I finally got my car down to the track this weekend. I don't have a lot of experience racing at a track because i live on Long Island and up until recently we haven't had a track, so i thought id ask you guys here. The car is a 64 Le Mans. It has a 198ci 4 cylinder with a turbo. It has around 200hp with out the turbo so unless it has manifold pressure its a real dog . Turns out i had a real big exhaust leak and couldn't build any pressure at the line. Not until the 330 is when the pressure started ramping in and start making power . So basically from the 330 to the 660 is where it was all in.. I wish they told you the mph at the 330 . If i were to guess it was maybe 45 mph at best lol.
So my question is , is there a way to figure out for now until i fix the car and go back what the mph would of been if it would have left with all the power? I'll post the time slip Thanks
My Half AN Injun..... Last edited by charlie66; 09-02-2024 at 07:26 AM. |
Your 660 et is 6.15 ?
I think you'll Be mid nines I'm at 3600# and w tight converter run 112-114 in the eight around 6.0x to 6.1x You'll run in the 5s if you're not leaving hard now
1968 firebird cameo white on red 400 4 speed 1969 carousel red firebird 455, richmond 5 speed 1964 gto pump gas, 505 IA2 EHeads, EFI, 92 mm turbo ice cream getter in process now.... 1970 lemans hardtop, gto clone Atoll Blue 1972 Maverick powered by 2004 gto ls1 and t56 6 speed, 8.8, fox strut front end, wifes car |
I don't think your MPH will be much more. I think your et will be in the very low 7's maybe very high 6's
Stan
He ran on an 1/8th mile track. That would be the 330' et. (I think)
I had a big crack in the cross over pipe so i had zero boost until after the 330 . So it was barley moving the car until after the 330. Most of the mph came after the 330 . So im wondering what the mph would be if i had full power from the starting line . If i was going any faster then 45 mph at the 330 id be surprised ..
My Half AN Injun..... |
So if the car was charging at full power to the 330 instead of moving like a turtle how much more mph would you say id pick up? I mean it left so slow it was embarrassing lol. This motor would be lucky if it made 150 Lb-ft on its best day. The car weighs 3500 lbs with me in it .
Yes that's correct
Heres what i found today . There was also another little crack on the other side of the pipe .
Who welded that pipe? Edwin. Lol
71 Lemans Sport. 72 Lemans Sport. RIP 75 Grandville Convertible. |
With that 60' (2.445 ?) and the 330' (6.155 ?) the MPH of the 330' is probably around 65/68 ?
The 1/8th would have been around a 9 second pass, so you were hauling in the last half. (plus about 10 MPH faster than the 60' / 330' shows) Get the boost going it should haul some butt.
I did get the pipe fixed and was able to make 8 psi on the trans break.. I'm going to try and get back there this weekend or the next.. The other issue was when the boost did come in was spinning the tires . I don't have slicks . just some Nitto drag radials .. so i know that i need to step up and get some slicks . Thanks for your thoughts on this ...
