What are you guys using to plug the heater outlet on timing cover?
Tim Corcoran |
$60 shipped.
I believe this covered in the Jim Hands How to Build a HP Pontiac V8…IIRC, it’s a 3/8 pipe plug?
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
| The Following User Says Thank You to grivera For This Useful Post: | ||
Carefully tap it for a 3/8 NPT pipe plug. Don’t run the tap too deep, test your plug a few times during the process.
The casting is thin so don’t over tighten the plug. No need to cut the hose nipple off of the cover, just thread it for the plug. This of course assumes the nipple isn’t corroded and thin.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
| The Following User Says Thank You to b-man For This Useful Post: | ||
Thanks, I need to look and see if I have a 3/8 pipe tap
Tim Corcoran |
Use RTV on the plugs threads
