-044 G. The only casting/date code I could find is not legible, it was on the underside front of the center section, on the passenger section.
From the stamping, any ideas on what this could have come from? Or other areas to check for a casting number? (I’ve scraped off several areas and no luck so far).
Doesn’t look like the mountings were moved or added, but will need to scrape off a bunch more crud to verify that.
It’s not limited slip, and drives rpm-wise like it has 3.36 or 3.42 gears (I’m going to remove the cover soon to change out the oil anyway, so will verify then).
1968 GTO Aegena Blue
Previous: 1970 Firebird Formula 400, 1964 Catalina, 1968 Firebird, 1967 Firebird 400 conv
Old 08-03-2024, 04:15 PM
67drake's Avatar
67drake 67drake is offline
I won’t even attempt.
Easy to tell when you pull the rear cover as the ring gear bolts are different size and thread. I can’t remember sizes off hand, but easy enough to look up. I have an 8.5 that all the experts claimed was an 8.2 but easy to miss visually from looking at the outside. I pulled out of a ‘72 Cutlass. I’m sure Ol Pinion Head might be able to tell.
‘55 Catalina
Old 08-03-2024, 04:25 PM
Need the date code year to be certain.
(the 044 is Feb 13 of the year)
But the CJ could be a 1971 Firebird with 3.42 gear and locking dif.
Or 1973 A or G body with 3.42 gear and locking dif.
Or 1977 A or G body with 2.56 gear and locking dif.
And if you had my luck it would be the 2.56 gear rear.
Old 08-03-2024, 04:26 PM
67drake's Avatar
I THINK it was this one ( I have a few 8.5’s sitting around). Looks like an 8.2 by some standards.
‘55 Catalina
Old 08-04-2024, 10:05 AM
I just picked up some gear oil so will pull the cover off this week, the insides don’t lie!
The Following User Says Thank You to Beers For This Useful Post:
Old 08-04-2024, 10:16 AM
3.42 is what it feels like driving on the freeway, at 65 mph I’m just a little shy of 3K rpms with BFG 245/60 14’s. Definitely not 2.56, I’d be driving 90 with those lol. I’ll see what gears are in it this week.
Maybe the width end to end will shine light on whether it’s from a 2nd gen F body, or a later A/G. This could help me locate the casting number.
It does have some welding shenanigans on it after all, I can’t imagine these pointy mounts came on anything factory from GM.
Old 08-04-2024, 10:21 AM
67drake's Avatar
Man, I hope you plan to grind that down. I’d hate to be working under there and hit my head on that!
‘55 Catalina
Old 08-04-2024, 01:40 PM
AG's Avatar
AG AG is offline
That looks like an Olds 8.5" rear.
The Following User Says Thank You to AG For This Useful Post:
Old 08-05-2024, 12:44 PM
Popped off the cover, at least I know what gear ratio it is. 3.42’s. And aftermarket gears.
At least the teeth look great and oil was clean (never seen purple gear oil, assuming it is synthetic, especially since it doesn’t smell like GO). Somebody went through this rear end internally at some time…
Old 08-05-2024, 01:23 PM
Def, one of the two different versions of 8.5 A-body housings that Olds mfg for '71-72 Olds & Buick A-body's. Buick manufactured the style with the cutout rear cover AND the large totally squared off lugs on the bottom.
Since the early 90's have purchased near 350 8.5 A-body cores for performance rear builds, the Olds mfg style with the A10 axle bearings has always been the least common to pull.
The Olds axle plant, for some reason, also manufactured quite a few 8.5 A-body A9 axle bearing end housings with the same round cover housing. Am starting to pay attention to casting dates on that particular style housing, trying to determine if only manufactured towards the end of the '72 production run.
By far the Buick style center housing (2 plug welds visible outboard per side, as well as the cutout rear cover) is the most common of the '71-72 8.5 A-body housings. Inventory files notes I have 21 of the Buick style & only two of the Olds style.
