| THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
Only time I've seen that is with a SR (Service Replacement block). Are you looking in the correct location(s)? Most common area is along the side of the timing cover about halfway down between the top and bottom of it on the passenger side. Another location is toward the top of the timing cover farther toward the outside of the block
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
| The Following User Says Thank You to Gary H For This Useful Post: | ||
I believe the EUN number is on PHS paperwork, if you have that.
be a simple...kinda man. |
I think that they stopped putting the EUN on the billing sheets in 1968 or 1969.
| The Following User Says Thank You to Joe's Garage For This Useful Post: | ||
Yes stopped after 68
| The Following User Says Thank You to Tellyshavilli For This Useful Post: | ||
Canadian "PHS" (Vintage Vehicle Services )documents show EUN after 68.
| The Following User Says Thank You to Bermuda Blue For This Useful Post: | ||
First one was a 428/370hp in a 1969 Grand Prix that we bought from the original owner. It was rusted beyond belief and we parted it out. This was in about 1985 - before GPs became somewhat collectible.
Second was a couple years later and was a 1971 GTO 400 engine that came out of a rolled and burnt GTO that we found in a wrecking yard in Tooele Utah. We bought the engine and transmission, then resold the engine about a year later. I think we still have the T400 somewhere. Third one was a 455 in a 1973 Bonneville that was owned by a friend here in Las Vega$. We helped him change out the timing chain shortly after he bought it from somewhere back east. He drove it around for about three or four years and then sold it to someone out in California. All of these had EUNS and correct matching date codes and engine codes. Just no partial VIN anywhere at all on the front surface. Maybe we were just lucky enough to go through enough Pontiacs to stumble across these. I've gotta believe that there are/were more. |
