Old 07-28-2024, 09:21 AM
Dave73TA's Avatar
Dave73TA Dave73TA is offline
Default Steering column .
Looking for a 1973 firebird steering column .NON tilt .Or at least the main input shaft .Or rebuilding service near Connecticut .Somethings wrong with mine .The spline with notch doesn't stick out far enough .Colasped or bad upper bearing .In Connecticut .Thanks .
Old 08-12-2024, 10:07 PM
Formulabruce's Avatar
Text me Dave, Ill help ya, Bruce
" Long may we DRIVE !"
Old 08-19-2024, 02:08 PM
unruhjonny's Avatar
I am posting incase this helps.
As far as I am aware, these are the same part for ALL 1970-1978 F-bodies;
I believe that the brights switch moved from the floor to the column in 1979 - which was when the column changed (but It may have been 1980);
If you find a parts car, look for the floor mounted brights switch as a way of confirming that you found a good part.
1970 Formula 400
Old 08-27-2024, 12:37 PM
newmexguy newmexguy is offline
There is a rebuilder in Cheshire. Paul Toller. I've sold him parts columns and miscellaneous pieces. Columns Galore is also close, in Westchester County to best of belief. They should still be in business.
Old 08-27-2024, 12:57 PM
Dave got his column shaft pulled out weeks ago. No rebuild needed.