The Following 4 Users Say Thank You to 'ol Pinion head For This Useful Post:
Old 08-05-2024, 03:32 PM
Thank OPH, appreciate the info. You definitely know these.
Did Olds/Buick use these on other body styles as well in 71/72? Or could these be from a ‘73+ A-body? The upper control arm mounts are stock, but looks like the lower control arm mounts have been moved ~2 1/4” outboard to fit this ‘68.
Old 08-05-2024, 06:09 PM
Coil spring '73-77 A-body/'77+ B-body housings had inboard shock mounts as part of each lower control arm mtg bracket. Earlier A-body rears had outboard shock mounting. The oddest outboard shock mounts were on 8.5 A-body housings used on the housings in VistaCruiser wagons.
It looks like someone has crudely cut off that area on each of your lower control arm mtg brackets, that makes me believe it's a '73-77 style coil spring housing that the shock mounts have been modified.
The spread between their upper control arm perches on the '73-77 housings is several inches wider than on all the earlier A-body rears. I once ran across a '70 ElCamino where the frame crossmember area where the upper control arm mounts, had been cut out, & a section cut out of a '73 & later A-body had been welded in. The other fit problem with the '73-77 A-body rears is they are little over an 1" wider than the '71-72 8.5 A-body rears. With the factory drums installed, the width of the '71-72 8.5 A-body rears are 61 5/16". '68-72 10 bolt & 12 bolt "Chevelle" rears are also very close to that width with drums installed.
The Following 2 Users Say Thank You to 'ol Pinion head For This Useful Post:
Old 08-05-2024, 07:03 PM
Schurkey Schurkey is offline
'75 Monte Carlo 10-bolt axle showing A-body control arm and shock mountings.
ID:	637987   Click image for larger version
ID:	637988   Click image for larger version
The Following 2 Users Say Thank You to Schurkey For This Useful Post:
Old 08-05-2024, 08:06 PM
I think OPH nailed it. ‘73-‘77 A-body.
Looking at your photos Schurkey, and the ‘75 cutlass photo below, I can see how that bracket has been cut apart to separate the control arm and the shock mounting, and then welded back together on this differential to earlier 68-72 layout.
I’ll have to check the overall width again to get a more accurate measurement, but it’s about 55” to the inside of the axle flange (this diff has been converted to rear disc, so no drums to check overall width). And it’s about 7.5” between the insides of the mounted upper control arms (I don’t have another 68-72 A-body diff to compare this against so don’t know if this is a lot wider).
Old 08-05-2024, 08:27 PM
67drake's Avatar
Attachment 637991
Here’s the measurement inside flange to inside flange of the 8.5 I pictured earlier. I also just double checked an 8.5 that is from a 71 or ‘72 Skylark, and it’s measurement is identical to this one I pictured.
‘55 Catalina
Old 08-05-2024, 08:32 PM
67drake's Avatar
Thanks. I pulled these so long ago, and can’t remember which is which. I could get these off of Craigslist for $50-75 each with open carriers and highway gears, so I stocked up figuring they would be harder to find in the future.
‘55 Catalina
Old 08-05-2024, 08:56 PM
Thanks 67drake! Looks like what I have here, I’ll double check.
Old 08-06-2024, 09:14 PM
Yup, the inside flange to flange is 55 3/8”, so this rear end is ~1/2” wider. Not a problem.
Thanks again for everyone’s help, especially OPH. Much appreciated.
Old 08-09-2024, 09:18 PM
59safaricat 59safaricat is offline
Royal Purple gear oil. It's synthetic.
The Following User Says Thank You to 59safaricat For This Useful Post:
Old 08-10-2024, 01:07 AM
Any chance this stuff smells like grape juice?
GM/ACDelco sells really expensive, synthetic gear oil (10-4016) that's listed on the bottle as having a "new grape scent".
https://www.amazon.com/ACDelco-10-40.../dp/B000QGOX1A
I'm just wondering if ACDelco is buying this stuff from Royal Purple.
